As show in the screenshot, the official announce ISP Processing image is 10 million pixels,I want to ensue whether if the CMOS sensor output is 12M pixel,the ISP cloud process the RAW(Bayer) data ?If not supported, is there any configuration that can improve the processing capacity of the ISP。
actually, Orin Nano’s ISP is capable to mostly camera sensors. the limitation usually on the CSI/VI side.
may I know what’s camera sensor you’re using?
The sensor we using is IMX226CQJ-C,The IMX226CQJ-C is a diagonal 9.33 mm (Type 1/1.7) CMOS image sensor with a color square pixel array and approximately 12.4M effective pixels.
okay, that image resolution, and bits per pixels looks supported.
you may also refer to Toshiba bridge driver, tc358840, which present at TX2, or Xavier series device tree for your driver implementation.
thanks
