您好,我在使用pwm1时发现orin路径在重启后会发生变化,比如第一次开机pwm1在/sys/class/hwmon2中,重启orin后pwm1会在/sys/class/hwmon4中,再重启又会回到/sys/class/hwmon2中,一直循环这个过程,这是为什么,能否让他固定。
Do you observe the issue on AGX Orin developer kit? We try this on Jetpack 5.1.2 Orin developer kit and the paths are not changed:
root@tegra-ubuntu:/home/nvidia# cat /sys/class/hwmon/hwmon0/name
pwm_tach
root@tegra-ubuntu:/home/nvidia# cat /sys/class/hwmon/hwmon1/name
soctherm_oc
root@tegra-ubuntu:/home/nvidia# cat /sys/class/hwmon/hwmon2/name
pwmfan
root@tegra-ubuntu:/home/nvidia# cat /sys/class/hwmon/hwmon3/name
ina3221
root@tegra-ubuntu:/home/nvidia# cat /sys/class/hwmon/hwmon4/name
ina3221
root@tegra-ubuntu:/home/nvidia# cat /sys/class/hwmon/hwmon5/name
ucsi_source_psy_1_00081
root@tegra-ubuntu:/home/nvidia# cat /sys/class/hwmon/hwmon6/name
ucsi_source_psy_1_00082
root@tegra-ubuntu:/home/nvidia# cat /sys/class/hwmon/hwmon7/name
6810000ethernet00
是的,在agx orin上有这个问题,但我使用的是5.1.1工具包
现在我需要用到的pwm1是在hwmon4中,再开机就会到hwmon2中
test@tegra-ubuntu:/sys/class/hwmon$ ls hwmon0
device name of_node power rpm subsystem uevent
test@tegra-ubuntu:/sys/class/hwmon$ ls hwmon1
device name oc1_event_cnt oc1_throt_en oc2_event_cnt oc2_throt_en oc3_event_cnt oc3_throt_en of_node power subsystem uevent
test@tegra-ubuntu:/sys/class/hwmon$ ls hwmon2
curr1_crit curr2_crit curr3_crit curr4_crit in1_input in3_enable in6_input power subsystem
curr1_crit_alarm curr2_crit_alarm curr3_crit_alarm curr4_crit_alarm in1_label in3_input in7_input samples uevent
curr1_input curr2_input curr3_input curr4_input in2_enable in3_label in7_label shunt1_resistor update_interval
curr1_max curr2_max curr3_max device in2_input in4_input name shunt2_resistor
curr1_max_alarm curr2_max_alarm curr3_max_alarm in1_enable in2_label in5_input of_node shunt3_resistor
test@tegra-ubuntu:/sys/class/hwmon$ ls hwmon3
test@tegra-ubuntu:/sys/class/hwmon$ ls hwmon4
device name of_node power pwm1 subsystem uevent
test@tegra-ubuntu:/sys/class/hwmon$ ls hwmon5
device name power subsystem temp1_input uevent
test@tegra-ubuntu:/sys/class/hwmon$ ls hwmon6
device of_node subsystem temp1_crit_alarm temp1_lcrit temp1_max temp1_min uevent
name power temp1_crit temp1_input temp1_lcrit_alarm temp1_max_alarm temp1_min_alarm
test@tegra-ubuntu:/sys/class/hwmon$ ls hwmon7
test@tegra-ubuntu:/sys/class/hwmon$ ls hwmon8
test@tegra-ubuntu:/sys/class/hwmon$ ls hwmon9
Blockquote
We have discussion with our team and it looks not possible to fix the index. Suggest you check the name to make sure you are reading the data from which monitor.
