Orin nano has an error using SDKManager for graphical burning!
The core board is Orin nano, without emmc, and is intended to flicker into nvme.
top1:
top2:
top3:
top4:
The log is as follows:
SDKM_logs_JetPack_5.1.2_Linux_for_Jetson_Orin_Nano_modules_2024-01-19_09-00-02.zip (137.7 KB)
請抓serial console log
flashing log只有timeout看不出任何東西
https://jetsonhacks.com/2019/04/19/jetson-nano-serial-console/
這是串口log輸出:
MobaXterm_COM4USB-SERIALCH340COM41_20240119_135620.txt (38.1 KB)
I> Task: Prepare eeprom data (0x50018ac4)
E> I2C: slave not found in slaves.
E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
E> I2C_DEV: Failed to send register address 0x00000000.
E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x000000
E> eeprom: Failed to read I2C slave device
C> Task 0x0 failed (err: 0x1f1e050d)
E> Top caller module: I2C_DEV, error module: I2C, reason: 0x0d, aux_info: 0x05
I> Busy Spin
你的custom carrier board上沒有EEPROM的話要改這一段
https://docs.nvidia.com/jetson/archives/r35.4.1/DeveloperGuide/text/HR/JetsonModuleAdaptationAndBringUp/JetsonOrinNxNanoSeries.html#eeprom-modifications
請不要用SDK Manager
用指令的方式確保你燒進去的東西是正確改過的
非常感谢,问题解决了。
很抱歉打扰您,能帮我看看这个问题吗?很急!!!Jetson orin nano Waiting for target to boot-up... Timeout
