Orin Nano and tp2815 capture issue
Hello, I am adapting the video decoding chip (tp2815) on Orin Nano. When executing the capture command,
v4l2-ctl -d /dev/video1 --set-fmt-video=width=1920,height=1080,pixelformat=UYVY --set-ctrl bypass_mode=0 --stream-mmap
cat /sys/kernel/debug/tracing/trace
the following error will be reported:
# tracer: nop
# entries-in-buffer/entries-written: 777/777   #P:6
#                                _-------=> irqs-off
#                               / _------=> need-resched
#                              | / _-----=> need-resched-lazy
#                              || / _----=> hardirq/softirq
#                              ||| / _---=> preempt-depth
#                              |||| / _--=> preempt-lazy-depth
#                              ||||| / _-=> migrate-disable
#                              |||||| /     delay
#           TASK-PID     CPU#  |||||||  TIMESTAMP  FUNCTION
     kworker/4:5-227     [004] .......   146.331871: rtcpu_nvcsi_intr: tstamp:5144439816 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x08000000
     kworker/4:5-227     [004] .......   146.331877: rtcpu_vinotify_error: tstamp:5144445257 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164621397632 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331877: rtcpu_vinotify_error: tstamp:5144452129 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164621423968 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331878: rtcpu_vinotify_error: tstamp:5144461556 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164621442496 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331878: rtcpu_vinotify_error: tstamp:5144463863 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164621483648 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331879: rtcpu_vinotify_error: tstamp:5144466241 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164621509728 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331879: rtcpu_vinotify_error: tstamp:5144468449 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164621510976 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331879: rtcpu_vinotify_error: tstamp:5144470402 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164621529280 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331880: rtcpu_vinotify_error: tstamp:5144472587 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164621550624 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331880: rtcpu_vinotify_error: tstamp:5144474956 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164621551904 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331881: rtcpu_vinotify_error: tstamp:5144476845 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164621571008 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331881: rtcpu_vinotify_error: tstamp:5144478868 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164621612160 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331881: rtcpu_vinotify_error: tstamp:5144481578 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164621653216 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331882: rtcpu_vinotify_error: tstamp:5144483374 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164621654464 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331882: rtcpu_vinotify_error: tstamp:5144498341 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164621654976 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331882: rtcpu_vinotify_error: tstamp:5144500502 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164621658912 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331904: rtcpu_nvcsi_intr: tstamp:5144656547 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000000
     kworker/4:5-227     [004] .......   146.331905: rtcpu_vinotify_error: tstamp:5144659215 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164628379296 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331905: rtcpu_vinotify_error: tstamp:5144661156 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164628399488 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331905: rtcpu_vinotify_error: tstamp:5144662836 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164628420000 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331905: rtcpu_vinotify_error: tstamp:5144665362 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164628442400 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331905: rtcpu_vinotify_error: tstamp:5144667369 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164628463104 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331906: rtcpu_vinotify_error: tstamp:5144669274 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164628482784 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331906: rtcpu_vinotify_error: tstamp:5144671669 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164628483296 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331906: rtcpu_vinotify_error: tstamp:5144674017 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164628486784 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331912: rtcpu_nvcsi_intr: tstamp:5144733068 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x08000000
     kworker/4:5-227     [004] .......   146.331912: rtcpu_vinotify_error: tstamp:5144734876 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164630222944 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331913: rtcpu_vinotify_error: tstamp:5144737107 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164630241920 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331913: rtcpu_vinotify_error: tstamp:5144739132 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164630242432 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331913: rtcpu_vinotify_error: tstamp:5144741564 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164630285088 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331931: rtcpu_nvcsi_intr: tstamp:5144902351 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x08000000
     kworker/4:5-227     [004] .......   146.331931: rtcpu_vinotify_error: tstamp:5144905122 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164634756384 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331931: rtcpu_vinotify_error: tstamp:5144907242 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164634783648 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331932: rtcpu_vinotify_error: tstamp:5144909366 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164634801632 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331932: rtcpu_vinotify_error: tstamp:5144912001 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164634830304 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331932: rtcpu_vinotify_error: tstamp:5144914462 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164634850304 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331932: rtcpu_vinotify_error: tstamp:5144916314 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164634878080 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331933: rtcpu_vinotify_error: tstamp:5144918849 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164634922752 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331933: rtcpu_vinotify_error: tstamp:5144920913 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164634923488 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331933: rtcpu_vinotify_error: tstamp:5144923260 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164634965088 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331933: rtcpu_nvcsi_intr: tstamp:5144925292 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000004
     kworker/4:5-227     [004] .......   146.331934: rtcpu_vinotify_error: tstamp:5144925918 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164635012640 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331935: rtcpu_vinotify_error: tstamp:5144928280 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164635030560 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331935: rtcpu_vinotify_error: tstamp:5144930392 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164635057344 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331935: rtcpu_vinotify_error: tstamp:5144932202 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164635107040 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331936: rtcpu_vinotify_error: tstamp:5144934379 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164635152096 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331936: rtcpu_vinotify_error: tstamp:5144936752 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164635153376 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331936: rtcpu_vinotify_error: tstamp:5144938931 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164635179712 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331936: rtcpu_vinotify_error: tstamp:5144941071 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164635180224 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331937: rtcpu_vinotify_error: tstamp:5144943857 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164635240224 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331937: rtcpu_vinotify_error: tstamp:5144946032 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164635244896 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331937: rtcpu_vinotify_error: tstamp:5144947941 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164635284960 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331937: rtcpu_vinotify_error: tstamp:5144950366 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164635285888 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331937: rtcpu_vinotify_error: tstamp:5144953291 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164635328416 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331938: rtcpu_vinotify_error: tstamp:5144955483 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164635328928 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331938: rtcpu_vinotify_error: tstamp:5144957678 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164635370112 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331938: rtcpu_vinotify_error: tstamp:5144960532 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164635418304 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331938: rtcpu_vinotify_error: tstamp:5144962662 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164635419104 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331939: rtcpu_vinotify_error: tstamp:5144964550 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164635460096 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331939: rtcpu_vinotify_error: tstamp:5144971421 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164635505440 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331939: rtcpu_vinotify_error: tstamp:5144973385 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164635547648 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331944: rtcpu_nvcsi_intr: tstamp:5145017325 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:5-227     [004] .......   146.331944: rtcpu_nvcsi_intr: tstamp:5145017325 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:5-227     [004] .......   146.331944: rtcpu_nvcsi_intr: tstamp:5145018815 class:GLOBAL type:STREAM_NOVC phy:0 cil:0 st:2 vc:0 status:0x00000001
     kworker/4:5-227     [004] .......   146.331944: rtcpu_nvcsi_intr: tstamp:5145018815 class:CORRECTABLE_ERR type:STREAM_NOVC phy:0 cil:0 st:2 vc:0 status:0x00000001
     kworker/4:5-227     [004] .......   146.331945: rtcpu_vinotify_error: tstamp:5145020247 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164638851296 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331945: rtcpu_vinotify_error: tstamp:5145022548 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164638853984 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331945: rtcpu_vinotify_error: tstamp:5145025231 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164638854464 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331945: rtcpu_vinotify_error: tstamp:5145027398 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164638876640 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331946: rtcpu_vinotify_error: tstamp:5145029419 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164638879616 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331946: rtcpu_nvcsi_intr: tstamp:5145031918 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x08000000
     kworker/4:5-227     [004] .......   146.331946: rtcpu_vinotify_error: tstamp:5145032723 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164638898912 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331946: rtcpu_vinotify_error: tstamp:5145034926 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164638920512 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331947: rtcpu_vinotify_error: tstamp:5145037133 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164638945952 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331947: rtcpu_vinotify_error: tstamp:5145040192 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164638968096 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331947: rtcpu_vinotify_error: tstamp:5145042442 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164638970848 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331947: rtcpu_vinotify_error: tstamp:5145044395 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164638992448 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331948: rtcpu_vinotify_error: tstamp:5145047172 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164639010560 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331948: rtcpu_vinotify_error: tstamp:5145049287 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164639013536 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331948: rtcpu_vinotify_error: tstamp:5145051647 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164639076320 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331948: rtcpu_vinotify_error: tstamp:5145053623 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164639102400 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331948: rtcpu_vinotify_error: tstamp:5145056529 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164639122176 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331949: rtcpu_vinotify_error: tstamp:5145063433 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164639122656 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331949: rtcpu_vinotify_error: tstamp:5145065996 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164639146720 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331949: rtcpu_vinotify_error: tstamp:5145068125 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164639149632 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331949: rtcpu_vinotify_error: tstamp:5145070126 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164639170528 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331950: rtcpu_vinotify_error: tstamp:5145073219 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164642000960 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331950: rtcpu_vinotify_error: tstamp:5145075218 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164642017344 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331950: rtcpu_vinotify_error: tstamp:5145077333 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164642020416 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331950: rtcpu_vinotify_error: tstamp:5145079524 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164642060288 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331951: rtcpu_nvcsi_intr: tstamp:5145081077 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000044
     kworker/4:5-227     [004] .......   146.331951: rtcpu_nvcsi_intr: tstamp:5145081077 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
     kworker/4:5-227     [004] .......   146.331952: rtcpu_vinotify_error: tstamp:5145083207 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164642101600 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331952: rtcpu_vinotify_error: tstamp:5145085328 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164642102112 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331952: rtcpu_vinotify_error: tstamp:5145087352 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164642103424 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331952: rtcpu_vinotify_error: tstamp:5145090236 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164642147168 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331953: rtcpu_vinotify_error: tstamp:5145092429 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164642148960 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331953: rtcpu_vinotify_error: tstamp:5145094663 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164642151104 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331953: rtcpu_vinotify_error: tstamp:5145097688 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164642196032 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331953: rtcpu_vinotify_error: tstamp:5145099711 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164642238752 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331954: rtcpu_vinotify_error: tstamp:5145101884 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164642239232 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331954: rtcpu_vinotify_error: tstamp:5145104701 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164642257344 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331954: rtcpu_vinotify_error: tstamp:5145106481 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164642280608 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331954: rtcpu_vinotify_error: tstamp:5145108543 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164642282560 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331955: rtcpu_vinotify_error: tstamp:5145110656 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164642299872 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331955: rtcpu_vinotify_error: tstamp:5145113814 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164642326720 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331955: rtcpu_vinotify_error: tstamp:5145115837 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164642368736 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331955: rtcpu_vinotify_error: tstamp:5145118081 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164642369248 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331956: rtcpu_vinotify_error: tstamp:5145120520 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164642370688 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331956: rtcpu_vinotify_error: tstamp:5145122673 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164642379072 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331956: rtcpu_vinotify_error: tstamp:5145125258 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164642411776 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331956: rtcpu_vinotify_error: tstamp:5145127062 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164642414656 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331956: rtcpu_vinotify_error: tstamp:5145130341 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164642460000 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331957: rtcpu_nvcsi_intr: tstamp:5145130599 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x08000000
     kworker/4:5-227     [004] .......   146.331957: rtcpu_vinotify_error: tstamp:5145132989 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164642501952 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331957: rtcpu_vinotify_error: tstamp:5145135028 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164642502880 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331957: rtcpu_vinotify_error: tstamp:5145137867 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164642504800 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331958: rtcpu_vinotify_error: tstamp:5145139855 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164642520800 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331958: rtcpu_vinotify_error: tstamp:5145142037 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164642542016 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331958: rtcpu_vinotify_error: tstamp:5145145293 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164642546272 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331958: rtcpu_vinotify_error: tstamp:5145147167 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164642591264 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331959: rtcpu_vinotify_error: tstamp:5145154384 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164642630208 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331959: rtcpu_vinotify_error: tstamp:5145156655 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164642632416 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331959: rtcpu_vinotify_error: tstamp:5145158609 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164642649472 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331959: rtcpu_nvcsi_intr: tstamp:5145161198 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:15 status:0x00000008
     kworker/4:5-227     [004] .......   146.331960: rtcpu_nvcsi_intr: tstamp:5145161198 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:15 status:0x00000008
     kworker/4:5-227     [004] .......   146.331960: rtcpu_vinotify_error: tstamp:5145162543 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164642650560 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331960: rtcpu_vinotify_error: tstamp:5145164725 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164643724896 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331960: rtcpu_vinotify_error: tstamp:5145166927 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164643726272 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331961: rtcpu_vinotify_error: tstamp:5145170087 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164643746304 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331961: rtcpu_vinotify_error: tstamp:5145172106 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164643815648 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331961: rtcpu_vinotify_error: tstamp:5145174250 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164643816992 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331961: rtcpu_vinotify_error: tstamp:5145176844 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164643834112 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331962: rtcpu_vinotify_error: tstamp:5145178977 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164643858592 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331962: rtcpu_vinotify_error: tstamp:5145180883 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164643860288 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331962: rtcpu_vinotify_error: tstamp:5145183223 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164643903040 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331962: rtcpu_vinotify_error: tstamp:5145186344 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164643940608 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331962: rtcpu_vinotify_error: tstamp:5145188343 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164643942240 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331963: rtcpu_vinotify_error: tstamp:5145190392 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164643942784 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331963: rtcpu_nvcsi_intr: tstamp:5145191000 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x08000000
     kworker/4:5-227     [004] .......   146.331963: rtcpu_vinotify_error: tstamp:5145193953 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164643943968 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331963: rtcpu_vinotify_error: tstamp:5145196180 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164643966976 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331964: rtcpu_vinotify_error: tstamp:5145197976 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164643968608 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331964: rtcpu_vinotify_error: tstamp:5145201022 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164643974816 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331964: rtcpu_vinotify_error: tstamp:5145202972 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164644035232 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331964: rtcpu_vinotify_error: tstamp:5145205289 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164644060864 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331965: rtcpu_vinotify_error: tstamp:5145207299 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164644062496 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331965: rtcpu_vinotify_error: tstamp:5145210352 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164644063008 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331965: rtcpu_vinotify_error: tstamp:5145212394 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164644101152 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331965: rtcpu_vinotify_error: tstamp:5145214167 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164644102080 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331966: rtcpu_vinotify_error: tstamp:5145217502 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164644104416 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331966: rtcpu_vinotify_error: tstamp:5145219569 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164644188320 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331966: rtcpu_nvcsi_intr: tstamp:5145219860 class:GLOBAL type:STREAM_NOVC phy:0 cil:0 st:2 vc:0 status:0x00000001
     kworker/4:5-227     [004] .......   146.331966: rtcpu_nvcsi_intr: tstamp:5145219860 class:CORRECTABLE_ERR type:STREAM_NOVC phy:0 cil:0 st:2 vc:0 status:0x00000001
     kworker/4:5-227     [004] .......   146.331967: rtcpu_vinotify_error: tstamp:5145222460 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164644189344 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331967: rtcpu_vinotify_error: tstamp:5145225724 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164644213952 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331967: rtcpu_vinotify_error: tstamp:5145227878 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164644214688 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331967: rtcpu_vinotify_error: tstamp:5145230061 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164644230016 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331968: rtcpu_vinotify_error: tstamp:5145232447 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164644275104 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331980: rtcpu_vinotify_error: tstamp:5145368412 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164649833888 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331981: rtcpu_vinotify_error: tstamp:5145370802 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164649835328 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331981: rtcpu_vinotify_error: tstamp:5145373120 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164649851296 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.331981: rtcpu_nvcsi_intr: tstamp:5145374316 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:14 status:0x0000000a
     kworker/4:5-227     [004] .......   146.331982: rtcpu_nvcsi_intr: tstamp:5145374316 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:14 status:0x0000000a
     kworker/4:5-227     [004] .......   146.331982: rtcpu_vinotify_error: tstamp:5145376280 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164649875520 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332017: rtcpu_vinotify_error: tstamp:5145378439 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164649878048 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332017: rtcpu_vinotify_error: tstamp:5145380646 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164649878880 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332028: rtcpu_vinotify_error: tstamp:5145479846 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164652328032 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332028: rtcpu_vinotify_error: tstamp:5145482210 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164652348320 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332028: rtcpu_vinotify_error: tstamp:5145484798 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164652389504 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332028: rtcpu_vinotify_error: tstamp:5145487072 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164652394016 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332029: rtcpu_vinotify_error: tstamp:5145489086 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164652415072 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332029: rtcpu_vinotify_error: tstamp:5145492048 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164652442656 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332029: rtcpu_vinotify_error: tstamp:5145494033 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164652465600 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332029: rtcpu_vinotify_error: tstamp:5145496599 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164652487968 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332030: rtcpu_vinotify_error: tstamp:5145499466 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164652508352 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332030: rtcpu_vinotify_error: tstamp:5145501564 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164652529760 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332030: rtcpu_vinotify_error: tstamp:5145503514 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164652549472 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332030: rtcpu_vinotify_error: tstamp:5145505585 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164652591616 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332031: rtcpu_nvcsi_intr: tstamp:5145507940 class:GLOBAL type:STREAM_NOVC phy:0 cil:0 st:2 vc:0 status:0x00000001
     kworker/4:5-227     [004] .......   146.332031: rtcpu_nvcsi_intr: tstamp:5145507940 class:CORRECTABLE_ERR type:STREAM_NOVC phy:0 cil:0 st:2 vc:0 status:0x00000001
     kworker/4:5-227     [004] .......   146.332031: rtcpu_vinotify_error: tstamp:5145509176 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164652592160 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332031: rtcpu_vinotify_error: tstamp:5145511449 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164652617760 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332032: rtcpu_vinotify_error: tstamp:5145513636 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164652635968 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332032: rtcpu_vinotify_error: tstamp:5145516603 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164652659008 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332032: rtcpu_vinotify_error: tstamp:5145522800 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164652680128 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332032: rtcpu_vinotify_error: tstamp:5145525337 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164652723776 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332033: rtcpu_vinotify_error: tstamp:5145527439 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164652724288 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332033: rtcpu_vinotify_error: tstamp:5145529534 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164652750112 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332033: rtcpu_vinotify_error: tstamp:5145532170 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164656754368 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332033: rtcpu_vinotify_error: tstamp:5145534130 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164656779264 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332034: rtcpu_nvcsi_intr: tstamp:5145534860 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:12 status:0x0000000a
     kworker/4:5-227     [004] .......   146.332034: rtcpu_nvcsi_intr: tstamp:5145534860 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:12 status:0x0000000a
     kworker/4:5-227     [004] .......   146.332034: rtcpu_vinotify_error: tstamp:5145537269 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164656799328 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332034: rtcpu_vinotify_error: tstamp:5145539995 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164656823808 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332035: rtcpu_nvcsi_intr: tstamp:5145541624 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x08000000
     kworker/4:5-227     [004] .......   146.332035: rtcpu_vinotify_error: tstamp:5145542718 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164656841632 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332035: rtcpu_vinotify_error: tstamp:5145544737 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164656845568 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332035: rtcpu_vinotify_error: tstamp:5145547560 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164656887104 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332036: rtcpu_vinotify_error: tstamp:5145549794 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164656887616 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332036: rtcpu_vinotify_error: tstamp:5145551805 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164656927680 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332036: rtcpu_vinotify_error: tstamp:5145554679 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164656929568 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332036: rtcpu_vinotify_error: tstamp:5145556878 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164656954592 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332037: rtcpu_vinotify_error: tstamp:5145558766 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164656970112 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332037: rtcpu_vinotify_error: tstamp:5145560730 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164656980416 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332037: rtcpu_vinotify_error: tstamp:5145563614 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164657019552 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332037: rtcpu_vinotify_error: tstamp:5145565736 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164657020064 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332038: rtcpu_vinotify_error: tstamp:5145567818 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164657058176 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332038: rtcpu_vinotify_error: tstamp:5145570592 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164657058880 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332039: rtcpu_vinotify_error: tstamp:5145572778 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164657085152 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332039: rtcpu_vinotify_error: tstamp:5145575083 cch:-1 vi:1 tag:CSIMUX_STREAM channel:0x30 frame:0 vi_tstamp:164657111744 data:0x0000000000000100
     kworker/4:5-227     [004] .......   146.332039: rtcpu_vinotify_error: tstamp:5145577526 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164657150080 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332039: rtcpu_vinotify_error: tstamp:5145579510 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164657150912 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332040: rtcpu_vinotify_error: tstamp:5145581498 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164657171840 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332040: rtcpu_vinotify_error: tstamp:5145583394 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164657172352 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332040: rtcpu_vinotify_error: tstamp:5145585831 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164657212960 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332040: rtcpu_vinotify_error: tstamp:5145588163 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164657213504 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332041: rtcpu_vinotify_error: tstamp:5145590270 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164657235776 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332041: rtcpu_vinotify_error: tstamp:5145592459 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164657236640 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332041: rtcpu_vinotify_error: tstamp:5145594877 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164657277920 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332041: rtcpu_vinotify_error: tstamp:5145597093 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164657279776 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332041: rtcpu_vinotify_error: tstamp:5145599403 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164657318048 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332042: rtcpu_nvcsi_intr: tstamp:5145600830 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x08000000
     kworker/4:5-227     [004] .......   146.332042: rtcpu_vinotify_error: tstamp:5145602126 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164657344224 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332042: rtcpu_vinotify_error: tstamp:5145604296 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164657346016 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332043: rtcpu_vinotify_error: tstamp:5145611057 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164657368000 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332043: rtcpu_vinotify_error: tstamp:5145613241 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164657410912 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332043: rtcpu_vinotify_error: tstamp:5145615519 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164657412064 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332043: rtcpu_vinotify_error: tstamp:5145618064 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164657432544 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332044: rtcpu_vinotify_error: tstamp:5145620043 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164658420960 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332044: rtcpu_vinotify_error: tstamp:5145622358 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164658463712 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332044: rtcpu_vinotify_error: tstamp:5145625143 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164658465600 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332044: rtcpu_vinotify_error: tstamp:5145627115 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164658485120 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332044: rtcpu_vinotify_error: tstamp:5145629069 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164658505856 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332045: rtcpu_nvcsi_intr: tstamp:5145630028 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000044
     kworker/4:5-227     [004] .......   146.332045: rtcpu_nvcsi_intr: tstamp:5145630028 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
     kworker/4:5-227     [004] .......   146.332045: rtcpu_vinotify_error: tstamp:5145631464 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164658528032 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332046: rtcpu_vinotify_error: tstamp:5145634122 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164658549600 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332046: rtcpu_vinotify_error: tstamp:5145636083 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164658552736 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332046: rtcpu_vinotify_error: tstamp:5145638430 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164658570208 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332046: rtcpu_vinotify_error: tstamp:5145641010 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164658595168 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332047: rtcpu_vinotify_error: tstamp:5145643081 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164658617568 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332047: rtcpu_vinotify_error: tstamp:5145645087 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164658636960 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332047: rtcpu_vinotify_error: tstamp:5145646993 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164658659264 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332047: rtcpu_vinotify_error: tstamp:5145649462 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164658681056 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332047: rtcpu_vinotify_error: tstamp:5145651637 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164658699008 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332048: rtcpu_vinotify_error: tstamp:5145653753 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164658700832 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332048: rtcpu_vinotify_error: tstamp:5145655812 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164658741728 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332048: rtcpu_vinotify_error: tstamp:5145658728 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164658743552 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332048: rtcpu_vinotify_error: tstamp:5145660965 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164658763968 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332049: rtcpu_vinotify_error: tstamp:5145662928 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164658784832 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332049: rtcpu_vinotify_error: tstamp:5145665758 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164658807968 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332049: rtcpu_vinotify_error: tstamp:5145667837 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164658831264 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332049: rtcpu_vinotify_error: tstamp:5145670262 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164658851840 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332050: rtcpu_vinotify_error: tstamp:5145672574 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164658853632 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332050: rtcpu_vinotify_error: tstamp:5145674965 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164658898688 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332050: rtcpu_nvcsi_intr: tstamp:5145675118 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x08000000
     kworker/4:5-227     [004] .......   146.332050: rtcpu_vinotify_error: tstamp:5145677665 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164658900480 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332051: rtcpu_vinotify_error: tstamp:5145679899 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164660592928 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332051: rtcpu_vinotify_error: tstamp:5145682625 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164660637984 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332051: rtcpu_vinotify_error: tstamp:5145684593 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164660655488 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332051: rtcpu_vinotify_error: tstamp:5145686536 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164660659808 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332052: rtcpu_vinotify_error: tstamp:5145689161 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164660686848 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332052: rtcpu_nvcsi_intr: tstamp:5145689291 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x08000000
     kworker/4:5-227     [004] .......   146.332052: rtcpu_vinotify_error: tstamp:5145691585 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164660700832 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332052: rtcpu_vinotify_error: tstamp:5145698544 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164660723904 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332052: rtcpu_vinotify_error: tstamp:5145700800 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164660725728 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.332053: rtcpu_vinotify_error: tstamp:5145702784 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164660766528 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387842: rtcpu_vinotify_error: tstamp:5145704747 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164660768320 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387843: rtcpu_vinotify_error: tstamp:5145707281 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164661590368 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387844: rtcpu_vinotify_error: tstamp:5145709384 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164661613632 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387844: rtcpu_vinotify_error: tstamp:5145711621 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164661632736 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387845: rtcpu_vinotify_error: tstamp:5145714366 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164661633856 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387845: rtcpu_vinotify_error: tstamp:5145716259 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164661655680 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387846: rtcpu_vinotify_error: tstamp:5145718683 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164661656224 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387846: rtcpu_vinotify_error: tstamp:5145720590 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164661701344 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387846: rtcpu_vinotify_error: tstamp:5145723164 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164661721952 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387848: rtcpu_vinotify_error: tstamp:5145725144 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164661723040 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387848: rtcpu_vinotify_error: tstamp:5145727092 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164661744768 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387849: rtcpu_vinotify_error: tstamp:5145730000 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164661765120 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387849: rtcpu_vinotify_error: tstamp:5145732184 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164661766112 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387850: rtcpu_vinotify_error: tstamp:5145734502 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164661788544 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387850: rtcpu_vinotify_error: tstamp:5145736625 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164661789056 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387850: rtcpu_vinotify_error: tstamp:5145739021 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164661833568 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387851: rtcpu_vinotify_error: tstamp:5145741346 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164661855232 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387851: rtcpu_vinotify_error: tstamp:5145743580 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164661856224 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387851: rtcpu_vinotify_error: tstamp:5145746468 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164661878176 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387852: rtcpu_vinotify_error: tstamp:5145748566 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164661896576 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387852: rtcpu_vinotify_error: tstamp:5145750585 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164661897568 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387853: rtcpu_vinotify_error: tstamp:5145753356 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164661919968 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387853: rtcpu_vinotify_error: tstamp:5145755557 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164661920480 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387854: rtcpu_nvcsi_intr: tstamp:5145757450 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x08000000
     kworker/4:5-227     [004] .......   146.387854: rtcpu_vinotify_error: tstamp:5145758391 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164661963520 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387855: rtcpu_nvcsi_intr: tstamp:5145760131 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x08000000
     kworker/4:5-227     [004] .......   146.387855: rtcpu_vinotify_error: tstamp:5145761230 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164662002368 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387855: rtcpu_vinotify_error: tstamp:5145763186 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164662023776 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387856: rtcpu_vinotify_error: tstamp:5145765778 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164662027552 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387856: rtcpu_vinotify_error: tstamp:5145768531 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164662028864 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387856: rtcpu_vinotify_error: tstamp:5145770800 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164662091488 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387857: rtcpu_vinotify_error: tstamp:5145772866 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164662113408 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387857: rtcpu_vinotify_error: tstamp:5145774915 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164662140768 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387858: rtcpu_vinotify_error: tstamp:5145777749 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164662154784 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387858: rtcpu_vinotify_error: tstamp:5145779890 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164662155264 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387858: rtcpu_vinotify_error: tstamp:5145786940 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164662179648 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387859: rtcpu_vinotify_error: tstamp:5145789536 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164662193856 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387859: rtcpu_vinotify_error: tstamp:5145791521 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164662220000 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387860: rtcpu_vinotify_error: tstamp:5145794493 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164662238912 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387860: rtcpu_vinotify_error: tstamp:5145796838 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164663325664 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387860: rtcpu_vinotify_error: tstamp:5145798924 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164663389024 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387861: rtcpu_vinotify_error: tstamp:5145801249 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164663408224 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387861: rtcpu_vinotify_error: tstamp:5145803934 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164663431104 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387862: rtcpu_vinotify_error: tstamp:5145806250 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164663456224 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387862: rtcpu_vinotify_error: tstamp:5145808797 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164663479776 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387862: rtcpu_vinotify_error: tstamp:5145811622 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164663525120 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387863: rtcpu_vinotify_error: tstamp:5145814119 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164663543520 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387863: rtcpu_vinotify_error: tstamp:5145816326 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164663585376 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387863: rtcpu_vinotify_error: tstamp:5145819388 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164663654016 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387864: rtcpu_vinotify_error: tstamp:5145821744 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164663675744 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387864: rtcpu_vinotify_error: tstamp:5145824091 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164663679296 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387865: rtcpu_vinotify_error: tstamp:5145826952 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164663702624 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387865: rtcpu_vinotify_error: tstamp:5145829104 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164663723072 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387865: rtcpu_vinotify_error: tstamp:5145830878 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164663745280 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387866: rtcpu_vinotify_error: tstamp:5145833540 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164663768416 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387866: rtcpu_vinotify_error: tstamp:5145836249 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164663787488 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387867: rtcpu_vinotify_error: tstamp:5145838565 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164663829792 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387867: rtcpu_vinotify_error: tstamp:5145840883 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164663900288 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387867: rtcpu_vinotify_error: tstamp:5145843573 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164663915968 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387868: rtcpu_vinotify_error: tstamp:5145845931 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164663933888 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387868: rtcpu_vinotify_error: tstamp:5145848236 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164663958176 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387869: rtcpu_nvcsi_intr: tstamp:5145849982 class:GLOBAL type:STREAM_NOVC phy:0 cil:0 st:2 vc:0 status:0x00000001
     kworker/4:5-227     [004] .......   146.387869: rtcpu_nvcsi_intr: tstamp:5145849982 class:CORRECTABLE_ERR type:STREAM_NOVC phy:0 cil:0 st:2 vc:0 status:0x00000001
     kworker/4:5-227     [004] .......   146.387869: rtcpu_nvcsi_intr: tstamp:5145850898 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x08000000
     kworker/4:5-227     [004] .......   146.387870: rtcpu_vinotify_error: tstamp:5145852198 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164663997856 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387870: rtcpu_vinotify_error: tstamp:5145854091 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164664045728 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387871: rtcpu_nvcsi_intr: tstamp:5145856254 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x08000000
     kworker/4:5-227     [004] .......   146.387871: rtcpu_vinotify_error: tstamp:5145856875 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164664066272 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387871: rtcpu_vinotify_error: tstamp:5145860043 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164664066784 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387872: rtcpu_vinotify_error: tstamp:5145861973 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164664110464 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387872: rtcpu_nvcsi_intr: tstamp:5145863024 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x08000000
     kworker/4:5-227     [004] .......   146.387873: rtcpu_vinotify_error: tstamp:5145864156 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164664162016 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387873: rtcpu_vinotify_error: tstamp:5145866118 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164664186752 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387873: rtcpu_vinotify_error: tstamp:5145869340 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164664187264 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387874: rtcpu_nvcsi_intr: tstamp:5145871377 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:15 status:0x00000002
     kworker/4:5-227     [004] .......   146.387874: rtcpu_nvcsi_intr: tstamp:5145871377 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:15 status:0x00000002
     kworker/4:5-227     [004] .......   146.387874: rtcpu_vinotify_error: tstamp:5145872390 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164664209216 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387874: rtcpu_vinotify_error: tstamp:5145874532 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164664250272 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387875: rtcpu_vinotify_error: tstamp:5145881857 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164664298016 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387876: rtcpu_vinotify_error: tstamp:5145883951 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164664300480 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387876: rtcpu_nvcsi_intr: tstamp:5145886936 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x0e000000
     kworker/4:5-227     [004] .......   146.387876: rtcpu_nvcsi_intr: tstamp:5145886936 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x06000000
     kworker/4:5-227     [004] .......   146.387876: rtcpu_vinotify_error: tstamp:5145887832 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164664344416 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387877: rtcpu_vinotify_error: tstamp:5145889663 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164664346720 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387877: rtcpu_vinotify_error: tstamp:5145892075 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164666343712 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387877: rtcpu_vinotify_error: tstamp:5145895214 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164666368096 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387877: rtcpu_vinotify_error: tstamp:5145897500 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164666387232 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387877: rtcpu_vinotify_error: tstamp:5145900074 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164666433408 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387878: rtcpu_vinotify_error: tstamp:5145903369 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164666475968 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387878: rtcpu_vinotify_error: tstamp:5145905599 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164666499008 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387878: rtcpu_vinotify_error: tstamp:5145907889 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164666522176 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387878: rtcpu_vinotify_error: tstamp:5145910236 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164666564224 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387878: rtcpu_vinotify_error: tstamp:5145913055 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164666586336 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387879: rtcpu_vinotify_error: tstamp:5145915174 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164666592576 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387879: rtcpu_vinotify_error: tstamp:5145917063 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164666603360 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387879: rtcpu_nvcsi_intr: tstamp:5145919646 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x08000000
     kworker/4:5-227     [004] .......   146.387879: rtcpu_vinotify_error: tstamp:5145920677 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164666627328 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387879: rtcpu_vinotify_error: tstamp:5145922543 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164666689760 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387880: rtcpu_vinotify_error: tstamp:5145924715 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164666711936 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387880: rtcpu_vinotify_error: tstamp:5145926757 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164666753472 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387880: rtcpu_vinotify_error: tstamp:5145930095 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164666754976 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387880: rtcpu_nvcsi_intr: tstamp:5145930917 class:GLOBAL type:STREAM_NOVC phy:0 cil:0 st:2 vc:0 status:0x00000001
     kworker/4:5-227     [004] .......   146.387880: rtcpu_nvcsi_intr: tstamp:5145930917 class:CORRECTABLE_ERR type:STREAM_NOVC phy:0 cil:0 st:2 vc:0 status:0x00000001
     kworker/4:5-227     [004] .......   146.387881: rtcpu_vinotify_error: tstamp:5145933560 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164666777280 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387881: rtcpu_vinotify_error: tstamp:5145936298 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164666820416 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387888: rtcpu_vinotify_error: tstamp:5146038168 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164669755072 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387889: rtcpu_vinotify_error: tstamp:5146040793 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164669778592 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387889: rtcpu_vinotify_error: tstamp:5146044141 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164669800864 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387889: rtcpu_vinotify_error: tstamp:5146046350 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164669819776 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387889: rtcpu_vinotify_error: tstamp:5146048168 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164669842240 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387890: rtcpu_vinotify_error: tstamp:5146050134 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164669867136 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387890: rtcpu_vinotify_error: tstamp:5146053098 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164669892864 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387891: rtcpu_vinotify_error: tstamp:5146055380 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164669911584 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387891: rtcpu_vinotify_error: tstamp:5146057482 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164669933536 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387891: rtcpu_vinotify_error: tstamp:5146060340 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164669973376 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387891: rtcpu_vinotify_error: tstamp:5146062708 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164669997824 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387891: rtcpu_vinotify_error: tstamp:5146064989 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164670017376 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387892: rtcpu_nvcsi_intr: tstamp:5146070188 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000044
     kworker/4:5-227     [004] .......   146.387892: rtcpu_nvcsi_intr: tstamp:5146070188 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
     kworker/4:5-227     [004] .......   146.387892: rtcpu_vinotify_error: tstamp:5146072849 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164670060448 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387892: rtcpu_vinotify_error: tstamp:5146075069 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164670065152 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387892: rtcpu_vinotify_error: tstamp:5146077980 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164670084672 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387893: rtcpu_vinotify_error: tstamp:5146080129 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164670127680 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387893: rtcpu_vinotify_error: tstamp:5146082154 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164673976928 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387893: rtcpu_vinotify_error: tstamp:5146084304 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164673980288 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387893: rtcpu_vinotify_error: tstamp:5146087312 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164674003328 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387893: rtcpu_vinotify_error: tstamp:5146089370 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164674021248 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387894: rtcpu_vinotify_error: tstamp:5146091582 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164674024896 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387894: rtcpu_vinotify_error: tstamp:5146094530 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164674047776 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387894: rtcpu_vinotify_error: tstamp:5146096707 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164674069792 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387894: rtcpu_vinotify_error: tstamp:5146099130 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164674090272 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387894: rtcpu_vinotify_error: tstamp:5146101114 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164674090752 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387895: rtcpu_vinotify_error: tstamp:5146104384 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164674098784 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387895: rtcpu_vinotify_error: tstamp:5146106442 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164674133408 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387895: rtcpu_vinotify_error: tstamp:5146108778 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164674136704 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387895: rtcpu_vinotify_error: tstamp:5146112058 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164674154816 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387895: rtcpu_vinotify_error: tstamp:5146114382 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164674176928 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387896: rtcpu_vinotify_error: tstamp:5146116639 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164674218624 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387896: rtcpu_vinotify_error: tstamp:5146119703 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164674219168 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387896: rtcpu_vinotify_error: tstamp:5146121856 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164674262336 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387896: rtcpu_vinotify_error: tstamp:5146124195 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164674279424 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387897: rtcpu_vinotify_error: tstamp:5146126257 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164674281760 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387897: rtcpu_vinotify_error: tstamp:5146129349 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164674306176 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387897: rtcpu_vinotify_error: tstamp:5146131462 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164674323264 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387897: rtcpu_nvcsi_intr: tstamp:5146133438 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x08000000
     kworker/4:5-227     [004] .......   146.387897: rtcpu_vinotify_error: tstamp:5146134244 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164674349216 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387898: rtcpu_vinotify_error: tstamp:5146137206 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164674349728 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387898: rtcpu_vinotify_error: tstamp:5146139410 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164674366272 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387898: rtcpu_vinotify_error: tstamp:5146141617 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164674390400 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387898: rtcpu_vinotify_error: tstamp:5146145148 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164674409728 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387898: rtcpu_vinotify_error: tstamp:5146146923 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164674434848 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387899: rtcpu_vinotify_error: tstamp:5146148863 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164674441088 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387899: rtcpu_vinotify_error: tstamp:5146150935 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164674476128 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387899: rtcpu_vinotify_error: tstamp:5146153811 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164674476640 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387899: rtcpu_vinotify_error: tstamp:5146155795 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164674493888 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387899: rtcpu_vinotify_error: tstamp:5146157866 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164674517952 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387899: rtcpu_vinotify_error: tstamp:5146165000 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164674538656 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387900: rtcpu_vinotify_error: tstamp:5146167129 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164674539968 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387900: rtcpu_vinotify_error: tstamp:5146169960 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164674566464 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387900: rtcpu_vinotify_error: tstamp:5146172167 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164674607104 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387900: rtcpu_vinotify_error: tstamp:5146174257 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164675478752 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387900: rtcpu_vinotify_error: tstamp:5146176578 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164675498784 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387901: rtcpu_vinotify_error: tstamp:5146179609 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164675520704 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387901: rtcpu_vinotify_error: tstamp:5146182148 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164675540352 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387901: rtcpu_vinotify_error: tstamp:5146184247 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164675543648 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387901: rtcpu_vinotify_error: tstamp:5146187556 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164675567136 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387901: rtcpu_nvcsi_intr: tstamp:5146188916 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:15 status:0x00000002
     kworker/4:5-227     [004] .......   146.387902: rtcpu_nvcsi_intr: tstamp:5146188916 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:15 status:0x00000002
     kworker/4:5-227     [004] .......   146.387902: rtcpu_vinotify_error: tstamp:5146190529 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164675586432 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387902: rtcpu_vinotify_error: tstamp:5146192557 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164675608256 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387902: rtcpu_vinotify_error: tstamp:5146203014 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164675628512 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387903: rtcpu_vinotify_error: tstamp:5146205156 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164675654528 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387903: rtcpu_vinotify_error: tstamp:5146207211 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164677786720 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387903: rtcpu_vinotify_error: tstamp:5146209473 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164677787424 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387903: rtcpu_vinotify_error: tstamp:5146211704 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164677828544 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387903: rtcpu_vinotify_error: tstamp:5146213809 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164677830304 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387904: rtcpu_vinotify_error: tstamp:5146216393 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164677859008 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387904: rtcpu_vinotify_error: tstamp:5146218614 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164677876160 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387904: rtcpu_vinotify_error: tstamp:5146220633 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164677896416 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387905: rtcpu_nvcsi_intr: tstamp:5146220826 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x08000000
     kworker/4:5-227     [004] .......   146.387905: rtcpu_vinotify_error: tstamp:5146223737 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164677916640 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387905: rtcpu_vinotify_error: tstamp:5146225763 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164677917152 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387906: rtcpu_vinotify_error: tstamp:5146227884 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164677957568 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387906: rtcpu_vinotify_error: tstamp:5146230367 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164677960800 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387906: rtcpu_vinotify_error: tstamp:5146232329 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:53442 vi_tstamp:164678041920 data:0x0000d0c20c0000a2
     kworker/4:5-227     [004] .......   146.387906: rtcpu_vinotify_error: tstamp:5146234222 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164678045056 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387906: rtcpu_vinotify_error: tstamp:5146236166 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164678046656 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387907: rtcpu_vinotify_error: tstamp:5146238610 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164678071872 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387907: rtcpu_vinotify_error: tstamp:5146240782 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164678092576 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387907: rtcpu_vinotify_error: tstamp:5146242967 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164678117408 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387907: rtcpu_vinotify_error: tstamp:5146245287 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164678138752 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387907: rtcpu_vinotify_error: tstamp:5146247513 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x02 frame:2 vi_tstamp:164678161440 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387908: rtcpu_vinotify_error: tstamp:5146249500 cch:0 vi:1 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:164678163424 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387908: rtcpu_vinotify_error: tstamp:5146251560 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x03 frame:2 vi_tstamp:164678180704 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387908: rtcpu_vinotify_error: tstamp:5146253938 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:164678181984 data:0x00000002000000a2
     kworker/4:5-227     [004] .......   146.387910: rtcpu_string: tstamp:5146258846 id:0x04010000 str:"BUG: core/watchdog/heartbeat-task.c:162 [heartbe"
     kworker/4:5-227     [004] .......   146.387911: rtcpu_string: tstamp:5146259043 id:0x04010000 str:"at_halt_execution] ""
     kworker/4:5-227     [004] .......   146.387911: rtcpu_string: tstamp:5146264012 id:0x04010000 str:"*** RCE WATCHDOG FAILURE: HALTING ***"
     kworker/4:5-227     [004] .......   146.555846: rtcpu_start: tstamp:5151013894
dmesg :
[   80.172756] tp2815 9-0047: probing v4l2 sensor.
[   80.172766] tp2815 9-0047: probing v4l2 sensor at addr 0x47
[   80.172843] tp2815 9-0047: Failed to find clocks
[   80.172984] tp2815 9-0047: tegracam sensor driver:tp2815_v2.0.6
[   80.173535] tp2815 9-0047: tp2815_board_setup: error during i2c read probe (-121)
[   80.173585] tegra-camrtc-capture-vi tegra-capture-vi: subdev tp2815 9-0047 bound
[   80.174656] tp2815 10-0047: probing v4l2 sensor.
[   80.174658] tp2815 10-0047: probing v4l2 sensor at addr 0x47
[   80.174701] tp2815 10-0047: Failed to find clocks
[   80.174748] tp2815 10-0047: tegracam sensor driver:tp2815_v2.0.6
[   80.175124] tegra-camrtc-capture-vi tegra-capture-vi: subdev tp2815 10-0047 bound
[  146.289950] bwmgr API not supported
[  146.387911] [RCE] BUG: core/watchdog/heartbeat-task.c:162 [heartbeat_halt_execution] "*** RCE WATCHDOG FAILURE: HALTING ***"
[  146.389572] tegra186-cam-rtcpu bc00000.rtcpu: Alert: Camera RTCPU gone bad! restoring it immediately!!
[  148.963835] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  148.963857] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  148.964014] tegra194-vi5 13e40000.host1x:vi1@14c00000: vi_capture_release: control failed, errno 1
[  148.964092] video4linux video1: vi capture release failed
[  148.964098] tegra-camrtc-capture-vi tegra-capture-vi: fatal: error recovery failed
hello 3165897602,
it looks there’re PHY interrupts, the error code 0x44 indicate there’re more than one bit error has detected on data-lane;
besides, you may double check your driver implementation, according to the error log… tp2815 10-0047: Failed to find clocks
