jtlee
1
I tried to kernel build and booting, but failed in Orin Nano.
I used L4T 35.3.1 kernel source and just building.
I attached booting log with kernel panic.
Please check kernel build for Orin Nano.
Thank you.
orinnanokernelpanic.txt (64.3 KB)
can you share the whole workflow of what you did?
Did you follow every steps shown below to build the kernel, and was there any modification to the kernel code?
https://docs.nvidia.com/jetson/archives/r35.2.1/DeveloperGuide/text/SD/Kernel/KernelCustomization.html#to-build-the-kernel
Also, did the flash succeed after the manually built kernel component was swapped?
system
Closed
4
