Orin nano devkit low upload speed
When I test udp bandwidth using iperf, I got around 1000Mbps when jetson is the server. However, when the other pc is the server, the bandwidth and jetson is client, I got around 130 Mbps. Is there any way to increase the second bandwidth?
Please share the steps and commands so that we can set up and replicate the issue. And the latest Jetpack version is 5.1.3. Please check if you use latest version.
Here the commands from server side and the result. I switched the commands for jetson. The jetpack version I use is 5.1.2
Jetpack 6.0GA(r36.3) is released. Please upgrade to the version and give it a try. See if the issue is not observed in latest version.
