Orin driver os kernel compile error: FAILED unresolved symbol udp6_sock
I have successfully compiled the kernel without the config: CONFIG_DEBUG_FS=y. But when I enable it, the compiling became failed. The error information shows below:
MODPOST vmlinux.symvers
MODINFO modules.builtin.modinfo
GEN modules.builtin
LD .tmp_vmlinux.btf
BTF .btf.vmlinux.bin.o
LD .tmp_vmlinux.kallsyms1
KSYMS .tmp_vmlinux.kallsyms1.S
AS .tmp_vmlinux.kallsyms1.S
LD .tmp_vmlinux.kallsyms2
KSYMS .tmp_vmlinux.kallsyms2.S
AS .tmp_vmlinux.kallsyms2.S
LD vmlinux
BTFIDS vmlinux
make[2]: *** [/home/lotus/sda/ad4/lambda/lambda_image_src/6040_sdk/ipu04_soc_linux/drive-linux_src/kernel/drive-linux/kernel/source/oss_src/kernel/Makefile:1211: vmlinux] Error 255
make[2]: Leaving directory ‘/home/lotus/sda/ad4/lambda/lambda_image_src/6040_sdk/ipu04_soc_linux/drive-linux_src/kernel/drive-linux/kernel/source/oss_src/output’
make[1]: *** [Makefile:213: __sub-make] Error 2
make[1]: Leaving directory ‘/home/lotus/sda/ad4/lambda/lambda_image_src/6040_sdk/ipu04_soc_linux/drive-linux_src/kernel/drive-linux/kernel/source/oss_src/kernel’
make: *** [Makefile:212: kernel] Error 2
Build kernel FAILED!
The whole log and the config file is attached.
I have learned the post [Orin dev kit] kernel compile error:FAILED unresolved symbol udp6_sock, and browsed on google for a long time, but did not get any help.
If need anything more, please let me know.
Any help will be grateful.
Software Version
DRIVE OS 6.0.6
DRIVE OS 6.0.5
[√] DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[√] Linux
QNX
other
Hardware Platform
[√] DRIVE AGX Orin Developer Kit (not sure its number)
other
SDK Manager Version
[√] 1.9.2.10884
other
Host Machine Version
[√] native Ubuntu Linux 20.04 Host installed with SDK Manager
other
Compiler Version
nvidia_6.0.3.0/toolchains/aarch64–glibc–stable-2020.08-1/bin/aarch64-linux-gcc
gcc version 9.3.0 (Buildroot 2020.08)
compile_error.log (9.6 MB)
.updated.defconfig (32.4 KB)
Dear @haomiao.wang,
May I know if you are using DRIVE AGX Orin Devkit or platform based on DRIVE Orin?
I use platform. But the error is occur at cross compiling.
Dear @haomiao.wang,
Are you using the DRIVE OS 6.0.4 installed using sdkmanager with Devzone credentials? The logs looks like a sepearte release. Please confirm it.
FYI, This forum is intended to support issues related DRIVE AGX Orin Devkit with devzone releases.
Yeah, We have a Devzone credentials. This develop kit is be used on our cars.
@SivaRamaKrishnaNV
@SivaRamaKrishnaNV Hello, I find an interesting thing. The config CONFIG_DEBUG_INFO_BTF and CONFIG_DEBUG_FS can only enable either one. But it will be compiled failed when you enable that two meanwhile.
Dear @haomiao.wang,
I see below command in compile_error.log
lotus@ubuntu:~/sda/ad4/lambda/lambda_image_src/6040_sdk/ipu04_soc_linux$ ./zfuse_build.sh host -j40 LOTUS_SOC_V6040_ADMC_V5.4.1A_PP-J1-EU-CS_20230519 LOTUS_sign
This script is not part of DRIVE OS 6.0.4 Devzone release.
The kernel compilation instructions are at Compiling the Kernel (NVIDIA DRIVE OS Linux) | NVIDIA Docs . Please see if it helps.
@SivaRamaKrishnaNV Yeah, this script is used for generating our filesystem image. But it doesn’t matter, it will execute make kernel image. The important things is the .updated.defconfig. In the compile_error.log, you just only concern the line which I post on:
Just as I mentioned, The compile can be succeed when only enable either CONFIG_DEBUG_INFO_BTF or CONFIG_DEBUG_FS.
Can you take a try please?
Dear @haomiao.wang,
I am just trying to understand if you are trying to perform the same steps provided in Compiling the Kernel (NVIDIA DRIVE OS Linux) | NVIDIA Docs or you are trying some thing else.
Also, May I know If it is P3710 or something else (like IPU04 ECU)?
Dear @SivaRamaKrishnaNV,
Yeah, I have tried the Docs you mentioned step by step, but it also shows a similar result:
FAILED unresolved symbol netlink_sock
The whole log is attached.
6040_compile_error.log (467.1 KB)
By the way, It seems the bug of DRIVE OS 6.0.4. It is ok with DRIVE OS 6.0.6. You can have a try with the config CONFIG_DEBUG_INFO_BTF=y and CONFIG_DEBUG_FS=y meanwhile using DRIVE OS 6.0.4.
Yes, our ECU is IPU04.
Dear @haomiao.wang,
So, the issue is resolved after upgrading to DRIVE OS 6.0.6.
@SivaRamaKrishnaNV , Yeah, thanks for your time.
