ORIN DO NOT START AFTER 6.1 UPGRADE
Delivered with a version 3.0 of BIOS. After upgrade to version 36 and SKD 6.1, it does not start anymore, no bootup, no splash screen, no information on the screen. Tried to burn like 30 SD cards, but none read and not starting anymore.
Use a physical Ubuntu 20.04 or 22.04 PC and SDK Manager for flashing. No virtual machine. No other distro. Only amd64/x86-64 architecture.
We have burn more than 30 SD cards different way. We have other ORIN kits boards, so we know a little bit how it works and the SD are working on others kits. The faulty ORIN do not show up initial messages, just is a black screen on power up.
Maybe the QSPI boot flash on the module is corrupted. This doesn’t get repaired by swapping SD cards, you need the USB recovery method for this.
Thank you. Can you confirm is this link?
https://docs.nvidia.com/jetson/archives/r35.4.1/DeveloperGuide/text/SD/FlashingSupport.html#enable-agx-orin-orin-nx-and-orin-nano-in-usb3-recovery-mode
Yes, looks good.
we abandon, is impossible to install the pack, we bought new computer, spent hours, no success. Too much bad
