Orin Nano : about USB3.0 & USB2.0 hub driver
USB3.0_USB2.0_HUB.pdf (340.7 KB)
We are currently using a custom carrier board, with the USB hub chip GL3523&GL850
The attachment is a schematic diagram of the USB hub section.
There is a problem with GL3523 and it is not working properly, but GL850 is working normally
Does the default BSP support these two chips? Do i need additional configurations?
No idea. Please check with the hub vendor what is the driver in use here.
