Orin Nano Jetson Clocks Question
How do I turn on Jetson Clocks by default at startup on my orin nano devkit? I’ve autologin on.
Hi coded7,
Do you mean the sudo jetson_clocks?
You can add this command to any script which will be run during boot up.
Thanks! Also, prolonged use with jetson_clocks at max won’t affect the devkit and the orin nano module right?
It’s okay to be used jetson_clocks but we would suggest you also using the custom power mode for your specific use case rather than MAXN mode.
I’m using the 15W mode, instead of the 7W as the application demands it. Is that okay?
It should be fine to use 15W mode. Please just do not use MAXN mode to prevent the OC throttling issue.
Thank you for the clarification!
