And these days I found somebody fix the similar problem so I want to ask again if my problem can be solved.How to check about if my bsp package including the overlay I mentioned and can this overlay fix some of my problem?
Could you capture the full serial console (UART) log while you run the backup/restore, and continue capturing through the boot attempt that hits the “can’t find PARTUUID” error? Please also share the exact l4t_backup_restore.sh commands you use. That will let us pin down where the PARTUUID is getting lost.
Log has been post in link and I don’t think this problem can be cause by lots of reason,can’t you find that so much people asking about this?It must be point at an abvious reason.I think I should repeat my problem again,is it cause by qspi?I just want to check out why and how.
The error you showed isn’t related to QSPI, since the boot process has already moved on to the kernel stage. A screenshot isn’t enough for us to find the root cause, so please send the full log so we can look into possible reasons.
Also, make sure your backup and restore are done only between NVMe drives of the same size. If the sizes differ, the golden image may be too large to write onto a smaller drive.
