For Jetson Orin Nano, is there a restriction on how long can the POWER_EN be held low from the time VDD_IN is stable? minimum and maximum?
Our custom carrier does not have an On/Off switch, as the system suppose to be on all the time, only off when power is removed. The carrier is working fine, but I would like to lengthen the time when software sends POWERDOWN_REQ to when the carrier hardware sends back POWER_EN and have an indicator so operator knows it’s safe to pull power off.
Thanks,
