Orin nano J20 and J21 connect a camera respectively,but J21 camera can not working properly, will stall within a few minutes of starting
Using an unofficial carrier board, paired with the orin nano’s core board.
J20 and J21 are each connected with one imx335 camera, bus 9(J21) will jam after running for a while, bus 10(J20)can run all the time.
What’s the version? Get the trace log to check.
cat /etc/nv_tegra_release
https://elinux.org/Jetson/l4t/Camera_BringUp
version is
R35 (release), REVISION: 3.1, GCID: 32827747, BOARD: t186ref, EABI: aarch64, DATE: Sun Mar 19 15:19:21 UTC 2023
what is the difference between carrier board p3767-0005 and p3767-0003?
what is the difference between core board p3767-0005 and p3767-0003?
Can i use core board (p3767-0005) with carrier board (p3767-0003)?
thank you
Please refer to developer guide for the supported devices:
Welcome — NVIDIA Jetson Linux Developer Guide 1 documentation
It seems to be an issue in sensor driver. Please share vendor of the IMX335 board for reference.
hello, we use veye imx335 camera module and driver.
veye
dtb diriver
github resp
