ORIN DP MST Is it possible to display two different resolutions
ORIN DP MST Is it possible to display two different resolutions ??
Are there any detailed specs??
Yes, should be possible. The spec is same as the module datasheet info.
So I can treat it as two independent screens and switch the resolution arbitrarily without affecting each other???
Yes, ideally.
