Hello:
I’m bringing up camera module(2M, gmsl2) on orin. Now serdes seems work well(video lock ok).
But I can’t receive frame data from orin MIPI CSI.
Serdes: max96717 + max96712
Resolution: 1920x1080(2M YUV422-8)
v4l2-ctl -d /dev/video1 --stream-mmap --set-fmt-video=width=1920,height=1080,pixelformat=YUYV --stream-count=100
The trace reports CHANSEL_FAULT at begining of dump, then reports CHANSEL_NOMATCH.
- CHANSEL_FAULT error bit is PIXEL_SHORT_LINE, but I tried to decrease size to both 1, but still error.
- CHANSEL_NOMATCH shows vc/dt not match, but I’ve already set format to YUV in dts and v4l2-ctl, and set vc to 0 in serdes.
Trace log(part, attach file is the full logs):
kworker/3:14-185 [003] .... 18407.580004: rtcpu_vinotify_event: tstamp:575838598451 cch:0 vi:1 tag:FS channel:0x00 frame:0 vi_tstamp:18426835126336 data:0x0000000000000012
kworker/3:14-185 [003] .... 18407.580005: rtcpu_vinotify_event: tstamp:575838915823 cch:0 vi:1 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:18426835126336 data:0x0000000800000000
kworker/3:14-185 [003] .... 18407.580005: rtcpu_vinotify_event: tstamp:575838915960 cch:0 vi:1 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:18426836243552 data:0x0000000000000001
kworker/3:14-185 [003] .... 18407.580005: rtcpu_vinotify_event: tstamp:575838916116 cch:0 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:18426836245120 data:0x0000000008020003
kworker/3:14-185 [003] .... 18407.580006: rtcpu_vinotify_event: tstamp:575838916251 cch:0 vi:1 tag:**CHANSEL_FAULT** channel:0x23 frame:0 vi_tstamp:18426836253088 data:**0x0000000000000200**
kworker/3:14-185 [003] .... 18407.580006: rtcpu_vinotify_event: tstamp:575838916405 cch:0 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:18426836259808 data:0x0000000001020003
kworker/3:14-185 [003] .... 18407.580006: rtcpu_vinotify_event: tstamp:575839253935 cch:0 vi:1 tag:**CHANSEL_FAULT** channel:0x23 frame:0 vi_tstamp:18426855426304 data:**0x0000000002cf0202**
kworker/3:14-185 [003] .... 18407.580006: rtcpu_vinotify_event: tstamp:575839254088 cch:0 vi:1 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:18426855426912 data:0x0000000000000000
kworker/3:14-185 [003] .... 18407.580006: rtcpu_vinotify_event: tstamp:575839254220 cch:0 vi:1 tag:**CHANSEL_FAULT** channel:0x23 frame:0 vi_tstamp:18426855443424 data:**0x0000000002d00240**
kworker/3:14-185 [003] .... 18407.580007: rtcpu_vinotify_event: tstamp:575839885165 cch:0 vi:1 tag:FE channel:0x00 frame:0 vi_tstamp:18426870893728 data:0x0000000000000022
kworker/3:14-185 [003] .... 18407.580007: rtcpu_vinotify_event: tstamp:575839885304 cch:0 vi:1 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:18426870893728 data:0x0000000800000000
kworker/3:14-185 [003] .... 18407.580007: rtcpu_vinotify_event: tstamp:575839885456 cch:0 vi:1 tag:FS channel:0x00 frame:0 vi_tstamp:18426875126080 data:0x0000000000000012
kworker/3:14-185 [003] .... 18407.580007: rtcpu_vinotify_event: tstamp:575839885592 cch:0 vi:1 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:18426875126080 data:0x0000000800000000
kworker/3:14-185 [003] .... 18407.580007: rtcpu_vinotify_event: tstamp:575839885744 cch:0 vi:1 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:18426876243296 data:0x0000000000000001
kworker/3:14-185 [003] .... 18407.580008: rtcpu_vinotify_event: tstamp:575839885876 cch:0 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:18426876244864 data:0x0000000008020004
kworker/3:14-185 [003] .... 18407.580008: rtcpu_vinotify_event: tstamp:575839886029 cch:0 vi:1 tag:**CHANSEL_FAULT** channel:0x23 frame:0 vi_tstamp:18426876252832 data:**0x0000000000000200**
kworker/3:14-185 [003] .... 18407.580008: rtcpu_vinotify_event: tstamp:575839886161 cch:0 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:18426876259552 data:0x0000000001020004
kworker/3:14-185 [003] .... 18407.635999: rtcpu_vinotify_event: tstamp:575840504709 cch:0 vi:1 tag:**CHANSEL_FAULT** channel:0x23 frame:0 vi_tstamp:18426895426048 data:**0x0000000002cf0202**
kworker/3:14-185 [003] .... 18407.636000: rtcpu_vinotify_event: tstamp:575840504853 cch:0 vi:1 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:18426895426656 data:0x0000000000000000
kworker/3:14-185 [003] .... 18407.636000: rtcpu_vinotify_event: tstamp:575840505003 cch:0 vi:1 tag:**CHANSEL_FAULT** channel:0x23 frame:0 vi_tstamp:18426895443200 data:**0x0000000002d00240**
kworker/3:14-185 [003] .... 18407.636001: rtcpu_vinotify_error: tstamp:575841133390 cch:0 vi:1 tag:**CHANSEL_NOMATCH** channel:0x04 frame:0 vi_tstamp:18426916243008 data:**0x00000000000003c9**
kworker/3:14-185 [003] .... 18407.636001: rtcpu_vinotify_event: tstamp:575841180660 cch:0 vi:1 tag:FE channel:0x00 frame:0 vi_tstamp:18426910893440 data:0x0000000000000022
kworker/3:14-185 [003] .... 18407.636002: rtcpu_vinotify_event: tstamp:575841180815 cch:0 vi:1 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:18426910893472 data:0x0000000800000000
kworker/3:14-185 [003] .... 18407.636002: rtcpu_vinotify_event: tstamp:575841180946 cch:0 vi:1 tag:FS channel:0x00 frame:0 vi_tstamp:18426915125792 data:0x0000000000000012
kworker/3:14-185 [003] .... 18407.636002: rtcpu_vinotify_event: tstamp:575841181095 cch:0 vi:1 tag:**CHANSEL_NOMATCH** channel:0x04 frame:0 vi_tstamp:18426916243008 data:**0x00000000000003c9**
kworker/3:14-185 [003] .... 18407.692001: rtcpu_vinotify_error: tstamp:575842383380 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:0 vi_tstamp:18426956242752 data:0x00000000000003c9
kworker/3:14-185 [003] .... 18407.692002: rtcpu_vinotify_event: tstamp:575842532922 cch:0 vi:1 tag:FE channel:0x00 frame:0 vi_tstamp:18426950893216 data:0x0000000000000022
kworker/3:14-185 [003] .... 18407.692002: rtcpu_vinotify_event: tstamp:575842533074 cch:0 vi:1 tag:FS channel:0x00 frame:0 vi_tstamp:18426955125536 data:0x0000000000000012
kworker/3:14-185 [003] .... 18407.692002: rtcpu_vinotify_event: tstamp:575842533206 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:0 vi_tstamp:18426956242752 data:0x00000000000003c9
kworker/3:14-185 [003] .... 18407.692002: rtcpu_vinotify_event: tstamp:575843547022 cch:0 vi:1 tag:FE channel:0x00 frame:0 vi_tstamp:18426990892928 data:0x0000000000000022
kworker/3:14-185 [003] .... 18407.692003: rtcpu_vinotify_error: tstamp:575843633368 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:0 vi_tstamp:18426996242464 data:0x00000000000003c9
kworker/3:14-185 [003] .... 18407.747996: rtcpu_vinotify_event: tstamp:575843885033 cch:0 vi:1 tag:FS channel:0x00 frame:0 vi_tstamp:18426995125248 data:0x0000000000000012
kworker/3:14-185 [003] .... 18407.747997: rtcpu_vinotify_event: tstamp:575843885189 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:0 vi_tstamp:18426996242464 data:0x00000000000003c9
kworker/3:14-185 [003] .... 18407.747997: rtcpu_vinotify_error: tstamp:575844883344 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:0 vi_tstamp:18427036242208 data:0x00000000000003c9
kworker/3:14-185 [003] .... 18407.747997: rtcpu_vinotify_event: tstamp:575844883805 cch:0 vi:1 tag:FE channel:0x00 frame:0 vi_tstamp:18427030892640
Device tree:
pix_clk_hz = "100000000";
num_lanes = "4";
tegra_sinterface = "serial_c";
mode_type = "yuv";
pixel_phase = "yuyv";
csi_pixel_bit_depth = "16";
active_w = "1920";
active_h = "1080";
line_length = "1920";
embedded_metadata_height = "0";
I tried the follow actions, but still reports error:
- Boost the rates as Jetson/l4t/Camera BringUp - eLinux.org
- Narrow down active_w/active_h/line_length, even to 1
- Increase embedded_metadata_height(no effection, for serdes pipeline only mapped FS/FE/YUV422-8 datatypes)
- Burn RCE FW to debug version, and find no useful information.
I debugged this for days, and have no idea now.
Could you help me or give me some advice, thank you very much!
