Software Version
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.2.10884
other
Host Machine Version
other
Hello NVIDIA Team,
I’m having some difficulties getting a device connected via the 1000BASE-T1 ports on the Spruce switch and I was looking to confirm that the following is correct to help debug and confirm our observations:
- Are all of the port roles for the 1000BASE-T1 connectors set as Master/Primary? This document says so but i wanted to confirm this is the case. We are using the base configuration as confirmed in Aurix. I am connected on pin 1 on J4.
- I am connecting a device that is a 1000BASE-T1 slave. This is set to have an IP address on that same network. This is the only device connected.
Pings all fail, I can see on the arp table that the IP address is present so i’m confident in the setup. I’ve also used a media converter setup as a master and 1000BASE-T1 and i can communicate to the device i am connecting. I’m confident that I am configuring the attached device correctly in this case.
Is there any mechanism to check the Port role to confirm if it is configured correctly? i understand that changing the port role may not be supported by the forum, but is checking the status possible?
Thanks,
