Orin nano 8G with official devkit tingmed out during falshing
When flashing Orin nano 8G with devkit using SDK manager, the process always timed out at the same place.
Device: Orin nano 8G + nvidia devkit
Host PC: win11 + SDK manager 2.4.1.13536
Jetpack: official 7.2.1 downloaded from SDK manager
When switching the core to a Orin nx 16G and flashing with exactly the same process, the process can be done successfully. The issue only happened on Orin Nano 8G.
I also tried to flash the official Jetpack 6.2.1 on the same devkit from a native Ubuntu 22.04 host PC, but I got exactly same result, and the issue never occurs on Orin NX.
The log generated by the SDK manager and the UART log are attached.
UART consel log.txt (18.8 KB)
SDKM_logs_JetPack_7.2.1_Linux_for_Jetson_Orin_Nano_8GB_Direct_Flash_2026-08-25_18-19-56.zip (2.6 MB)
Do anyone know how to solve this problem?
Please proceed with the RMA process.
Did this Orin Nano ever get flashed by host before?
no, It’s brand new
Do you have other Orin Nano on your side that could confirm if your host PC really could flash it?
or do you have other native ubuntu host to try? I notice your PC here is a Windows one.
I have another host PC that is running Ubuntu 22.04, and I tried to flash the same Orin Nano with the CLI tool. I received the same result.
the command I use is
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1   -c tools/kernel_flash/flash_l4t_t234_nvme.xml -p "-c bootloader/generic/cfg/flash_t234_qspi.xml"   --showlogs --network usb0 jetson-orin-nano-devkit internal
I also have a Orin NX 16G core module, I replaced it with the Orin Nano core and tried to flash from both Windows and Ubuntu, both falshing worked. The I put the Orin Nano 8G core module back to the devkit, flashing following the same step, and faild again. All failling cases are terminated at the same point, which is the “Waiting for target to boot-up…” and then “Error: Timeout”
  1. Please share the full host side log when you run manual command.
  2. Please also attach the UART log from device.
  1. Is it possible to flash with Jetpack6.x?
SerialLog_20260827_170244.txt (36.0 KB)
host-pc_log.txt (299.9 KB)
Here is the log when I tried to flash Jetpack 6.2.1 from Ubuntu 22.04 on the Orin Nano 8g. I can flash this setup successfuly with the Orin NX 16g core module. It only failed with the Orin Nano 8g core module.
ok. please RMA this module.
