I was previously using Orin Nano with Jetpack 5 NVME SSD.I upgraded Orin Nano to Jetpack 6 on a new NVMe SSD with SDK.When I try to run Orin Nano with old NVMe SSD with Jetpack 5 installed, the boot fails.
Hi kullanici1106,
Are you using the devkit or custom board for Orin Nano?
It is expected since the bootloader on your Orin Nano has been updated to Jetpack 6 but you are using the rootfs on NVMe with Jetpack 5.
Please connect the NVMe SSD and reflash again.
I am using devkit. Since the realsense camera did not work well on jetpack 5, I wanted to try it on another nvme with jetpack 6, but the camera was not seen on that. I will continue with jetpack 5 for now. The answer to the question I asked here is that the card upgraded to jetpack 6 cannot be used with jetpack 5 by installing a different ssd.
It is expected that you should use the same Jetpack release for them.
