We are provisioning a Jetson Orin Nano 8GB devkit (P3768-0000 carrier, P3767-0005 module) on L4T r36.4.4 as a production customer unit, and we have one question we would rather confirm than infer, because the operation is irreversible.
Goal: burn OemK1 as the EKB fuse key for disk encryption (LUKS via OP-TEE luks-srv). We are NOT enabling secure boot, no PKC and no SBK, and we are NOT burning SecurityMode.
Current fuse state, read with odmfuseread.sh on this board:
PublicKeyHash: 0000…0000 (blank)
BootSecurityInfo: 000001e0
SecurityMode: 00000000
ArmJtagDisable: 00000000
OdmLock: 00000000
ReservedOdm0-7: 00000000
BootSecurityInfo reads 0x1e0, so bit 9 (ODM Key Valid) is 0, which we take to mean OemK1 is not programmed. Please confirm that reading.
1. What exact BootSecurityInfo value should we write when burning OemK1?
This board already has bits 5-8 set (0x1e0). Since fuses only transition 0 to 1, we assume we should write 0x3e0 (0x1e0 OR 0x200) so the requested value matches what the register will read afterwards. Your sample configurations show bare values such as 0x200, which we assume come from boards whose other bits were zero.
If we write 0x200 on this board, will odmfuse treat it as set bit 9, or will it fail verification because the register reads back 0x3e0?
2. Is bit 9 required for our configuration at all?
We are using OemK1 only as the EKB fuse key for disk encryption, with no SBK and no PKC. Does ODM Key Valid need to be set for OP-TEE to load OemK1 and open the EKB, or is it only required in SBK and secure-boot configurations?
3. Ordering within the fuse XML.
The documentation states that odmfuse.sh burns fuses in the order they appear and does not check dependencies. Should OemK1 be declared before BootSecurityInfo?
4. Is anything else required in the SAME operation?
The documentation recommends burning everything needed in a single operation. For an EKB-only configuration on r36.4.4, is OemK1 plus BootSecurityInfo bit 9 the complete set?
What we have already done
We have run odmfuse.sh --test successfully with the XML below, and have not burned anything. The key value is redacted.
<genericfuse MagicId=“0x45535546” version=“2.0.0”>
<fuse name=“OemK1” size=“32” value=“0xREDACTED” />
<fuse name=“BootSecurityInfo” size=“4” value=“0x3e0” />
</genericfuse>
The dry run completes, the 128-byte fuse blob builds, and FSKP runs to completion under the TEST magic ID.
Separate bug report: tegraparser_v2 segfaults on a missing size attribute
If the size attribute is omitted from a fuse element, tegraparser_v2 --fuse_info segfaults rather than reporting an error. With size it works:
<fuse name=“OemK1” size=“32” value=“0x…” />
Without size it dies with SIGSEGV (core dumped):
<fuse name=“OemK1” value=“0x…” />
An empty genericfuse element parses fine. ANY fuse element without a size attribute segfaults, including one with a nonexistent fuse name. strace shows the tool opening the XML and immediately dereferencing NULL, with no other file access. Reproduced on r36.4.4, both inside and outside a container.
A clear error message here would help. On a board sitting in RCM, a segfault from the fusing tool reads as a hardware fault rather than a malformed input file.
Thank you,
Pavana Manjunath
Eldaeon
