Orin Nano 8gb RIVA Docker fails to load (network issue in logs)
Jetpack 5.1.2
8gb Orin Nano
CUDA 11.4.315
cuDNN 8.6.0.166
TensorRT 8.5.2.2
VPI 2.3.9
Vulkan 1.3.204
OpenCV 4.5.4 with CUDA YES
L4T 35.4.1
Interfaces:
wlan0: 192.168.50.69
docker0: 172.17.0.1
# GPU family of target platform. Supported values: tegra, non-tegra
riva_target_gpu_family="tegra"
# Name of tegra platform that is being used. Supported tegra platforms: orin, xavier
riva_tegra_platform="orin"
# Enable or Disable Riva Services
# For any language other than en-US: service_enabled_nlp must be set to false
service_enabled_asr=true
service_enabled_nlp=false
service_enabled_tts=false
service_enabled_nmt=false
# Configure translation services
# Text-to-Text translation (T2T):
# - service_enabled_nmt must be set to true
# - Uncomment desired model for source and target languages in models_nmt field
# Speech-to-Text translation (S2T):
# - service_enabled_asr, service_enabled_nmt must be set to true
# - Set language code of input speech in the asr_language_code field
# Speech-to-Speech translation (S2S):
# - service_enabled_asr, service_enabled_nmt, service_enabled_tts must be set to true
# - Set language code of output speech in the tts_language_code field
# Enable Riva Enterprise
# If enrolled in Enterprise, enable Riva Enterprise by setting configuration
# here. You must explicitly acknowledge you have read and agree to the EULA.
# RIVA_API_KEY=<ngc api key>
# RIVA_API_NGC_ORG=<ngc organization>
# RIVA_EULA=accept
# Language code to fetch ASR models of a specific language
# Supported language codes: ar-AR, en-US, en-GB, de-DE, es-ES, es-US, fr-FR, hi-IN, it-IT, ja-JP, ru-RU, ko-KR, pt-BR, zh-CN, es-en-US, ja-en-JP
# For multiple languages enter space separated language codes.
asr_language_code=("en-US")
# ASR acoustic model architecture
# Supported values are: conformer, conformer_xl (en-US + amd64 only), citrinet_1024, citrinet_256 (en-US + arm64 only), jasper (en-US + amd64 only), quartznet (en-US + amd64 only)
asr_acoustic_model=("conformer")
# ASR acoustic model architecture variant
# Supported values for the architecture are:
# conformer: unified(de-DE, ja-JP and zh-CN only), ml_cs(es-en-US only), unified_ml_cs(ja-en-JP only)
# For the default model, keep the field empty
asr_acoustic_model_variant=("")
# ASR decoder type to be used
# If you'd like to use greedy decoder for ASR instead of flashlight/os2s decoder then set the below $use_asr_greedy_decoder to true
use_asr_greedy_decoder=false
# Language code to fetch TTS models of a specific language
# Supported language codes: en-US, es-ES, it-IT, de-DE
tts_language_code=("en-US")
# Specify one or more GPUs to use
# specifying more than one GPU is currently an experimental feature, and may result in undefined behaviours.
gpus_to_use="device=0"
# Specify the encryption key to use to deploy models
MODEL_DEPLOY_KEY="tlt_encode"
# Locations to use for storing models artifacts
# If an absolute path is specified, the data will be written to that location
# Otherwise, a Docker volume will be used (default).
# riva_init.sh will create a `rmir` and `models` directory in the volume or
# path specified.
# RMIR ($riva_model_loc/rmir)
# Riva uses an intermediate representation (RMIR) for models
# that are ready to deploy but not yet fully optimized for deployment. Pretrained
# versions can be obtained from NGC (by specifying NGC models below) and will be
# downloaded to $riva_model_loc/rmir by `riva_init.sh`
# Custom models produced by NeMo or TLT and prepared using riva-build
# may also be copied manually to this location $(riva_model_loc/rmir).
# Models ($riva_model_loc/models)
# During the riva_init process, the RMIR files in $riva_model_loc/rmir
# are inspected and optimized for deployment. The optimized versions are
# stored in $riva_model_loc/models. The riva server exclusively uses these
# optimized versions.
riva_model_loc="riva-model-repo"
if [[ $riva_target_gpu_family == "tegra" ]]; then
    riva_model_loc="`pwd`/model_repository"
fi
# The default RMIRs are downloaded from NGC by default in the above $riva_rmir_loc directory
# If you'd like to skip the download from NGC and use the existing RMIRs in the $riva_rmir_loc
# then set the below $use_existing_rmirs flag to true. You can also deploy your set of custom
# RMIRs by keeping them in the riva_rmir_loc dir and use this quickstart script with the
# below flag to deploy them all together.
use_existing_rmirs=false
# Ports to expose for Riva services
riva_speech_api_port="50051"
# NGC orgs
riva_ngc_org="nvidia"
riva_ngc_team="riva"
riva_ngc_image_version="2.13.0"
riva_ngc_model_version="2.13.0"
########## ASR MODELS ##########
models_asr=()
for lang_code in ${asr_language_code[@]}; do
    modified_lang_code="${lang_code//-/_}"
    modified_lang_code=${modified_lang_code,,}
    decoder=""
    if [ "$use_asr_greedy_decoder" = true ]; then
      decoder="_gre"
    fi
    if [[ ${asr_acoustic_model_variant} != "" ]]; then
      if [[ ${asr_acoustic_model} == "conformer" && ${asr_acoustic_model_variant} != "unified" && ${asr_acoustic_model_variant} != "ml_cs" && ${asr_acoustic_model_variant} != "unified_ml_cs" ]]; then
        echo "Valid variants for Conformer are: unified, ml_cs and unified_ml_cs."
        exit 1
      elif [[ ${asr_acoustic_model} != "conformer" ]]; then
        echo "Invalid variant for ${asr_acoustic_model}."
        exit 1
      fi
      asr_acoustic_model_variant="_${asr_acoustic_model_variant}"
    fi
    if [[ ${asr_acoustic_model} == "conformer_xl" && ${lang_code} != "en-US" ]]; then
      echo "Conformer-XL acoustic model is only available for language code en-US."
      exit 1
    fi
    if [[ ${asr_acoustic_model_variant} == "_unified" && ${lang_code} != "de-DE" && ${lang_code} != "ja-JP" && ${lang_code} != "zh-CN" ]]; then
      echo "Unified Conformer acoustic model is only available for language code de-DE, ja-JP and zh-CN."
      exit 1
    fi
    if [[ ${asr_acoustic_model_variant} == "_ml_cs" && ${lang_code} != "es-en-US" ]]; then
      echo "Multilingual Code Switch Conformer acoustic model is only available for language code es-en-US."
      exit 1
    fi
    if [[ ${asr_acoustic_model_variant} == "_unified_ml_cs" && ${lang_code} != "ja-en-JP" ]]; then
      echo "Unified Multilingual Code Switch Conformer acoustic model is only available for language code ja-en-JP."
      exit 1
    fi
      if [[ ${asr_acoustic_model} == "jasper" || \
            ${asr_acoustic_model} == "quartznet" || \
            ${asr_acoustic_model} == "conformer_xl" ]]; then
          echo "Conformer-XL, Jasper and Quartznet models are not available for arm64 architecture"
          exit 1
      fi
      if [[ ${asr_acoustic_model} == "citrinet_256" && ${lang_code} != "en-US" ]]; then
        echo "For arm64 architecture, citrinet_256 acoustic model is only available for language code en-US."
        exit 1
      fi
      models_asr+=(
      ### Streaming w/ CPU decoder, best latency configuration
          "${riva_ngc_org}/${riva_ngc_team}/models_asr_${asr_acoustic_model}${asr_acoustic_model_variant}_${modified_lang_code}_str:${riva_ngc_model_version}-${riva_target_gpu_family}-${riva_tegra_platform}"
### Offline w/ CPU decoder
      #    "${riva_ngc_org}/${riva_ngc_team}/rmir_asr_${asr_acoustic_model}${asr_acoustic_model_variant}_${modified_lang_code}_ofl${decoder}:${riva_ngc_model_version}"
    else
      if [[ ${asr_acoustic_model} != "conformer" && \
            ${asr_acoustic_model} != "conformer_xl" && \
            ${asr_acoustic_model} != "citrinet_1024" && \
            ${asr_acoustic_model} != "jasper" && \
            ${asr_acoustic_model} != "quartznet" ]]; then
        echo "For amd64 architecture, valid acoustic models are conformer, conformer_xl, citrinet_1024, jasper and quartznet."
        exit 1
      fi
      if [[ (${asr_acoustic_model} == "jasper" || \
            ${asr_acoustic_model} == "quartznet") && \
        echo "jasper and quartznet acoustic models are only available for language code en-US."
        exit 1
      fi
      models_asr+=(
          "${riva_ngc_org}/${riva_ngc_team}/rmir_asr_${asr_acoustic_model}${asr_acoustic_model_variant}_${modified_lang_code}_str${decoder}:${riva_ngc_model_version}"
      ### Streaming w/ CPU decoder, best throughput configuration
      #    "${riva_ngc_org}/${riva_ngc_team}/rmir_asr_${asr_acoustic_model}${asr_acoustic_model_variant}_${modified_lang_code}_str_thr${decoder}:${riva_ngc_model_version}"
    fi
    ### Punctuation model
    if [[ ${asr_acoustic_model_variant} != "_unified" && ${asr_acoustic_model_variant} != "_unified_ml_cs" ]]; then
      pnc_lang=$(echo $modified_lang_code | cut -d "_" -f 1)
      pnc_region=${modified_lang_code##*_}
      modified_lang_code=${pnc_lang}_${pnc_region}
        models_asr+=(
            "${riva_ngc_org}/${riva_ngc_team}/models_nlp_punctuation_bert_base_${modified_lang_code}:${riva_ngc_model_version}-${riva_target_gpu_family}-${riva_tegra_platform}"
      else
        models_asr+=(
            "${riva_ngc_org}/${riva_ngc_team}/rmir_nlp_punctuation_bert_base_${modified_lang_code}:${riva_ngc_model_version}"
      fi
    fi
done
when trying to load the docker container with bash riva_start.sh i get the following errors in the logs:
$ docker logs riva-speech
/opt/riva/bin/start-riva: line 10: curl: command not found
/opt/riva/bin/start-riva: line 11: [: -ne: unary operator expected
  > Triton server is ready...
I0912 19:05:46.787671    22 riva_server.cc:126] Using Insecure Server Credentials
E0912 19:05:46.796759    22 model_registry.cc:288] error: unable to get server status: failed to connect to all addresses; last error: UNKNOWN: ipv4:127.0.0.1:8001: Failed to connect to remote host: Connection refused
I0912 19:05:46.954185 20 pinned_memory_manager.cc:240] Pinned memory pool is created at '0x203b8e000' with size 268435456
I0912 19:05:46.954640 20 cuda_memory_manager.cc:105] CUDA memory pool is created on device 0 with size 1000000000
I0912 19:05:47.271525 20 model_lifecycle.cc:459] loading: conformer-en-US-asr-streaming-ctc-decoder-cpu-streaming:1
I0912 19:05:47.271637 20 model_lifecycle.cc:459] loading: conformer-en-US-asr-streaming-endpointing-streaming:1
I0912 19:05:47.271713 20 model_lifecycle.cc:459] loading: conformer-en-US-asr-streaming-feature-extractor-streaming:1
I0912 19:05:47.271786 20 model_lifecycle.cc:459] loading: riva-punctuation-en-US:1
I0912 19:05:47.271841 20 model_lifecycle.cc:459] loading: riva-trt-conformer-en-US-asr-streaming-am-streaming:1
I0912 19:05:47.272042 20 model_lifecycle.cc:459] loading: riva-trt-riva-punctuation-en-US-nn-bert-base-uncased:1
I0912 19:05:47.403735 20 tensorrt.cc:5444] TRITONBACKEND_Initialize: tensorrt
I0912 19:05:47.403858 20 tensorrt.cc:5454] Triton TRITONBACKEND API version: 1.10
I0912 19:05:47.403870 20 tensorrt.cc:5460] 'tensorrt' TRITONBACKEND API version: 1.10
I0912 19:05:47.403879 20 tensorrt.cc:5488] backend configuration:
{"cmdline":{"auto-complete-config":"false","min-compute-capability":"5.300000","backend-directory":"/opt/tritonserver/backends","default-max-batch-size":"4"}}
I0912 19:05:48.330135 20 tensorrt.cc:5578] TRITONBACKEND_ModelInitialize: riva-trt-conformer-en-US-asr-streaming-am-streaming (version 1)
I0912 19:05:48.331957 20 tensorrt.cc:5627] TRITONBACKEND_ModelInstanceInitialize: riva-trt-conformer-en-US-asr-streaming-am-streaming_0 (GPU device 0)
I0912 19:05:50.092374 20 logging.cc:49] Loaded engine size: 285 MiB
W0912 19:05:50.227172 20 logging.cc:46] Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
I0912 19:05:54.173549 20 logging.cc:49] [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +535, GPU +593, now: CPU 1455, GPU 7227 (MiB)
I0912 19:05:54.192756 20 logging.cc:49] [MemUsageChange] TensorRT-managed allocation in engine deserialization: CPU +0, GPU +281, now: CPU 0, GPU 281 (MiB)
I0912 19:05:54.294400 20 logging.cc:49] [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +0, GPU +7, now: CPU 883, GPU 6699 (MiB)
I0912 19:05:54.863133 20 logging.cc:49] [MemUsageChange] TensorRT-managed allocation in IExecutionContext creation: CPU +0, GPU +11, now: CPU 0, GPU 292 (MiB)
I0912 19:05:55.081385 20 tensorrt.cc:1547] Created instance riva-trt-conformer-en-US-asr-streaming-am-streaming_0 on GPU 0 with stream priority 0 and optimization profile default[0];
E0912 19:05:56.801369    22 model_registry.cc:288] error: unable to get server status: failed to connect to all addresses; last error: UNKNOWN: ipv4:127.0.0.1:8001: Failed to connect to remote host: Connection refused
E0912 19:06:06.801837    22 model_registry.cc:288] error: unable to get server status: failed to connect to all addresses; last error: UNKNOWN: ipv4:127.0.0.1:8001: Failed to connect to remote host: Connection refused
E0912 19:06:16.802244    22 model_registry.cc:288] error: unable to get server status: failed to connect to all addresses; last error: UNKNOWN: ipv4:127.0.0.1:8001: Failed to connect to remote host: Connection refused
E0912 19:06:26.802716    22 model_registry.cc:288] error: unable to get server status: failed to connect to all addresses; last error: UNKNOWN: ipv4:127.0.0.1:8001: Failed to connect to remote host: Connection refused
E0912 19:06:36.811107    22 model_registry.cc:288] error: unable to get server status: failed to connect to all addresses; last error: UNKNOWN: ipv4:127.0.0.1:8001: Failed to connect to remote host: Connection refused
E0912 19:06:46.811460    22 model_registry.cc:288] error: unable to get server status: failed to connect to all addresses; last error: UNKNOWN: ipv4:127.0.0.1:8001: Failed to connect to remote host: Connection refused
E0912 19:06:56.811830    22 model_registry.cc:288] error: unable to get server status: failed to connect to all addresses; last error: UNKNOWN: ipv4:127.0.0.1:8001: Failed to connect to remote host: Connection refused
I0912 19:06:58.293629 20 model_lifecycle.cc:693] successfully loaded 'riva-trt-conformer-en-US-asr-streaming-am-streaming' version 1
I0912 19:06:58.300656 20 feature-extractor.cc:415] TRITONBACKEND_ModelInitialize: conformer-en-US-asr-streaming-feature-extractor-streaming (version 1)
I0912 19:06:58.348831 20 backend_model.cc:303] model configuration:
    "name": "conformer-en-US-asr-streaming-feature-extractor-streaming",
    "platform": "",
    "backend": "riva_asr_features",
    "version_policy": {
        "latest": {
            "num_versions": 1
    "max_batch_size": 1024,
    "input": [
            "name": "AUDIO_SIGNAL",
            "data_type": "TYPE_FP32",
            "format": "FORMAT_NONE",
            "dims": [
                -1
            "is_shape_tensor": false,
            "allow_ragged_batch": false,
            "optional": false
            "name": "SAMPLE_RATE",
            "data_type": "TYPE_UINT32",
            "dims": [
                1
            "optional": false
    "output": [
            "name": "AUDIO_FEATURES",
            "dims": [
                80,
                -1
            "label_filename": "",
            "name": "AUDIO_PROCESSED",
            "dims": [
                1
            "name": "AUDIO_FEATURES_LENGTH",
            "data_type": "TYPE_INT32",
            "dims": [
                1
    "batch_input": [],
    "batch_output": [],
    "optimization": {
        "graph": {
            "level": 0
        "priority": "PRIORITY_DEFAULT",
        "cuda": {
            "graphs": false,
            "busy_wait_events": false,
            "graph_spec": [],
            "output_copy_stream": true
        "input_pinned_memory": {
            "enable": true
        "output_pinned_memory": {
            "enable": true
        "gather_kernel_buffer_threshold": 0,
        "eager_batching": false
    "sequence_batching": {
        "oldest": {
            "max_candidate_sequences": 1024,
            "preferred_batch_size": [
                256,
                512
            "max_queue_delay_microseconds": 1000
        "max_sequence_idle_microseconds": 60000000,
        "control_input": [
                "name": "START",
                "control": [
                        "kind": "CONTROL_SEQUENCE_START",
                        "int32_false_true": [
                            0,
                            1
                        "fp32_false_true": [],
                        "bool_false_true": [],
                        "data_type": "TYPE_INVALID"
                "name": "READY",
                "control": [
                        "kind": "CONTROL_SEQUENCE_READY",
                            0,
                            1
                "name": "END",
                "control": [
                        "kind": "CONTROL_SEQUENCE_END",
                            0,
                            1
                "name": "CORRID",
                "control": [
                        "kind": "CONTROL_SEQUENCE_CORRID",
                        "int32_false_true": [],
                        "data_type": "TYPE_UINT64"
        "state": []
    "instance_group": [
            "name": "conformer-en-US-asr-streaming-feature-extractor-streaming_0",
            "kind": "KIND_GPU",
            "count": 1,
            "gpus": [
                0
            "secondary_devices": [],
            "profile": [],
            "passive": false,
            "host_policy": ""
    "default_model_filename": "",
    "cc_model_filenames": {},
    "metric_tags": {},
    "parameters": {
        "streaming": {
            "string_value": "True"
        "window_size": {
            "string_value": "0.025"
        "stddev": {
            "string_value": "2.2668, 3.1642, 3.7079, 3.7642, 3.5349, 3.5901, 3.7640, 3.8424, 4.0145, 4.1475, 4.0457, 3.9048, 3.7709, 3.6117, 3.3188, 3.1489, 3.0615, 3.0362, 2.9929, 3.0500, 3.0341, 3.0484, 3.0103, 2.9474, 2.9128, 2.8669, 2.8332, 2.9411, 3.0378, 3.0712, 3.0190, 2.9992, 3.0124, 3.0024, 3.0275, 3.0870, 3.0656, 3.0142, 3.0493, 3.1373, 3.1135, 3.0675, 2.8828, 2.7018, 2.6296, 2.8826, 2.9325, 2.9288, 2.9271, 2.9890, 3.0137, 2.9855, 3.0839, 2.9319, 2.3512, 2.3795, 2.6191, 2.7555, 2.9326, 2.9931, 3.1543, 3.0855, 2.6820, 3.0566, 3.1272, 3.1663, 3.1836, 3.0018, 2.9089, 3.1727, 3.1626, 3.1086, 2.9804, 3.1107, 3.2998, 3.3697, 3.3716, 3.2487, 3.1597, 3.1181"
        "apply_normalization": {
        "norm_per_feature": {
        "dither": {
            "string_value": "0.0"
        "stddev_floor": {
            "string_value": "1e-05"
        "transpose": {
            "string_value": "False"
        "chunk_size": {
            "string_value": "0.16"
        "right_padding_size": {
            "string_value": "1.92"
        "sample_rate": {
            "string_value": "16000"
        "window_stride": {
            "string_value": "0.01"
        "max_execution_batch_size": {
            "string_value": "1"
        "num_features": {
            "string_value": "80"
        "precalc_norm_params": {
        "precalc_norm_time_steps": {
            "string_value": "0"
        "mean": {
            "string_value": "-11.4412,  -9.9334,  -9.1292,  -9.0365,  -9.2804,  -9.5643,  -9.7342, -9.6925,  -9.6333,  -9.2808,  -9.1887,  -9.1422,  -9.1397,  -9.2028, -9.2749,  -9.4776,  -9.9185, -10.1557, -10.3800, -10.5067, -10.3190, -10.4728, -10.5529, -10.6402, -10.6440, -10.5113, -10.7395, -10.7870, -10.6074, -10.5033, -10.8278, -10.6384, -10.8481, -10.6875, -10.5454, -10.4747, -10.5165, -10.4930, -10.3413, -10.3472, -10.3735, -10.6830, -10.8813, -10.6338, -10.3856, -10.7727, -10.8957, -10.8068, -10.7373, -10.6108, -10.3405, -10.2889, -10.3922, -10.4946, -10.3367, -10.4164, -10.9949, -10.7196, -10.3971, -10.1734,  -9.9257,  -9.6557,  -9.1761, -9.6653,  -9.7876,  -9.7230,  -9.7792,  -9.7056,  -9.2702,  -9.4650, -9.2755,  -9.1369,  -9.1174,  -8.9197,  -8.5394,  -8.2614,  -8.1353, -8.1422,  -8.3430,  -8.6655"
        "use_utterance_norm_params": {
        "left_padding_size": {
        "gain": {
            "string_value": "1.0"
    "model_warmup": [],
    "model_transaction_policy": {
        "decoupled": false
I0912 19:06:58.350500 20 tensorrt.cc:5578] TRITONBACKEND_ModelInitialize: riva-trt-riva-punctuation-en-US-nn-bert-base-uncased (version 1)
I0912 19:06:58.421547 20 pipeline_library.cc:24] TRITONBACKEND_ModelInitialize: riva-punctuation-en-US (version 1)
WARNING: Logging before InitGoogleLogging() is written to STDERR
W0912 19:06:58.422551    48 parameter_parser.cc:146] Parameter 'attn_mask_tensor_name' set but unused.
W0912 19:06:58.422822    48 parameter_parser.cc:146] Parameter 'bos_token' set but unused.
W0912 19:06:58.422828    48 parameter_parser.cc:146] Parameter 'capit_logits_tensor_name' set but unused.
W0912 19:06:58.422834    48 parameter_parser.cc:146] Parameter 'capitalization_mapping_path' set but unused.
W0912 19:06:58.422838    48 parameter_parser.cc:146] Parameter 'delimiter' set but unused.
W0912 19:06:58.422842    48 parameter_parser.cc:146] Parameter 'eos_token' set but unused.
W0912 19:06:58.422845    48 parameter_parser.cc:146] Parameter 'input_ids_tensor_name' set but unused.
W0912 19:06:58.422848    48 parameter_parser.cc:146] Parameter 'language_code' set but unused.
W0912 19:06:58.422852    48 parameter_parser.cc:146] Parameter 'load_model' set but unused.
W0912 19:06:58.422856    48 parameter_parser.cc:146] Parameter 'model_api' set but unused.
W0912 19:06:58.422860    48 parameter_parser.cc:146] Parameter 'model_family' set but unused.
W0912 19:06:58.422865    48 parameter_parser.cc:146] Parameter 'model_name' set but unused.
W0912 19:06:58.422869    48 parameter_parser.cc:146] Parameter 'pad_chars_with_spaces' set but unused.
W0912 19:06:58.422873    48 parameter_parser.cc:146] Parameter 'pipeline_type' set but unused.
W0912 19:06:58.422878    48 parameter_parser.cc:146] Parameter 'preserve_accents' set but unused.
W0912 19:06:58.422883    48 parameter_parser.cc:146] Parameter 'punct_logits_tensor_name' set but unused.
W0912 19:06:58.422888    48 parameter_parser.cc:146] Parameter 'punctuation_mapping_path' set but unused.
W0912 19:06:58.422894    48 parameter_parser.cc:146] Parameter 'remove_spaces' set but unused.
W0912 19:06:58.422899    48 parameter_parser.cc:146] Parameter 'to_lower' set but unused.
W0912 19:06:58.422904    48 parameter_parser.cc:146] Parameter 'token_type_tensor_name' set but unused.
W0912 19:06:58.422909    48 parameter_parser.cc:146] Parameter 'tokenizer' set but unused.
W0912 19:06:58.422912    48 parameter_parser.cc:146] Parameter 'tokenizer_to_lower' set but unused.
W0912 19:06:58.422917    48 parameter_parser.cc:146] Parameter 'unicode_normalize' set but unused.
W0912 19:06:58.422922    48 parameter_parser.cc:146] Parameter 'unk_token' set but unused.
W0912 19:06:58.422927    48 parameter_parser.cc:146] Parameter 'use_int64_nn_inputs' set but unused.
W0912 19:06:58.422931    48 parameter_parser.cc:146] Parameter 'vocab' set but unused.
W0912 19:06:58.423112    48 parameter_parser.cc:146] Parameter 'attn_mask_tensor_name' set but unused.
W0912 19:06:58.423126    48 parameter_parser.cc:146] Parameter 'bos_token' set but unused.
W0912 19:06:58.423130    48 parameter_parser.cc:146] Parameter 'capit_logits_tensor_name' set but unused.
W0912 19:06:58.423135    48 parameter_parser.cc:146] Parameter 'capitalization_mapping_path' set but unused.
W0912 19:06:58.423137    48 parameter_parser.cc:146] Parameter 'delimiter' set but unused.
W0912 19:06:58.423141    48 parameter_parser.cc:146] Parameter 'eos_token' set but unused.
W0912 19:06:58.423144    48 parameter_parser.cc:146] Parameter 'input_ids_tensor_name' set but unused.
W0912 19:06:58.423148    48 parameter_parser.cc:146] Parameter 'language_code' set but unused.
W0912 19:06:58.423151    48 parameter_parser.cc:146] Parameter 'model_api' set but unused.
W0912 19:06:58.423156    48 parameter_parser.cc:146] Parameter 'model_family' set but unused.
W0912 19:06:58.423158    48 parameter_parser.cc:146] Parameter 'model_name' set but unused.
W0912 19:06:58.423162    48 parameter_parser.cc:146] Parameter 'pad_chars_with_spaces' set but unused.
W0912 19:06:58.423166    48 parameter_parser.cc:146] Parameter 'preserve_accents' set but unused.
W0912 19:06:58.423169    48 parameter_parser.cc:146] Parameter 'punct_logits_tensor_name' set but unused.
W0912 19:06:58.423172    48 parameter_parser.cc:146] Parameter 'punctuation_mapping_path' set but unused.
W0912 19:06:58.423175    48 parameter_parser.cc:146] Parameter 'remove_spaces' set but unused.
W0912 19:06:58.423179    48 parameter_parser.cc:146] Parameter 'to_lower' set but unused.
W0912 19:06:58.423182    48 parameter_parser.cc:146] Parameter 'token_type_tensor_name' set but unused.
W0912 19:06:58.423187    48 parameter_parser.cc:146] Parameter 'tokenizer' set but unused.
W0912 19:06:58.423189    48 parameter_parser.cc:146] Parameter 'tokenizer_to_lower' set but unused.
W0912 19:06:58.423193    48 parameter_parser.cc:146] Parameter 'unicode_normalize' set but unused.
W0912 19:06:58.423197    48 parameter_parser.cc:146] Parameter 'unk_token' set but unused.
W0912 19:06:58.423199    48 parameter_parser.cc:146] Parameter 'use_int64_nn_inputs' set but unused.
W0912 19:06:58.423203    48 parameter_parser.cc:146] Parameter 'vocab' set but unused.
W0912 19:06:58.423228    48 parameter_parser.cc:146] Parameter 'attn_mask_tensor_name' set but unused.
W0912 19:06:58.423233    48 parameter_parser.cc:146] Parameter 'bos_token' set but unused.
W0912 19:06:58.423236    48 parameter_parser.cc:146] Parameter 'capit_logits_tensor_name' set but unused.
W0912 19:06:58.423239    48 parameter_parser.cc:146] Parameter 'capitalization_mapping_path' set but unused.
W0912 19:06:58.423243    48 parameter_parser.cc:146] Parameter 'delimiter' set but unused.
W0912 19:06:58.423246    48 parameter_parser.cc:146] Parameter 'eos_token' set but unused.
W0912 19:06:58.423249    48 parameter_parser.cc:146] Parameter 'input_ids_tensor_name' set but unused.
W0912 19:06:58.423254    48 parameter_parser.cc:146] Parameter 'language_code' set but unused.
W0912 19:06:58.423256    48 parameter_parser.cc:146] Parameter 'model_api' set but unused.
W0912 19:06:58.423260    48 parameter_parser.cc:146] Parameter 'model_family' set but unused.
W0912 19:06:58.423264    48 parameter_parser.cc:146] Parameter 'model_name' set but unused.
W0912 19:06:58.423266    48 parameter_parser.cc:146] Parameter 'pad_chars_with_spaces' set but unused.
W0912 19:06:58.423270    48 parameter_parser.cc:146] Parameter 'preserve_accents' set but unused.
W0912 19:06:58.423274    48 parameter_parser.cc:146] Parameter 'punct_logits_tensor_name' set but unused.
W0912 19:06:58.423276    48 parameter_parser.cc:146] Parameter 'punctuation_mapping_path' set but unused.
W0912 19:06:58.423280    48 parameter_parser.cc:146] Parameter 'remove_spaces' set but unused.
W0912 19:06:58.423283    48 parameter_parser.cc:146] Parameter 'to_lower' set but unused.
W0912 19:06:58.423287    48 parameter_parser.cc:146] Parameter 'token_type_tensor_name' set but unused.
W0912 19:06:58.423305    48 parameter_parser.cc:146] Parameter 'tokenizer_to_lower' set but unused.
W0912 19:06:58.423310    48 parameter_parser.cc:146] Parameter 'unicode_normalize' set but unused.
W0912 19:06:58.423313    48 parameter_parser.cc:146] Parameter 'unk_token' set but unused.
W0912 19:06:58.423316    48 parameter_parser.cc:146] Parameter 'use_int64_nn_inputs' set but unused.
W0912 19:06:58.423322    48 parameter_parser.cc:146] Parameter 'vocab' set but unused.
W0912 19:06:58.423398    48 parameter_parser.cc:146] Parameter 'model_api' set but unused.
W0912 19:06:58.423481    48 parameter_parser.cc:146] Parameter 'model_family' set but unused.
I0912 19:06:58.424102 20 backend_model.cc:303] model configuration:
    "name": "riva-punctuation-en-US",
    "platform": "",
    "backend": "riva_nlp_pipeline",
    "version_policy": {
        "latest": {
            "num_versions": 1
    "max_batch_size": 1,
    "input": [
            "name": "PIPELINE_INPUT",
            "data_type": "TYPE_STRING",
            "dims": [
                1
            "optional": false
    "output": [
            "name": "PIPELINE_OUTPUT",
            "dims": [
                1
    "batch_input": [],
    "batch_output": [],
    "optimization": {
            "enable": true
            "enable": true
    "instance_group": [
            "name": "riva-punctuation-en-US_0",
            "kind": "KIND_CPU",
            "count": 1,
            "gpus": [],
            "profile": [],
            "passive": false,
            "host_policy": ""
    "metric_tags": {},
    "parameters": {
        "attn_mask_tensor_name": {
            "string_value": "attention_mask"
        "to_lower": {
            "string_value": "true"
        "input_ids_tensor_name": {
            "string_value": "input_ids"
        "punct_logits_tensor_name": {
            "string_value": "punct_logits"
        "remove_spaces": {
        "unicode_normalize": {
        "eos_token": {
            "string_value": "[SEP]"
        "load_model": {
            "string_value": "false"
        "capit_logits_tensor_name": {
            "string_value": "capit_logits"
        "tokenizer": {
            "string_value": "wordpiece"
        "token_type_tensor_name": {
            "string_value": "token_type_ids"
        "pipeline_type": {
            "string_value": "punctuation"
        "model_api": {
            "string_value": "/nvidia.riva.nlp.RivaLanguageUnderstanding/PunctuateText"
        "vocab": {
            "string_value": "/data/models/riva-punctuation-en-US/1/f92889b136d2433693cb9127e1aea218_vocab.txt"
        "delimiter": {
            "string_value": " "
        "model_family": {
            "string_value": "riva"
        "punctuation_mapping_path": {
            "string_value": "/data/models/riva-punctuation-en-US/1/bf74918539724a61a0d7703134519ea5_punct_label_ids.csv"
        "language_code": {
            "string_value": "en-US"
        "preserve_accents": {
        "tokenizer_to_lower": {
        "capitalization_mapping_path": {
            "string_value": "/data/models/riva-punctuation-en-US/1/56633d0a0d8e459b9c8acd572cfa34b8_capit_label_ids.csv"
        "unk_token": {
            "string_value": "[UNK]"
        "model_name": {
            "string_value": "riva-trt-riva-punctuation-en-US-nn-bert-base-uncased"
        "pad_chars_with_spaces": {
        "bos_token": {
            "string_value": "[CLS]"
        "use_int64_nn_inputs": {
    "model_warmup": []
I0912 19:06:58.424595 20 pipeline_library.cc:28] TRITONBACKEND_ModelInstanceInitialize: riva-punctuation-en-US_0 (device 0)
I0912 19:06:58.484221 20 tensorrt.cc:5627] TRITONBACKEND_ModelInstanceInitialize: riva-trt-riva-punctuation-en-US-nn-bert-base-uncased_0 (GPU device 0)
I0912 19:06:58.484622 20 model_lifecycle.cc:693] successfully loaded 'riva-punctuation-en-US' version 1
E0912 19:07:06.819216    22 model_registry.cc:288] error: unable to get server status: failed to connect to all addresses; last error: UNKNOWN: ipv4:127.0.0.1:8001: Failed to connect to remote host: Connection refused
/opt/riva/bin/start-riva: line 55:    20 Killed                  ${CUSTOM_TRITON_ENV} tritonserver --log-verbose=0 --disable-auto-complete-config $model_repos --cuda-memory-pool-byte-size=0:1000000000
One of the processes has exited unexpectedly. Stopping container.
W0912 19:07:08.115984    22 riva_server.cc:196] Signal: 15
FWIW, looks like this was possibly caused by not enough resources (RAM).
I increated the pagefile/swap north of 100gb and loaded up very quickly and good performance with ASR. I didn’t see the swap creep about 8GB so you can probably get away with just 10-20gb swap.
I am moving this topic to the Jetson forums for greater visibility.
Where is the TritonServer located?
Is it on the Jetson Nano or another desktop machine?
Just FYI, here is a JetsonHacks post and walkthrough video of running RIVA server on Jetson Orin Nano:
Thanks for the followup, i had followed that guide and worked great the first time then ran into issues. Once i added some swap memory it was flying. Food for thought.
This was all running locally on the jetson orin nano.
