hi all:
we designed a board.In our board, the MGBE UPHY6 port is directly connnct to switch BCM89586M with 10Gbe speed.it has some error. the 156.25M crystal oscillator works normally.
here is our dts file:
ethernet@6810000 {
compatible = “nvidia,nvmgbe”;
status = “okay”;
nvidia,disable-aspm-states = <0x0>;
nvidia,uphy-gbe-mode = <1>;
nvidia,phy-iface-mode = <0>;
nvidia,mac-addr-idx = <0>;
nvidia,pause_frames = <0>;
phy-mode = “10gbase-r”;
nvidia,max-platform-mtu = <16383>;
fixed-link {
speed = <10000>;
full-duplex;
here is the result of “sudo dmesg” | grep 681
[ 15.244409] nvethernet ethernet@6810000: failed to get number of DMA channels (-22)
[ 15.252304] nvethernet ethernet@6810000: Setting number of channels to one
[ 15.259389] nvethernet ethernet@6810000: failed to get number of MTL queueus (-22)
[ 15.267177] nvethernet ethernet@6810000: Setting number of queues to one
[ 15.274077] nvethernet ethernet@6810000: failed to read skip mac reset flag, default 0
[ 15.282242] nvethernet ethernet@6810000: failed to read MDIO address
[ 15.288793] nvethernet ethernet@6810000: setting default PTP clk rate as 312.5MHz
[ 15.296501] nvethernet ethernet@6810000: setting default promiscuous mode supported
[ 15.304393] nvethernet ethernet@6810000: Failed to read nvida,pause_frames, so setting to default support as disable
[ 15.315230] nvethernet ethernet@6810000: setting to default DMA bit mask
[ 15.322135] nvethernet ethernet@6810000: failed to read MTL Queue numbers
[ 15.329129] nvethernet ethernet@6810000: setting default MTL queue: 0
[ 15.335768] nvethernet ethernet@6810000: set default TXQ to TC mapping
[ 15.342477] nvethernet ethernet@6810000: Setting default PTP RX queue
[ 15.349117] nvethernet ethernet@6810000: failed to read DMA channel numbers
[ 15.356276] nvethernet ethernet@6810000: setting default DMA channel: 0
[ 15.363081] nvethernet ethernet@6810000: failed to read rxq enable ctrl
[ 15.369888] nvethernet ethernet@6810000: failed to parse DT
[ 15.375641] nvethernet: probe of ethernet@6810000 failed with error -22
