Orin Nano/NX: GPIO as Interrupt source
I’m designing a custom carrier board. I need some interrupt pins.
Example: This part NXP SC16IS762IBS to Orin NX/Nano SPI0.
https://www.nxp.com/part/SC16IS762IBS#/
CS, SCK, MISO, MOSI, Reset are easy.
This SPI slave has got an IRQ pin. Where do I connect this? In the pinmux Excel sheet I can select Input, Bidirectional, Output, I can select internal pullups and pulldowns but no interrupts.
Can I use any GPIO as interrupt pin? If not, where is the list of interrupt capable pins?
You can use the “wake #” pins that you can find in the pinmux sheet.
