Orin nano 在修改p3767.conf.common里的配置成ODMDATA=“gbe-uphy-config-9,hsstp-lane-map-3,hsio-uphy-config-0”;烧录系统报错
烧录后启动打印ERROR: Exception reason=0 syndrome=0xbe000011
ERROR: **************************************
ERROR: RAS Uncorrectable Error in IOB, base=0xe010000:
ERROR: Status = 0xec000612
ERROR: SERR = Error response from slave: 0x12
ERROR: IERR = CBB Interface Error: 0x6
ERROR: Overflow (there may be more errors) - Uncorrectable
ERROR: MISC0 = 0xc44e0040
ERROR: MISC1 = 0x13cc860000000000
ERROR: MISC2 = 0x0
ERROR: MISC3 = 0x0
ERROR: ADDR = 0x8000000003f300c0
ERROR: sdei_dispatch_event returned -1
Unhandled Exception in EL3.
x30 = 0x0000000050011384
x0 = 0x0000000000000000
x1 = 0x0000000000000000
x2 = 0x0000000000000002
x3 = 0x0000000000000001
x4 = 0x0000000000000000
x5 = 0x0000000000000040
x6 = 0x0000000000000000
x7 = 0x0000000000000002
x8 = 0x0000000050001f74
x9 = 0x0000000000000000
x10 = 0x0000000000011254
x11 = 0x000000026e9fe84c
x12 = 0x000000026e555000
x13 = 0x0000000000011254
x14 = 0x0000000267da83a8
x15 = 0x000000026e555000
x16 = 0x0000000268634cd4
x17 = 0x0000000031507a45
x18 = 0x0000000000000000
x19 = 0x0000000003f300c4
x20 = 0x000000026618e020
x21 = 0x0000000266184e40
x22 = 0x0000000000000001
x23 = 0x0000000000000023
x24 = 0x000000000000005a
x25 = 0x00000002684c3574
x26 = 0x00000002684c3589
x27 = 0x000000004c553250
x28 = 0x0000000267da81c8
x29 = 0x000000026e9fe850
scr_el3 = 0x000000000003073d
sctlr_el3 = 0x00000000b0cd183f
cptr_el3 = 0x0000000000000000
tcr_el3 = 0x0000000080823518
daif = 0x00000000000003c0
mair_el3 = 0x00000000004404ff
spsr_el3 = 0x00000000600003cd
elr_el3 = 0x0000000050011384
ttbr0_el3 = 0x0000000050026ac1
esr_el3 = 0x0000000002000000
far_el3 = 0x0000000000000000
spsr_el1 = 0x0000000000000000
elr_el1 = 0x0000000000000000
spsr_abt = 0x0000000000000000
spsr_und = 0x0000000000000000
spsr_irq = 0x0000000000000000
spsr_fiq = 0x0000000000000000
sctlr_el1 = 0x0000000030d00800
actlr_el1 = 0x0000000000000000
cpacr_el1 = 0x0000000000300000
csselr_el1 = 0x0000000000000000
sp_el1 = 0x0000000000000000
esr_el1 = 0x0000000000000000
ttbr0_el1 = 0x0000000000000000
ttbr1_el1 = 0x0000000000000000
mair_el1 = 0x0000000000000000
amair_el1 = 0x0000000000000000
tcr_el1 = 0x0000000000000000
tpidr_el1 = 0x0000000000000000
tpidr_el0 = 0x0000000080000000
tpidrro_el0 = 0x0000000000000000
par_el1 = 0x0000000000000800
mpidr_el1 = 0x0000000081000000
afsr0_el1 = 0x0000000000000000
afsr1_el1 = 0x0000000000000000
contextidr_el1 = 0x0000000000000000
vbar_el1 = 0x0000000000000000
cntp_ctl_el0 = 0x0000000000000005
cntp_cval_el0 = 0x000000000e46e1ba
cntv_ctl_el0 = 0x0000000000000000
cntv_cval_el0 = 0x0000000000000000
cntkctl_el1 = 0x0000000000000000
sp_el0 = 0x00000002687bb2f0
isr_el1 = 0x0000000000000040
cpuectlr_el1 = 0xa000000b40543000
gicd_ispendr regs (Offsets 0x200 - 0x278)
Offset: value
0000000000000200: 0x0000000000000000
0000000000000204: 0x0000000000000000
0000000000000208: 0x0000000000000000
000000000000020c: 0x0000000000000000
0000000000000210: 0x0000000000000000
0000000000000214: 0x0000000000000000
0000000000000218: 0x0000000000010000
000000000000021c: 0x0000000000000000
0000000000000220: 0x0000000000000000
0000000000000224: 0x0000000000000000
0000000000000228: 0x0000000000000000
000000000000022c: 0x0000000000000000
0000000000000230: 0x0000000000000000
0000000000000234: 0x0000000000000000
0000000000000238: 0x0000000000000000
000000000000023c: 0x0000000000000000
0000000000000240: 0x0000000000000000
0000000000000244: 0x0000000000000000
0000000000000248: 0x0000000000000000
000000000000024c: 0x0000000000000000
0000000000000250: 0x0000000000000000
0000000000000254: 0x0000000000000000
0000000000000258: 0x0000000000000000
000000000000025c: 0x0000000000000000
0000000000000260: 0x0000000000000000
0000000000000264: 0x0000000000000000
0000000000000268: 0x0000000000000000
000000000000026c: 0x0000000000000000
0000000000000270: 0x0000000000000000
0000000000000274: 0x0000000000000000
0000000000000278: 0x0000000000000000
000000000000027c: 0x0000000000000000
3f300c0 is on PCIe C7/C9.
What is your actual hardware design there? Which Jetpack release is in use?
我使用的是35.6.2,pcie修改如下
How did you update the device tree?
I mean after you changed the content. What files did you replace?
修改后编译生成了一个新的tegra234-p3767-0003-p3768-0000-a0.dtb文件,然后把这个文件替换系统下面/boot/dtb/下面原来的kernel_tegra234-p3767-0003-p3768-0000-a0.dtb,然后重启系统
上面这个是在没有修改ODMDATA的情况下更新设备树的,而我在更新了ODMDATA之后烧录系统就失败了,并没有在源码里面去同步修改设备树,我一般是在系统烧录成功后再去更新设备树的
You need to update device tree right before flashing.
OK,I well give it a try.
我按照文档的介绍替换了Image和编译的dtb之后,重新烧录系统一直卡在waiting for target to boot-up
確認一下UART log
uart.log (86.1 KB)请帮忙看一下,一直就卡在waiting for target to boot-up
usb device mode沒有起來.
大部分原因都是你們的底板跟原本NV devkit的usb設定不一致造成的
請照文件更改device tree部份去配合你們的底板設計
在设备树里面我把otg接口改成了host模式对这个是否有影响
有影響. initrd flash會看device tree. 你這樣做基本上就是把device mode完全關掉了.
再次修改的话需要清理一下之前的编译吗,还是说修改后拷贝进去再次刷机就可以覆盖掉之前的烧录
问题解决了,谢谢
