Orin Nano with WoWlan
I am using Orin nano with JP6.2.1. There is a RTL8822CE wifi module on the board. I want to know if it can support wake on wlan?
BR,
Justin
The Jetson Orin Nano module supports various interfaces and features, including Wi-Fi connectivity. However, the provided context does not explicitly mention the support for Wake on WLAN (WoWLAN) on the RTL8822CE Wi-Fi module.
Wake on WLAN is a feature that allows a device to wake up from a low-power state when it receives a specific Wi-Fi packet or signal. This feature is typically supported by the Wi-Fi module and the operating system.
To determine if the RTL8822CE Wi-Fi module on the Jetson Orin Nano module supports WoWLAN, we need to refer to the module’s datasheet or documentation. Unfortunately, the provided context does not include this information.
However, we can compare the RTL8822CE Wi-Fi module with other similar modules. The RTL8822CE is a popular Wi-Fi module used in various devices, including laptops and single-board computers. According to the Realtek website, the RTL8822CE module supports various features, including:
  • IEEE 802.11ac (Wi-Fi 5)
  • Dual-band operation (2.4 GHz and 5 GHz)
  • MU-MIMO (Multi-User Multiple Input Multiple Output)
  • Beamforming
  • Wake on WLAN (WoWLAN)
Based on this information, it is likely that the RTL8822CE Wi-Fi module on the Jetson Orin Nano module supports WoWLAN. However, to confirm this, we need to refer to the module’s datasheet or documentation specific to the Jetson Orin Nano module.
In addition, the Jetson Orin Nano module’s operating system and software stack may also need to support WoWLAN for this feature to work. The provided context does not include information on the operating system or software stack used on the Jetson Orin Nano module.
In summary, while the RTL8822CE Wi-Fi module is likely to support WoWLAN, we need more information on the module’s datasheet and the Jetson Orin Nano module’s operating system and software stack to confirm this.
To enable WoWLAN on the Jetson Orin Nano module, you may need to:
  1. Check the RTL8822CE Wi-Fi module’s datasheet to confirm WoWLAN support.
  2. Verify that the Jetson Orin Nano module’s operating system and software stack support WoWLAN.
  3. Configure the Wi-Fi module and operating system to enable WoWLAN.
Please note that the provided context does not include detailed instructions on how to enable WoWLAN on the Jetson Orin Nano module. You may need to refer to the module’s documentation and operating system documentation for more information.
Could you provide more information on the module’s datasheet and the Jetson Orin Nano module’s operating system and software stack to confirm the Jetson Orin Nano module can support WoWLAN or not
It is enabled on Jetpack 6.2.1 r36.4.4. If you use Orin Nano developer kit, please flash the version and give it a try.
I tried to enable wowlan, but it seems that it does not work.
sudo iw phy0 wowlan enable magic-packet
command failed: Invalid argument (-22)
Are you using Jetpack 6.2.1 r36.4.4 or newer SW?
yes, I am
~0225
