- this is demo for camera
- email: cuixiaolei@tztek.com
- date: 20190925
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <assert.h>
#include <getopt.h> /* getopt_long() /
#include <fcntl.h> / low-level i/o */
#include <unistd.h>
#include <errno.h>
#include <time.h>
#include <sys/stat.h>
#include <sys/types.h>
#include <sys/time.h>
#include <sys/mman.h>
#include <sys/ioctl.h>
#include <dlfcn.h>
#include <linux/videodev2.h>
#include <poll.h>
#include <unistd.h>
#include <sched.h>
#include <pthread.h>
#include <GL/glew.h>
#include <GL/glut.h>
#include <cuda_runtime.h>
#include “yuyv2rgb.cuh”
static int index_get = 0;
static int index_pro = 0;
#define CLEAR(x) memset(&(x), 0, sizeof(x))
#define BUFFER_LENGHT 4
int PIXL_WIDTH = 1920;
int PIXL_HEIGHT = 1080;
char *image_yuyv_cuda_ = NULL;
char *image_rgb_cuda_ = NULL;
unsigned char *show_buf;
int pixel_w = PIXL_WIDTH, pixel_h = PIXL_HEIGHT;
int screen_w = 1280, screen_h = 720;
struct buffer {
void *start;
size_t length;
struct buffer *buffers;
unsigned char *yuyv_buf;
static int fd_video = -1;
char dev_name[24] = “/dev/video0”;
int width = PIXL_WIDTH;
int height = PIXL_HEIGHT;
static int v4l2_format = V4L2_PIX_FMT_YUYV;
static int flag_enable_trigger = 0;
static void errno_exit(const char *s)
fprintf(stderr, “%s error %d, %s\n”, s, errno, strerror(errno));
exit(EXIT_FAILURE);
static int xioctl(int fh, int request, void *arg)
int r;
do {
r = ioctl(fh, request, arg);
} while (-1 == r && EINTR == errno);
return r;
const unsigned char uchar_clipping_table = {
0, 0, 0, 0, 0, 0, 0, 0, // -128 - -121
0, 0, 0, 0, 0, 0, 0, 0, // -120 - -113
0, 0, 0, 0, 0, 0, 0, 0, // -112 - -105
0, 0, 0, 0, 0, 0, 0, 0, // -104 - -97
0, 0, 0, 0, 0, 0, 0, 0, // -96 - -89
0, 0, 0, 0, 0, 0, 0, 0, // -88 - -81
0, 0, 0, 0, 0, 0, 0, 0, // -80 - -73
0, 0, 0, 0, 0, 0, 0, 0, // -72 - -65
0, 0, 0, 0, 0, 0, 0, 0, // -64 - -57
0, 0, 0, 0, 0, 0, 0, 0, // -56 - -49
0, 0, 0, 0, 0, 0, 0, 0, // -48 - -41
0, 0, 0, 0, 0, 0, 0, 0, // -40 - -33
0, 0, 0, 0, 0, 0, 0, 0, // -32 - -25
0, 0, 0, 0, 0, 0, 0, 0, // -24 - -17
0, 0, 0, 0, 0, 0, 0, 0, // -16 - -9
0, 0, 0, 0, 0, 0, 0, 0, // -8 - -1
0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30,
31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59,
60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88,
89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113,
114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136,
137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159,
160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182,
183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205,
206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228,
229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251,
252, 253, 254, 255, 255, 255, 255, 255, 255, 255, 255, 255, // 256-263
255, 255, 255, 255, 255, 255, 255, 255, // 264-271
255, 255, 255, 255, 255, 255, 255, 255, // 272-279
255, 255, 255, 255, 255, 255, 255, 255, // 280-287
255, 255, 255, 255, 255, 255, 255, 255, // 288-295
255, 255, 255, 255, 255, 255, 255, 255, // 296-303
255, 255, 255, 255, 255, 255, 255, 255, // 304-311
255, 255, 255, 255, 255, 255, 255, 255, // 312-319
255, 255, 255, 255, 255, 255, 255, 255, // 320-327
255, 255, 255, 255, 255, 255, 255, 255, // 328-335
255, 255, 255, 255, 255, 255, 255, 255, // 336-343
255, 255, 255, 255, 255, 255, 255, 255, // 344-351
255, 255, 255, 255, 255, 255, 255, 255, // 352-359
255, 255, 255, 255, 255, 255, 255, 255, // 360-367
255, 255, 255, 255, 255, 255, 255, 255, // 368-375
255, 255, 255, 255, 255, 255, 255, 255, // 376-383
const int clipping_table_offset = 128;
/** Clip a value to the range 0<val<255. For speed this is done using an
array, so can only cope with numbers in the range -128<val<383.
static unsigned char CLIPVALUE(int val)
// Old method (if)
/ val = val < 0 ? 0 : val; /
/ return val > 255 ? 255 : val; */
// New method (array)
return uchar_clipping_table[val + clipping_table_offset];
static void YUV2RGB(const unsigned char y, const unsigned char u, const unsigned char v, unsigned char r,
unsigned char* g, unsigned char* b)
const int y2 = (int)y;
const int u2 = (int)u - 128;
const int v2 = (int)v - 128;
//std::cerr << “YUV=(”<<y2<<“,”<<u2<<“,”<<v2<<“)”<<std::endl;
// This is the normal YUV conversion, but
// appears to be incorrect for the firewire cameras
/* int r2 = y2 + ( (v2*91947) >> 16); */
/* int g2 = y2 - ( ((u2*22544) + (v2*46793)) >> 16 ); */
/* int b2 = y2 + ( (u2*115999) >> 16); */
// This is an adjusted version (UV spread out a bit)
int r2 = y2 + ((v2 * 37221) >> 15);
int g2 = y2 - (((u2 * 12975) + (v2 * 18949)) >> 15);
int b2 = y2 + ((u2 * 66883) >> 15);
// Cap the values.
*r = CLIPVALUE(r2);
*g = CLIPVALUE(g2);
*b = CLIPVALUE(b2);
static void yuyv2rgb(char* YUV, char* RGB, int NumPixels)
int i, j;
unsigned char y0, y1, u, v;
unsigned char r, g, b;
for (i = 0, j = 0; i < (NumPixels << 1); i += 4, j += 6)
y0 = (unsigned char)YUV[i + 0];
u = (unsigned char)YUV[i + 1];
y1 = (unsigned char)YUV[i + 2];
v = (unsigned char)YUV[i + 3];
YUV2RGB(y0, u, v, &r, &g, &b);
RGB[j + 0] = r;
RGB[j + 1] = g;
RGB[j + 2] = b;
YUV2RGB(y1, u, v, &r, &g, &b);
RGB[j + 3] = r;
RGB[j + 4] = g;
RGB[j + 5] = b;
static void display(void)
glRasterPos3f(-1.0f, 1.0f, 0);
glPixelZoom((float)screen_w/(float)pixel_w, -(float)screen_h/pixel_h);
glDrawPixels(pixel_w, pixel_h, GL_RGB, GL_UNSIGNED_BYTE, show_buf);
glutSwapBuffers();
static void init_cuda(void)
// Number of CUDA devices
int devCount = 0;
cudaGetDeviceCount(&devCount);
printf(“CUDA Device Query…\n”);
printf(“There are %d CUDA devices.\n”, devCount);
if (0 == devCount)
errno_exit("No cuda device found\n");
// Iterate through devices
for (int i = 0; i < devCount; ++i) {
// Get device properties
printf(“\nCUDA Device #%d\n”, i);
cudaDeviceProp devProp;
cudaGetDeviceProperties(&devProp, i);
printDevProp(devProp);
static void process_image(const void* src, int size)
struct timeval ts;
int yuv_size = size * sizeof(char);
gettimeofday(&ts, NULL);
//printf("[%lu.%lu]\tbefore yuyv2rgb computation\n", ts.tv_sec, ts.tv_usec);
yuyv2rgb((char *)src, (char *)show_buf, yuv_size / 3);
//printf("[%lu.%lu]\tyuyv2rgb computation done\n", ts.tv_sec, ts.tv_usec);
//printf("[%lu.%lu]\tprocess image index = %d\n", ts.tv_sec, ts.tv_usec, ++index_pro);
static void process_image_cuda(const void *src, int size)
struct timeval ts;
//printf("[%lu.%lu]\tbefore copy image_data(CPU to GPU)\n", ts.tv_sec, ts.tv_usec);
cudaError_t ret = cudaMemcpy(image_yuyv_cuda_, src, yuv_size, cudaMemcpyHostToDevice);
//printf("[%lu.%lu]\tcopy image_data(CPU to GPU) done\n", ts.tv_sec, ts.tv_usec);
if (cudaSuccess != ret) {
printf("cudaMemcpy fail %d\n", ret);
const int block_size = 256;
const int num_blocks = yuv_size / (4*block_size);
yuyv2rgb_cuda(image_yuyv_cuda_, image_rgb_cuda_, num_blocks, block_size);
int rgb_size = size / 2 * 3 * sizeof(char);
//printf("[%lu.%lu]\tbefore copy image_data(GPU to CPU)\n", ts.tv_sec, ts.tv_usec);
ret = cudaMemcpy(show_buf, image_rgb_cuda_, rgb_size, cudaMemcpyDeviceToHost);
//printf("[%lu.%lu]\tcopy image_data(GPU to CPU) done\n", ts.tv_sec, ts.tv_usec);
//printf("[%lu.%lu]\tcuda process image index = %d\n", ts.tv_sec, ts.tv_usec, ++index_pro);
static void read_frame()
struct timeval ts;
struct v4l2_buffer buf;
CLEAR(buf);
buf.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
buf.memory = V4L2_MEMORY_MMAP;
// get picture
//printf("\n[%lu.%lu]\tbefore get picture\n", ts.tv_sec, ts.tv_usec);
if (-1 == xioctl(fd_video, VIDIOC_DQBUF, &buf))
errno_exit("VIDIOC_DQBUF");
//printf("[%lu.%lu]\tget image index = %d.\n", ts.tv_sec, ts.tv_usec, ++index_get);
//printf("[%lu.%lu]\tget image is ok.\n", ts.tv_sec, ts.tv_usec);
// deal with image data
//process_image(buffers[buf.index].start, buf.bytesused);
process_image_cuda(buffers[buf.index].start, buf.bytesused);
//printf("[%lu.%lu]\tprocess image is ok\n", ts.tv_sec, ts.tv_usec);
display();
if (-1 == xioctl(fd_video, VIDIOC_QBUF, &buf))
errno_exit("VIDIOC_QBUF");
static void mainloop(void)
int ret = 0;
fd_set fds;
struct timeval tv_timeout;
printf("%s\n", __func__);
FD_ZERO(&fds);
FD_SET(fd_video, &fds);
tv_timeout.tv_sec = 3;
tv_timeout.tv_usec = 0;
while(1)
fflush(stdout);
read_frame();
static void stop_capturing(void)
printf(“%s\n”, func);
enum v4l2_buf_type type;
if (-1 == xioctl(fd_video, VIDIOC_STREAMOFF, &type))
errno_exit("VIDIOC_STREAMOFF");
static void start_capturing(void)
unsigned int i;
struct v4l2_control ctrl_mode;
for (i = 0; i < BUFFER_LENGHT; ++i) {
CLEAR(buf);
buf.index = i;
//set streaming on
if (-1 == xioctl(fd_video, VIDIOC_STREAMON, &type))
errno_exit("VIDIOC_STREAMON");
static void uninit_device(void)
unsigned int i;
if (-1 == munmap(buffers[i].start, buffers[i].length))
errno_exit("munmap");
free(buffers);
static void init_mmap(void)
int n_buffers;
struct v4l2_requestbuffers req;
CLEAR(req);
req.count = BUFFER_LENGHT;
req.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
req.memory = V4L2_MEMORY_MMAP;
if (-1 == xioctl(fd_video, VIDIOC_REQBUFS, &req)) {
if (EINVAL == errno) {
fprintf(stderr, "%s does not support "
"memory mapping\n", dev_name);
exit(EXIT_FAILURE);
} else {
errno_exit("VIDIOC_REQBUFS");
if (req.count < 2) {
fprintf(stderr, "Insufficient buffer memory on %s\n",
dev_name);
exit(EXIT_FAILURE);
buffers = (struct buffer*)calloc(req.count, sizeof(*buffers));
if (!buffers) {
fprintf(stderr, "Out of memory\n");
exit(EXIT_FAILURE);
for (n_buffers = 0; n_buffers < req.count; ++n_buffers) {
CLEAR(buf);
buf.index = n_buffers;
if (-1 == xioctl(fd_video, VIDIOC_QUERYBUF, &buf))
errno_exit("VIDIOC_QUERYBUF");
buffers[n_buffers].length = buf.length;
buffers[n_buffers].start =
mmap(NULL /* start anywhere */,
buf.length,
PROT_READ | PROT_WRITE /* required */,
MAP_SHARED /* recommended */,
fd_video, buf.m.offset);
if (MAP_FAILED == buffers[n_buffers].start)
errno_exit("mmap");
static void init_device(void)
struct v4l2_capability cap;
struct v4l2_format fmt;
if (-1 == xioctl(fd_video, VIDIOC_QUERYCAP, &cap)) {
fprintf(stderr, “%s is no V4L2 device\n”,
dev_name);
exit(EXIT_FAILURE);
} else {
errno_exit(“VIDIOC_QUERYCAP”);
if (!(cap.capabilities & V4L2_CAP_VIDEO_CAPTURE)) {
fprintf(stderr, "%s is no video capture device\n",
dev_name);
exit(EXIT_FAILURE);
if (!(cap.capabilities & V4L2_CAP_STREAMING)) {
fprintf(stderr, "%s does not support streaming i/o\n",
dev_name);
exit(EXIT_FAILURE);
CLEAR(fmt);
fmt.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
fmt.fmt.pix.width = width;
fmt.fmt.pix.height = height;
fmt.fmt.pix.pixelformat = v4l2_format;
fmt.fmt.pix.field = V4L2_FIELD_INTERLACED;
if (-1 == xioctl(fd_video, VIDIOC_S_FMT, &fmt))
errno_exit("VIDIOC_S_FMT");
usleep(10000);
init_mmap();
static void close_device(void)
if (-1 == close(fd_video))
errno_exit(“close fd_video”);
fd_video = -1;
static void open_device(void)
fd_video = open(dev_name, O_RDWR /* required / /| O_NONBLOCK*/, 0);
if (-1 == fd_video) {
fprintf(stderr, "Cannot open '%s': %d, %s\n",
dev_name, errno, strerror(errno));
exit(EXIT_FAILURE);
int str2int(const char* str)
int temp = 0;
const char* p = str;
if(str == NULL) return 0;
if(*str == ‘-’ || *str == ‘+’)
str ++;
while( *str != 0)
if( *str < ‘0’ || str > ‘9’)
break;
temp = temp10 +(*str -‘0’);
str ++;
if(*p == ‘-’)
temp = -temp;
return temp;
int main(int argc, char *argv)
//printf(“./camera_show_cuda /dev/video0 1920 1080\r\n”);
//printf(“./camera_show_cuda /dev/video0 1280 720\r\n”);
//printf(“./camera_show_cuda /dev/video0 3840 2160\r\n”);
//printf(“%d\r\n”, argc);
// for(int i = 0; i<argc;i++){
// printf(“argv[%d] = %s \r\n”, i, argv[i]);
int width_l = 0 , height_l = 0;
width_l = str2int(argv[2]);
height_l = str2int(argv[3]);
// printf(“int argv[2]=%d\r\n”, width_l);
// printf(“int argv[3]=%d\r\n”, height_l);
PIXL_WIDTH = width_l;
PIXL_HEIGHT = height_l;
width = PIXL_WIDTH;
pixel_w = PIXL_WIDTH;
strcpy(dev_name, argv[1]);
// printf(“dev_name= %s\r\n”, dev_name);
show_buf = (unsigned char )malloc(PIXL_WIDTHPIXL_HEIGHT3);
memset(show_buf, 0, PIXL_WIDTHPIXL_HEIGHT3);
yuyv_buf = (unsigned char )malloc(PIXL_WIDTHPIXL_HEIGHT3);
memset(yuyv_buf, 0, PIXL_WIDTHPIXL_HEIGHT3);
//CUDA init
init_cuda();
//GLUT init
glutInit(&argc, argv);
glutInitDisplayMode(GLUT_DOUBLE | GLUT_RGB);
glutInitWindowPosition(0, 0);
glutInitWindowSize(screen_w, screen_h);
glutCreateWindow("Simplest Video Play OpenGL");
glutDisplayFunc(&display);
open_device();
init_device();
start_capturing();
//Allocate cuda memory for device
int rgb_image_size = width * height * 3;
int yuyv_image_size = width * height * 2;
cudaError_t ret = cudaMalloc((void **)&image_yuyv_cuda_, yuyv_image_size * sizeof(char));
printf("Fail to allocate cuda memory %d\n", ret);
exit(EXIT_FAILURE);
ret = cudaMemset((void *)image_yuyv_cuda_, 0, yuyv_image_size * sizeof(char));
printf("Fail to set cuda memory1 %d\n", ret);
exit(EXIT_FAILURE);
ret = cudaMalloc((void **)&image_rgb_cuda_, rgb_image_size * sizeof(char));
exit(EXIT_FAILURE);
ret = cudaMemset((void *)image_rgb_cuda_, 0, rgb_image_size * sizeof(char));
printf("Fail to set cuda2 memory %d\n", ret);
exit(EXIT_FAILURE);
mainloop();
stop_capturing();
uninit_device();
free(show_buf);
free(yuyv_buf);
close_device();
return 0;
