Orin Nano Dev Kit - Jetpack not detected
Hi, I bought Jetson Orin Nano Dev Kit and started installing today. The setup was little complicated.
I run Ubuntu 22 on 32G USB key with additional 32G on SD card. I did not have 64G usb… Then I run SDK tool BUT at the step 3
I checked only first item which is basic Linux and leave other items blank. Installation started and ended successfully. I though that I will install other components later when Jetson will have an OS. So I run the Jetson first time and run
apt install nvidia-jetpack
I see in the terminal jetpack is installed in version 6.2.
Then I run jtop and see that the jetpack is not detected. Now I think I need to install remaining packages to get the performance. Can somebody help me to run the jetpack properly?
Please refer to related topics
