Orin Nano devkit: MB1 stalls at bct_mem → blob, deterministic across 3 hosts / 3 cables / 2 configs
Hardware
  • Jetson Orin Nano Developer Kit, official P3768-0000 carrier (no custom carrier)
  • Module: P3767, 8GB
  • BR_CID: 0x80012344705DF1E20C00000003020240
  • Power: bench supply, 19V, 3A limit, barrel jack
  • Target storage: internal microSD
  • BSP: JetPack 6.2.2 (L4T 36.4.4)
The board has never booted successfully since I received it. Original
symptom was power LED on, fan self-test kick, then nothing, with no
display output. I originally assumed outdated factory QSPI firmware and
have been trying to flash it ever since.
Failure signature (bit-identical on every single attempt)
[ x.xxxx ] BL: version 1.4.0.7-t234-54845784-56c609fa last_boot_error: 0
[ x.xxxx ] Sending bct_mem
[ x.xxxx ] Sending blob
[ +0.077s ] ERROR: might be timeout in USB write.
Error: Return value 3
BootROM handshake completes, BR_CID reads out cleanly, MB1 and PSC-BL1
load, MB1 reports last_boot_error: 0. The failure is always at the
transition from bct_mem to blob, always ~77 ms after “Sending blob”.
Eliminated so far
  • 3 different host machines, all native x86_64 Ubuntu, never a VM
    (2x Ubuntu 22.04, 1x Ubuntu 24.04)
  • 3 different USB cables, both A-to-C and C-to-C, all data-capable
  • usbcore.autosuspend=-1 and usbcore.usbfs_memory_mb=2048, verified
    applied via /sys/module/usbcore/parameters/
  • ModemManager stopped, no stale rpcbind, no USB hub in path
  • Payload size: 104 MB (l4t_initrd_flash via SDK Manager) vs 23.7 MB
    (flash.sh with jetson-orin-nano-devkit-qspi, QSPI-only) — identical
    failure at identical offset
  • EMC profile: super config vs non-super config — identical failure
  • SDK Manager and bare flash.sh — identical failure
  • Module removed, edge connector and carrier socket inspected, reseated,
    retested — identical failure
  • No physical damage anywhere: I unscrewed and removed the module and
    inspected both the module and the carrier under good light. Gold
    fingers are clean and evenly plated, no oxidation, no debris, no bent
    or missing contacts in the carrier socket, no visible damage to
    components or traces on either board. Nothing was ever spilled on it,
    dropped, or hot-plugged.
Why I don’t think this is a USB transport problem
  1. dmesg shows NO USB disconnect at the moment of failure. The APX device
    (0955:7523) stays enumerated throughout and after. The board does not
    reset or brown out.
  2. 77 ms is far too fast to be a genuine timeout on a 24 MB transfer over
    USB 2.0 (~700 ms expected). This looks like an endpoint stall, not a
    slow or flaky link.
  3. The failure is perfectly deterministic across every combination above.
    Transport faults are stochastic.
My reading is that MB1 stalls during DRAM bring-up: bct_mem is the
instruction to initialize LPDDR5, and the blob is the first payload that
requires working DRAM. That would also explain the original cold-boot
symptom, since cold boot runs the same training against the mem BCT in
QSPI.
Question
Is there any remaining host-side or configuration cause I have not
eliminated, or does this signature point to a module-level DRAM/PMIC
fault? Is there a way to get MB1 DRAM training output over the debug
UART to confirm?
Note on warranty: this kit was a gift. I still have the original box but
I have no way to find out where or when it was purchased, so I cannot
go back to the reseller. That is what makes this frustrating if it does
turn out to be a hardware fault.
~0930
Hi bytrizzyt,
Have you tried using SDK manager to flash the devkit?
Do you have other Orin Nano devkits with the similar issue?
Please also share the full serial console log for further check.
