Orin Nano Dev Kit fan doesn’t run when in recovery mode
I’ve noticed that when the Orin Nano is in recovery mode, the heat sink fan doesn’t run, and it gets quite warm. Not sure if it’s possible for Nvidia to change the firmware on it to run the fan when in recovery mode.
Hi rmann,
If the device only in recovery mode without flash, the FAN doesn’t running is expected.
During the flash process, the FAN is running, we can’t see the issue.
Yeah, in recovery mode, there is no fan running. I’d suggest changing the recovery mode behavior to run the fan, as it was getting quite hot to the touch.
