Orin flash
error :File rcm_state open failed
Decompressing rootfs...
rootfs_ab 0 flash_pads10-a2
rootfs
Flashing Pegasus board pads10-a2
# L4T BSP Information:
# R35 , REVISION: 4.1
# User release: 0.0
# Target Board Information:
# Name: jetson-agx-orin-devkit, Board Family: t186ref, SoC: Tegra 234,
# OpMode: production, Boot Authentication: NS,
# Disk encryption: disabled ,
copying emc_fuse_dev_params(/home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/flash_pads10-a2/bootloader/t186ref/BCT/tegra234-br-bct-diag-boot.dts)... done.
copying device_config(/home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/flash_pads10-a2/bootloader/t186ref/BCT/tegra234-mb1-bct-device-p3701-0000.dts)... done.
copying misc_config(/home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/flash_pads10-a2/bootloader/t186ref/BCT/tegra234-mb1-bct-misc-p3701-0000.dts)... done.
./tegraflash.py --instance /dev/bus/usb/001/010 --chip 0x23 --applet "/home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/flash_pads10-a2/bootloader/mb1_t234_prod.bin" --skipuid --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3701-0000.dts --misc_config tegra234-mb1-bct-misc-p3701-0000.dts --bins "mb2_applet applet_t234.bin" --cmd "dump eeprom cvm cvm.bin; dump custinfo custinfo_out.bin; reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[   0.0177 ] tegrarcm_v2 --instance /dev/bus/usb/001/010 --chip 0x23 0 --ismb2applet
[   0.0182 ] File rcm_state open failed
[   0.0182 ] ERROR: failed to read rcm_state
[   0.0182 ]
[   0.0223 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.0224 ] Assuming zero filled SBK key
[   0.0184 ] Pre-processing config: tegra234-mb1-bct-device-p3701-0000.dts
[   0.0218 ] Pre-processing config: tegra234-mb1-bct-misc-p3701-0000.dts
[   0.0263 ] Parsing partition layout
[   0.0267 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.0275 ] Kernel DTB used: None
[   0.0275 ] WARNING: dce base dtb is not provided
[   0.0275 ] Parsing partition layout
[   0.0280 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.0284 ] Creating list of images to be signed
[   0.0288 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[   0.0292 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.0297 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.0298 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.0318 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.0327 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.0346 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.0347 ] adding BCH for mb2_t234_aligned.bin
[   0.0358 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.0410 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.0411 ] adding BCH for mb2_t234_aligned.bin
[   0.0477 ] Filling MB1 storage info
[   0.0477 ] Parsing dev params for multi chains
[   0.0517 ] Generating br-bct
[   0.0522 ] Updating dev and MSS params in BR BCT
[   0.0522 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   0.0529 ] Updating bl info
[   0.0543 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin
[   0.0557 ] WARNING: boot chain is not completed. set to 0
[   0.0565 ] Generating signatures
[   0.0606 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.0607 ] Assuming zero filled SBK key
[   0.0681 ] Warning: pub_key.key is not found
[   0.0643 ] Parsing dev params for multi chains
[   0.0643 ] Generating br-bct
[   0.0650 ] Updating dev and MSS params in BR BCT
[   0.0650 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   0.0660 ] Updating bl info
[   0.0667 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   0.0674 ] WARNING: boot chain is not completed. set to 0
[   0.0684 ] Get Signed section of bct
[   0.0691 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[   0.0701 ] Signing BCT
[   0.0741 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.0743 ] Assuming zero filled SBK key
[   0.0765 ] Sha saved in br_bct_BR.sha
[   0.0768 ] Warning: pub_key.key is not found
[   0.0728 ] Updating BCT with signature
[   0.0737 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[   0.0747 ] Offset :4608 Len :3584
[   0.0751 ] Generating SHA2 Hash
[   0.0791 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[   0.0793 ] Assuming zero filled SBK key
[   0.0820 ] Sha saved in br_bct_BR.sha
[   0.0783 ] Updating BCT with SHA2 Hash
[   0.0791 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[   0.0798 ] Offset :4608 Len :3584
[   0.0800 ] Offset :68 Len :8124
[   0.0802 ] Generating coldboot mb1-bct
[   0.0810 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   0.0817 ] MB1-BCT version: 0.10
[   0.0818 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[   0.0822 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[   0.0824 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[   0.0826 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[   0.0828 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[   0.0830 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[   0.0832 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[   0.0834 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[   0.0836 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[   0.0838 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[   0.0840 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[   0.0842 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[   0.0843 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[   0.0843 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[   0.0843 ]
[   0.0843 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   0.0843 ] Added Platform Config 9 data with size :- 100
[   0.0843 ]
[   0.0844 ] Updating mb1-bct with firmware information
[   0.0850 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[   0.0868 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[   0.0907 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   0.0923 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   0.0971 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.0973 ] Assuming zero filled SBK key
[   0.0993 ] Warning: pub_key.key is not found
[   0.0964 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   0.0976 ] Generating recovery mb1-bct
[   0.0982 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   0.0987 ] MB1-BCT version: 0.10
[   0.0988 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[   0.0992 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[   0.0993 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[   0.0995 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[   0.0997 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[   0.0998 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[   0.1000 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[   0.1001 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[   0.1003 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[   0.1005 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[   0.1006 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[   0.1008 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[   0.1008 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[   0.1008 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[   0.1009 ]
[   0.1009 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   0.1009 ] Added Platform Config 9 data with size :- 100
[   0.1009 ]
[   0.1009 ] Updating mb1-bct with firmware information
[   0.1014 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[   0.1028 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[   0.1036 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[   0.1040 ] adding BCH for mb1_bct_MB1_aligned.bct
[   0.1083 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.1084 ] Assuming zero filled SBK key
[   0.1091 ] Warning: pub_key.key is not found
[   0.1056 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   0.1062 ] Error: Skip generating mem_bct because sdram_config is not defined
[   0.1062 ] Copying signatures
[   0.1066 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   0.1111 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[   0.1112 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[   0.1112 ] Boot Rom communication
[   0.1118 ] tegrarcm_v2 --instance /dev/bus/usb/001/010 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[   0.1124 ] BR_CID: 0x80012344705DE6C98400000006028240
[   0.1131 ] Sending bct_br
[   0.1131 ] Sending mb1
[   0.1134 ] Sending psc_bl1
[   0.1234 ] Sending bct_mb1
[   0.1291 ] Boot Rom communication completed
[   0.1307 ] tegrahost_v2 --chip 0x23 0 --align applet_t234_aligned.bin
[   0.1330 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --appendsigheader applet_t234_aligned.bin zerosbk
[   0.1342 ] adding BCH for applet_t234_aligned.bin
[   0.1491 ] tegrasign_v3.py --key None --list applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.1493 ] Assuming zero filled SBK key
[   0.1516 ] Warning: pub_key.key is not found
[   0.1485 ] tegrahost_v2 --chip 0x23 0 --updatesigheader applet_t234_aligned_sigheader.bin.encrypt applet_t234_aligned_sigheader.bin.hash zerosbk
[   0.1503 ] Sending mb2_applet...
[   0.1511 ] tegrarcm_v2 --instance /dev/bus/usb/001/010 --chip 0x23 0 --pollbl --download applet applet_t234_sigheader.bin.encrypt
[   0.1529 ] BL: version 1.2.0.0-t234-54845784-562369e5 last_boot_error: 0
[   0.3355 ] Sending applet
[   0.4452 ] completed
[   0.4480 ] tegrarcm_v2 --instance /dev/bus/usb/001/010 --chip 0x23 0 --ismb2applet
[   0.4505 ] MB2 Applet version 01.00.0000
[   0.6790 ] tegrarcm_v2 --instance /dev/bus/usb/001/010 --chip 0x23 0 --ismb2applet
[   0.6813 ] MB2 Applet version 01.00.0000
[   0.6862 ] Retrieving board information
[   0.6885 ] tegrarcm_v2 --instance /dev/bus/usb/001/010 --chip 0x23 0 --oem platformdetails chip chip_info.bin
[   0.6908 ] MB2 Applet version 01.00.0000
[   0.6932 ] Saved platform info in chip_info.bin
[   0.6986 ] Chip minor revision: 1
[   0.6988 ] Bootrom revision: 0x7
[   0.6990 ] Ram code: 0x3
[   0.6993 ] Chip sku: 0xd0
[   0.6993 ] Chip Sample: prod
[   0.6993 ]
[   0.6999 ] Retrieving EEPROM data
[   0.7000 ] tegrarcm_v2 --instance /dev/bus/usb/001/010 --oem platformdetails eeprom cvm /home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/flash_pads10-a2/bootloader/cvm.bin --chip 0x23 0
[   0.7022 ] MB2 Applet version 01.00.0000
[   0.7049 ] Saved platform info in /home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/flash_pads10-a2/bootloader/cvm.bin
[   0.7402 ] tegrarcm_v2 --instance /dev/bus/usb/001/010 --chip 0x23 0 --ismb2applet
[   0.7426 ] MB2 Applet version 01.00.0000
[   0.7460 ] tegrarcm_v2 --instance /dev/bus/usb/001/010 --chip 0x23 0 --ismb2applet
[   0.7473 ] MB2 Applet version 01.00.0000
[   0.7497 ] Dumping customer Info
[   0.7513 ] tegrarcm_v2 --instance /dev/bus/usb/001/010 --chip 0x23 0 --oem dump bct tmp.bct
[   0.7527 ] MB2 Applet version 01.00.0000
[   0.7549 ] Saved bct in tmp.bct
[   0.7640 ] tegrabct_v2 --brbct tmp.bct --chip 0x23 0 --custinfo /home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/flash_pads10-a2/bootloader/custinfo_out.bin
[   0.7659 ] C[   0.7664 ] ustomer data saved in /home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/flash_pads10-a2/bootloader/custinfo_out.bin successfully
[   0.7665 ] Rebooting to recovery mode
[   0.7681 ] tegrarcm_v2 --instance /dev/bus/usb/001/010 --chip 0x23 0 --ismb2
[   0.7747 ] tegrarcm_v2 --instance /dev/bus/usb/001/010 --chip 0x23 0 --ismb2applet
[   0.7769 ] MB2 Applet version 01.00.0000
[   0.7793 ] Booting to recovery mode
[   0.7809 ] tegrarcm_v2 --instance /dev/bus/usb/001/010 --chip 0x23 0 --reboot recovery
[   0.7821 ] MB2 Applet version 01.00.0000
RCM rebooted. Updating USB instance (old: /dev/bus/usb/001/010)...
The new USB instance is /dev/bus/usb/001/011
Board ID(3701) version(500) sku(0005) revision(R.0)
Chip SKU(00:00:00:D0) ramcode(00:00:00:03) fuselevel(fuselevel_production) board_FAB(500)
Copy /home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/flash_pads10-a2/kernel/dtb/tegra234-p3701-0005-p3737-0000.dtb to /home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/flash_pads10-a2/kernel/dtb/tegra234-p3701-0005-p3737-0000.dtb.rec
copying bctfile(/home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/flash_pads10-a2/bootloader/t186ref/BCT/tegra234-p3701-0005-sdram-l4t.dts)... done.
copying minratchet_config(/home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/flash_pads10-a2/bootloader/t186ref/BCT/tegra234-mb1-bct-ratchet-p3701-0000.dts)... done.
copying pinmux_config(/home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/flash_pads10-a2/bootloader/t186ref/BCT/tegra234-mb1-bct-pinmux-p3701-0000-a04.dtsi)... done.
copying gpioint_config(/home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/flash_pads10-a2/bootloader/t186ref/BCT/tegra234-mb1-bct-gpioint-p3701-0000.dts)... done.
copying pmic_config(/home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/flash_pads10-a2/bootloader/t186ref/BCT/tegra234-mb1-bct-pmic-p3701-0000.dts)... done.
copying pmc_config(/home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/flash_pads10-a2/bootloader/t186ref/BCT/tegra234-mb1-bct-padvoltage-p3701-0000-a04.dtsi)... done.
copying deviceprod_config(/home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/flash_pads10-a2/bootloader/t186ref/BCT/tegra234-mb1-bct-cprod-p3701-0000.dts)... done.
copying prod_config(/home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/flash_pads10-a2/bootloader/t186ref/BCT/tegra234-mb1-bct-prod-p3701-0000.dts)... done.
copying scr_config(/home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/flash_pads10-a2/bootloader/t186ref/BCT/tegra234-mb2-bct-scr-p3701-0000.dts)... done.
copying wb0sdram(/home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/flash_pads10-a2/bootloader/t186ref/BCT/tegra234-p3701-0005-wb0sdram-l4t.dts)... done.
copying bootrom_config(/home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/flash_pads10-a2/bootloader/t186ref/BCT/tegra234-mb1-bct-reset-p3701-0000.dts)... done.
Existing uphylane_config(/home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/flash_pads10-a2/bootloader/tegra234-mb1-bct-uphylane-si.dtsi) reused.
copying dev_params(/home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/flash_pads10-a2/bootloader/t186ref/BCT/tegra234-br-bct-p3701-0000.dts)... done.
copying dev_params_b(/home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/flash_pads10-a2/bootloader/t186ref/BCT/tegra234-br-bct_b-p3701-0000.dts)... done.
copying mb2bct_cfg(/home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/flash_pads10-a2/bootloader/t186ref/BCT/tegra234-mb2-bct-misc-p3701-0000.dts)... done.
Existing pscfwfile(/home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/flash_pads10-a2/bootloader/pscfw_t234_prod.bin) reused.
Existing pscbl1file(/home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/flash_pads10-a2/bootloader/psc_bl1_t234_prod.bin) reused.
Existing mtsmcefile(/home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/flash_pads10-a2/bootloader/mce_flash_o10_cr_prod.bin) reused.
Existing mb2applet(/home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/flash_pads10-a2/bootloader/applet_t234.bin) reused.
Existing bootloader(/home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/flash_pads10-a2/bootloader/mb2_t234.bin) reused.
copying initrd(/home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/flash_pads10-a2/bootloader/l4t_initrd.img)... done.
bl is uefi
Making Boot image... done.
Not signing of boot.img
记录了20+0 的读入
记录了20+0 的写出
20字节已复制,0.000356032 s,56.2 kB/s
./flash.sh: 行 3093: python:未找到命令
Existing sosfile(/home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/flash_pads10-a2/bootloader/mb1_t234_prod.bin) reused.
Existing tegraboot(/home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/flash_pads10-a2/bootloader/mb2_t234.bin) reused.
Existing cpu_bootloader(/home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/flash_pads10-a2/bootloader/mb2_t234.bin) reused.
Existing mb2blfile(/home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/flash_pads10-a2/bootloader/mb2_t234.bin) reused.
Existing xusbfile(/home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/flash_pads10-a2/bootloader/xusb_t234_prod.bin) reused.
Existing dcefile(/home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/flash_pads10-a2/bootloader/display-t234-dce.bin) reused.
Existing nvdecfile(/home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/flash_pads10-a2/bootloader/nvdec_t234_prod.fw) reused.
Existing psc_rf(/home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/flash_pads10-a2/bootloader/psc_rf_t234_prod.bin) reused.
Existing mb2_rf(/home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/flash_pads10-a2/bootloader/mb2rf_t234.bin) reused.
Existing mb1file(/home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/flash_pads10-a2/bootloader/mb1_t234_prod.bin) reused.
Existing bpffile(/home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/flash_pads10-a2/bootloader/bpmp_t234-TE990M-A1_prod.bin) reused.
copying bpfdtbfile(/home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/flash_pads10-a2/bootloader/t186ref/tegra234-bpmp-3701-0005-3737-0000.dtb)... done.
Existing scefile(/home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/flash_pads10-a2/bootloader/camera-rtcpu-sce.img) reused.
Existing camerafw(/home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/flash_pads10-a2/bootloader/camera-rtcpu-t234-rce.img) reused.
Existing apefile(/home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/flash_pads10-a2/bootloader/adsp-fw.bin) reused.
Existing spefile(/home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/flash_pads10-a2/bootloader/spe_t234.bin) reused.
Existing wb0boot(/home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/flash_pads10-a2/bootloader/sc7_t234_prod.bin) reused.
Existing tosfile(/home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/flash_pads10-a2/bootloader/tos-optee_t234.img) reused.
Existing eksfile(/home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/flash_pads10-a2/bootloader/eks_t234.img) reused.
copying dtbfile(/home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/kernel/dtb/tegra234-p3701-0005-p3737-0000.dtb)... done.
Copying nv_boot_control.conf to rootfs
	populating kernel to rootfs... done.
	populating initrd to rootfs... done.
	populating kernel_tegra234-p3701-0005-p3737-0000.dtb to rootfs... done.
Making system.img...
	Setting "FDT /boot/dtb/kernel_tegra234-p3701-0005-p3737-0000.dtb" successfully in the extlinux.conf...done.
	populating rootfs from /home/rqm/work/soc/soc_atlas-kernel-linux-aarch64-20240410-v6.3.5/soc_firmware_v6.3.5/rootfs ...
I would like to ask a few questions for further clarification.
  1. Do you flash the AGX Orin using the SDK manager or by manually flashing it?
  2. Is your Ubuntu running on a physical machine or a virtual environment (e.g., VMware, WSL, VirtualBox)?
  3. Is your AGX Orin a dev kit or a custom carrier board?
