Hi Nvidia Support, I need help getting an unmodified L4T 35.1 kernel built from Nvidia source to run on a new Orin. I’ve followed the instructions here:
https://docs.nvidia.com/jetson/archives/r35.1/DeveloperGuide/text/SD/Kernel/KernelCustomization.html#to-build-the-kernel
I’ve downloaded L4T 35.1, installed the bootlin gcc 9.3 toolchain, built a stock, “as-shipped” kernel from the L4T 35.1 public_sources.tbz2 archive and this kernel fails to boot. No device tree changes. No changes to tegra_defconfig.
AGX Orin devkit, p3737, purchased off Amazon. Flashed with Jetpack 5.0.2 to set up a base line. No changes. Graphical/desktop disabled as it is unneeded. Serial console to the shell is more than adequate. AGX Orin devkit info:
Serial No 1422122016757
Part No 945-13730-00000-000
The bootlin-gcc-93 kernel image is 33262080 bytes.
The Jetpack 5.0.2 installed kernel image is 33657344 bytes.
That seems to suggest some defconfg change didn’t get pushed into the release source.
I’ve edited /boot/extlinux/extlinux.conf, and tested booting kernel options 0 or 1 using the default Jetpack 5.0.2 installed kernel. Both 0 and 1 boot options work. No issue with extlinux.conf. It appears to work fine. Again, no device tree changes, using the as-shipped device tree.
Serial port /dev/ttyACM0 shows Orin is very unhappy in booting this stock kernel. See below. The console hangs after this output.
Some help would be appreciated.
L4TLauncher: Attempting GRUB Boot
L4TLauncher: Attempting Direct Boot
L4T boot options
0: primary kernel
1: rcarter kernel
Press 0-1 to boot selection within 3.0 seconds.
Press any other key to boot default (Option: 0)
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services and installing virtual address map...
��I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Secondary CPU 4 initializing
I/TC: Secondary CPU 4 switching to normal world boot
I/TC: Secondary CPU 5 initializing
I/TC: Secondary CPU 5 switching to normal world boot
I/TC: Secondary CPU 6 initializing
I/TC: Secondary CPU 6 switching to normal world boot
I/TC: Secondary CPU 7 initializing
I/TC: Secondary CPU 7 switching to normal world boot
I/TC: Secondary CPU 8 initializing
I/TC: Secondary CPU 8 switching to normal world boot
I/TC: Secondary CPU 9 initializing
I/TC: Secondary CPU 9 switching to normal world boot
I/TC: Secondary CPU 10 initializing
I/TC: Secondary CPU 10 switching to normal world boot
I/TC: Secondary CPU 11 initializing
I/TC: Secondary CPU 11 switching to normal world boot
��debugfs initialized
WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpusysclk
WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpc1clk
WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpc0clk
