orin的万兆外挂spi flash(W25Q40EW),需要烧录固件,但将开发板flash拆下后装到自制版,ifconfig里有eth1加载,但无法ping通,测量cs一直为高没有通信,硬件检查连接也没有问题,请问是什么原因?
eth1 dmesg打印如下:
root@tegra-ubuntu:/home/nvidia# dmesg | grep eth
[ 0.000000] psci: probing for conduit method from DT.
[ 4.511140] usbcore: registered new interface driver cdc_ether
[ 7.434308] optee: probing for conduit method.
[ 13.479318] nvethernet 6810000.ethernet: Adding to iommu group 51
[ 13.485930] nvethernet 6810000.ethernet: failed to read skip mac reset flag, default 0
[ 13.494085] nvethernet 6810000.ethernet: failed to read MDIO address
[ 13.500634] nvethernet 6810000.ethernet: setting to default DMA bit mask
[ 13.507547] nvethernet 6810000.ethernet: failed to read UPHY GBE mode- default to 10G
[ 13.908609] nvethernet 6810000.ethernet: Ethernet MAC address: 48:b0:2d:e7:15:10
[ 13.916571] nvethernet 6810000.ethernet: macsec param in DT is missing or disabled
[ 13.924364] nvethernet 6810000.ethernet: Macsec not supported/Not enabled in DT
[ 13.936881] nvethernet 6810000.ethernet: eth0 (HW ver: 31) created with 10 DMA channels
[ 18.885643] using random self ethernet address
[ 18.890385] using random host ethernet address
[ 19.741628] using random self ethernet address
[ 19.746229] using random host ethernet address
[ 21.672863] Aquantia AQR113C 6810000.ethernet:00: aqr107_wait_reset_complete failed: -110
[ 21.776182] Aquantia AQR113C 6810000.ethernet:00: No AQR phy_mode setting in DT
开发板的flash应该是已经烧录过固件的?为什么移过去还是不行?请问有人吗
Sorry for the late response.
