Orin Nano - Time date synchronization
When i am using WIFI, datetime is synchronizing perfectly.
when I am using ethernet, datetime is not synchronizing after reboot…
what is the issue here…? how to solve this.?
i tried all ntp things available on internet.
Please share which Jetpack version you are using. If you use previous version, would suggest upgrade to Jetpack 6.1 and try. To check if the issue is present on latest release.
Hi, thanks for quick reply.
That is my version. check it.
my version is 6.1 only
yes the problem is there
need help
Please share the steps and we will set up Orin Nano developer kit to check.
what are the steps you are looking for…?
We would like to replicate the non-synchronization on Orin Nano developer kit. Would need your help to share one-by-one steps so that we can set up and try.
I need step by step instructions. Please share. We will setup time
Please refer to the topic and give it a try:
Unable to sync the system clock of jeston orin to internet time
I followed all the steps which are there in this. still not synced.
an error like : Timed out waiting for a reply from 158.220.97.17.123(0.pool.ntp.org)
