Orin DriveOS NITO file from Jetson ISP tuned settings
I wanted to find out, given the number of cameras supported by DriveOS are limited as compared to those supported by Jetson, is there a process by which we can use the ISP settings from Jetson to port those into DriveOS?
For example, if I have an ISP file that was developed with a GMSL2 camera targeted for Jetson, is there a process by which that can be converted to be compatible with the NITO format for DriveOS? Or better yet, is that ISP file something that we could use in Drive as the NITO file?
thanks for your help!
We don’t have the guidance as the camera stack and application layer are different.
There is no cross reference, and need to do the study seperately.
