I flashed it via SSD. I connected FC REC pin to GND. I successfully flashed Orin nano and turned it on. Orin nano desktop screen opened. When I plugged in the original adapter 1 day later, the power led did not light up and the fan did not spin. When I measured the output of the adapter, I saw 19.5 volts, but when I plugged it into the card, this volt dropped to 2.5. The card does not stand up. The power led does not light up. Why did this happen? What should I do next?
Buy another board. If that voltage is dropping to 2.5v when connected its either the powersupply or the board. If you have a lab supply see what happens when you connect it to that one. Be sure to set the current limit very low like 2.0 amps just to see if it will boot.
