I’m designing a custom carrier board for the Jetson Orin Nano and need two independent displays for my application. I’ve been evaluating my options and have a few questions.
What I’ve confirmed so far:
The Orin Nano’s Display Controller (NVDisplay 4.0) has two heads, with a crossbar that allows the output of any head to be routed to any SOR. The documentation also states that only head0 can be attached to DSI.
The module’s SODIMM connector exposes DSI lanes on pins 70/72 (DSI_D0_N/P), 76/78 (DSI_CLK_N/P), and 82/84 (DSI_D1_N/P).
However, in the official Jetson Orin Nano Pinmux Datasheet, all six of these pins are listed as “RSVD” in the “Jetson Orin Nano Function” column — no DSI function is exposed, while the SoC TRM clearly documents a DSI block connected to head0.
My questions:
Is DSI display output (head0 → DSI) usable on the Jetson Orin Nano module? Or are these pins permanently reserved and not available to custom carrier board designers?
If DSI is not available, is it possible on JetPack 6.x (L4T r36.x) to drive head1 → SOR (DP) and head0 → DSI simultaneously as two independent displays? If yes, could you point me to a device tree example showing the head-to-encoder/SOR binding for this configuration?
As background: our primary plan is to use an external MST hub (DP 1.2, 2×1080p60) on the DP output, which is listed in the Orin Nano datasheet (“MST for 2×1080p60”). We’ve seen forum reports that commercial DP→2×HDMI MST hubs are not validated on Jetson (some fail with no HPD/EDID). If DSI output were available, we could avoid the MST hub entirely, which would be preferable for our design.
Any guidance on whether the RSVD DSI pins can be re-enabled via pinmux/device tree, and whether dual-head (DP + DSI) output is supported in L4T, would be greatly appreciated.
Thank you.
Note: The older Jetson Nano (Tegra210/B01) supported DSI display output via panel DTS files and drivers in the L4T kernel source (e.g., tegra210-p3448-…-hdmi-dsi.dts for an AUO 8" panel). Since the Orin Nano TRM documents the DSI block and head0-only DSI attachment, and the SODIMM pins out the DSI lanes, we expected similar support — but the official pinmux lists these pins as RSVD. Could you clarify the intended status of DSI output on Orin Nano?
