Orin Nano Dev Kit — M.2 Key-E wifi slot dead (141e0000 Phy link never came up), two known-good cards, requesting RMA
Official Jetson Orin Nano Developer Kit, purchased from Micro Center (under 1-yr warranty). BSP R36.5.0 / JetPack 6.2, kernel 5.15.185-tegra (consistent install). Serial: [SERIAL].
The M.2 Key-E wifi slot detects no card — nothing appears in lspci. The Key-E controller fails to train:
tegra194-pcie 141e0000.pcie: Phy link never came up
The other PCIe controllers on the same board work: NVMe 14160000 and Realtek ethernet 140a0000 both report “Link up” and enumerate in lspci. Only 141e0000 fails.
Two different PCIe wifi cards (incl. an RTL8822CE) were tried in the slot — both fail identically, and both are confirmed working in another machine. Cards were reseated flat under the retention screw with antennas attached; no change. Install is BSP-consistent, so this is not a software/device-tree issue.
This matches the RMA’d case in thread 298198 (official dev kit, two good cards, → RMA). Requesting hardware evaluation / RMA.
(Minor corroborating detail: the ASIX AX88179 USB-GbE adapter on this unit also throws Error submitting the control message: status=-19.)
— 🤖 This is an automated AI response. I’m here to help, but please verify important details! —
The issue described is related to the M.2 Key-E wifi slot on the Jetson Orin Nano Dev Kit, where two known-good wifi cards are not detected, and the Phy link never comes up. The problem is consistent across two different PCIe wifi cards, including an RTL8822CE, and the issue is not resolved by reseating the cards or attaching antennas.
Given the provided context, it appears that the issue is hardware-related, as the installation is consistent with the BSP (R36.5.0 / JetPack 6.2, kernel 5.15.185-tegra), and other PCIe controllers on the board, such as NVMe and Realtek ethernet, are functioning correctly.
The context mentions a similar issue reported in thread 298198, which resulted in an RMA (Return Merchandise Authorization). Based on this information, it seems that a hardware evaluation or RMA might be necessary to resolve the issue.
However, the context does not provide clear steps or troubleshooting methods for the user to attempt before requesting an RMA. Therefore, the next course of action would be to contact the manufacturer or vendor for further assistance and to request an RMA, as the issue appears to be hardware-related and is occurring with multiple known-good wifi cards.
It is also worth noting that the ASIX AX88179 USB-GbE adapter on the unit is throwing an error, but this may be unrelated to the primary issue with the M.2 Key-E wifi slot.
In summary, the issue is likely hardware-related, and the user should contact the manufacturer or vendor for further assistance and to request an RMA.
What is not covered in the provided context is any potential software or configuration-related causes for the issue, as well as any specific troubleshooting steps that the user can attempt before requesting an RMA.
— We support team will also look into your issue to have further suggestions soon. please stay tuned. —
Do you have the rtl8822ce card there? This one shall be in the Orin Nano devkit by default. May test this one first.
Also,
If endpoint excepts some GPIO signals to be toggled as part of power up sequence, make sure that it is happening, Example: Some Wi-Fi cards expects WDISABLE_1 signal to be asserted before PCIe link up.
This is common for wifi card.
