I’ve got a device with an Orin Nano module. I have burned fuses for the PKC Hash, SBK and OemK1 keys. I’ve got my Linux builds installed and running without problem. This is the (redacted) fuse-burning XML file so far:
<genericfuse MagicId="0x45535546" version="1.0.0">
<fuse name="PublicKeyHash" size="64" value="redacted"/>
<fuse name="SecureBootKey" size="32" value="redacted"/>
<fuse name="OemK1" size="32" value="redacted"/>
<fuse name="BootSecurityInfo" size="4" value="0x3E9"/>
</genericfuse>
At this point, we are moving forward and want to further secure the module. Having reviewed the Fuse Specification document, I think I will want to burn these additional fuses:
OdmId. Burn a product-specific ID number. I don’t think this value should have any effect on running software.ArmJtagDisable. Set to0x01to disable all JTAG and SWD debuggingDebugAuthentication. Set to0x1Fto disable the five Arm debug capabilities.- Is this necessary? Or does setting
ArmJtagDisableautomatically take care of this? - And if I burn both this and
ArmJtagDisable, will it create a problem?
SecurityMode. Set to0x01to prevent further fuse burning
There are few other fuses I saw mentioned in the documentation, which I am much less clear about, and would like some advice:
CcplexDfdAccessDisable. Set to0x01. But I’m not clear about what the CCPLEX DFD actually is. Does it matter? Is it a potential security problem to not disable this access? Or will disabling this break Linux power management?OptInEnable. Set to0x01. It is documented as permitting field-burning of NV fuses, including ratchet and PKC-revocation. But the docs are not clear if setting this to0x01is needed to permit ratchet and key-revocation, or if that value disables the capability.- The developer guide shows this being set in the example setting three PKC hashes. So I’m thinking maybe we should also set this if we think we may need to use the ratchet feature in the future.
Also, the Fuse Specification document mentions several fuses that do not appear in the Orin Reference Fuse Configuration file (from the documentation). Should I care about any of them? And if they matter, how do I burn them if they’re not described in the XML?
Finally, I know that modules manufactured after January 2025 have BootSecurityInfo pre-burned as 0x1E0. If we have some older modules that don’t have these bits pre-burned, will it break anything to burn them? If yes, then we’ll need to construct two XML files and ensure that we use the correct one for a module. If no, then we can just use the same file for every module, which would certainly be more convenient.
