Orin 平台,Jetpack 5.1.3, 高负载运行一段时间(10天左右)出现 [kworker/6:0+pm] 进程cpu占用 100%,内核跟踪发现系统卡在 nvgpu 驱动中。路径如下:gk20a_pm_runtime_suspend()
gk20a_pm_prepare_poweroff()
nvgpu_hide_usermode_for_poweroff()
alter_usermode_mappings()
最后卡在alter_usermode_mappings() 这个函数中永远无法退出
If the device cannot be flashed/booted, please refer to the page to get uart log from the device:
Jetson/General debug - eLinux.org
And get logs of host PC and Jetson device for reference. If you are using custom board, you can compare uart log of developer kit and custom board to get more information.
Also please check FAQs:
Jetson AGX Orin FAQ
If possible, we would suggest follow quick start in developer guide to re-flash the system:
Quick Start — NVIDIA Jetson Linux Developer Guide 1 documentation
And see if the issue still persists on a clean-flashed system.
May I know what kind of application you’re running on device?
Tensorflow
please try on jetpack5.1.4 and capture UART log when error happneed.
我们已经定位到问题了,就卡在nvgup 驱动的 alter_usermode_mappings()这个函数中。论坛中也有一个类似问题的帖子。
Yes, thank you for locating. But that does not matter now. You should just provide the method to reproduce first.
您看 Jetson TX2: kworker CPU usage at 100% 这个帖子 也提到了类似问题。我们是在用 tensorflow做仿真,连续工作10几天出现的,并且已经出现了好几次。出现后只能重启。
static void alter_usermode_mappings(struct gk20a *g, bool poweroff)
struct gk20a_ctrl_priv *priv;
struct nvgpu_os_linux *l = nvgpu_os_linux_from_gk20a(g);
int err = 0;
do {
nvgpu_mutex_acquire(&l->ctrl_privs_lock);
nvgpu_list_for_each_entry(priv, &l->ctrl_privs,
gk20a_ctrl_priv, list) {
err = alter_usermode_mapping(g, priv, poweroff);
if (err != 0) {
break;
nvgpu_mutex_release(&l->ctrl_privs_lock);
if (err == -EBUSY) {
nvgpu_log_info(g, "ctrl_privs_lock lock contended. retry altering usermode mappings");
nvgpu_udelay(10);
} else if (err != 0) {
nvgpu_err(g, "can't alter usermode mapping. err = %d", err);
} while (err == -EBUSY);
出问题时,nvgpu 驱动的这个函数 do while 无法返回
首先謝謝你的分析. 但是請你要了解一下
你貼的是一個6年前在兩個世代以前SoC的post. 基本上軟體已經有很多差別. 不能保證完全是同一件事情.
基本上你現在要做的就是提供一個穩定的方法給我們讓我們在NV devkit上能複製出問題. 關於你的tensorflow usecase, 請問能否直接提供sample. 如果你不想提供的話, 也可以提供任何其他方法. 只要能複製出問題就行.
我们跟踪到 pm 负责电源管理的 kworker,出问题的时候,是从
static struct platform_driver gk20a_driver = {
.probe = gk20a_probe,
.remove = __exit_p(gk20a_remove),
.shutdown = gk20a_pm_shutdown,
.driver = {
.owner = THIS_MODULE,
.name = “gk20a”,
.probe_type = PROBE_PREFER_ASYNCHRONOUS,
#ifdef CONFIG_OF
.of_match_table = tegra_gk20a_of_match,
endif
#ifdef CONFIG_PM
.pm = &gk20a_pm_ops,
endif
.suppress_bind_attrs = true,
从这里 .pm = &gk20a_pm_ops, 这里进入。 出问题时,它尝试 poweroff,但是卡在alter_usermode_mappings 函数中,最终导致 pm kworker 卡死 cpu占用 100%
好的 謝謝. 可以請你先回答我的問題嗎?
我们也没有简明的复现方法,出现时间也在 7-10天不等。但肯定的是,问题是在 高负载,高内存 情况下才会产生。
能請你大概說明一下你的高負載是怎樣的高負載嗎? CPU/GPU/EMC全滿跑10天?
請問power mode使用哪個狀況在跑呢?
Please try the stress test on your board and see if the issue is present:
单纯的 高cpu负载 高内存可能还不行, 因为问题出在 nvgpu 驱动里,可能跟 高 gpu 负载有关
问题出在 nvgpu 驱动中,高cpu负载 高内存 只是诱发条件。
static int alter_usermode_mapping(struct gk20a *g,
struct gk20a_ctrl_priv *priv,
bool poweroff)
* We use trylock due to lock inversion: we need to acquire
* mmap_lock while holding ctrl_privs_lock. usermode_vma_close
* does it in reverse order. Trylock is a way to avoid deadlock.
#if LINUX_VERSION_CODE >= KERNEL_VERSION(5, 8, 0)
if (!mmap_write_trylock(vma->vm_mm)) {
#else
if (!down_write_trylock(&vma->vm_mm->mmap_sem)) {
endif
return -EBUSY;
return err;
我们深入分析,极度怀疑是 这里
mmap_write_trylock() 一直返回 -EBUSY 导致
We are not able to comment further. Please share a method to reproduce the issue so that we can check.
You might find this to be quite useful in getting more specific information:
https://medium.com/@boutnaru/the-linux-process-journey-kworker-f947634da73
Note that a kworker thread is from a software driver interaction, and not directly related to a hardware driver. Quite often triggering a hardware driver results in spawning one or more software IRQs (which is what a kworker thread is servicing). It might be useful to find out what that kworker is actually doing, and the above URL can show you a way to find out. It is finer-grained information, although you will need to sort through that information.
你们核查一下我们跟踪到的函数呢?
非常难于复现。 看起来是 高CPU占用 高内存占用, 高 gpu占用的情况下发生的。
