Referring to Pins 219, 221, 223, 225 which now look to be used for PCIE2/3 signals.
Can these pins be used as GPIOs? Are they 1.8V?
It looks like on the pin mux, some of them are pulled to 3.3V - is there any way to turn this off?
Hi daniel174,
Are you using the devkit or custom board for Orin Nano?
Do you mean the following 4 pins?
If you don’t use them for PCIe, you could configure them as GPIO (PAG.00, PAG.01, PAG.04, PAG.05) in pinmux spreadsheet and apply the generated dtsi to your BSP package.
Yes, I mean those pins. We are trying to build a custom board and looking to use these as GPIO.
Are they 1.8V? It looks like on the pin mux, some of them are pulled to 3.3V - is there any way to turn this off?
We are currently on 35.3.1.
These pins are pulled up to 3.3V on module, can’t be disabled.
