The Orin Nano Dev Kit Carrier Board has an operating temperature range of 0-35 deg C. I understand this isn’t a production device and is meant to reference “typical room temperature.” At what altitude range does this apply? I’m referring to typical ground elevated altitudes like 1000-2000m, not aircraft use cases.
There is no such data can be shared. Generally we did not received failure report for altitudes. 1000-2000m should be ok in theory.
