Orin nano4GB 使用Basic Flavor Root File System 刷机报错
开发套件:orin nano4GB
开发工具:jetpack5.1.1
开发环境:R35.3.1
开发环境系统:ubuntu20.4
文件系统获取方式:Root File System — Jetson Linux Developer Guide documentation
$ sudo ./nv_build_samplefs.sh --abi aarch64 --distro ubuntu --flavor basic --version focal
获取的文件系统。
烧录过程信息:
debug.txt (195.8 KB)
尝试过使用Desktop Flavor Root File System 可以正常烧录,但是使用Basic Flavor Root File System烧录失败。
Based on the provided context, I’ll address the question and provide a comprehensive answer.
The question seems to be asking about the Jetson Orin Nano, specifically the 4GB version, and its compatibility with JetPack 5.1.1, R35.31, Ubuntu 20.04, and the Root File System. Additionally, it mentions the sudo nvbuildsamplefssh command and its output.
Here’s a breakdown of the information:
  1. Jetson Orin Nano 4GB: This is a specific module from the Jetson Orin Nano series, which is a production module (P3767-0004) according to the table in the context.
  2. JetPack 5.1.1: This is a software development kit (SDK) for NVIDIA Jetson modules. The context mentions JetPack 6.2, but the question specifically asks about JetPack 5.1.1.
  3. R35.31: This is likely a reference to the NVIDIA JetPack SDK version, which includes the Linux kernel, device drivers, and other software components.
  4. Ubuntu 20.04: This is the Linux distribution used as the root file system on the Jetson module.
  5. Root File System: This refers to the file system that contains the operating system, device drivers, and other essential software components.
  6. sudo nvbuildsamplefssh: This command is used to build and flash the file system on the Jetson module. The output of this command is mentioned in the question, specifically the debug.txt file with a size of 1958 KB.
Now, let’s address the question:
  • The Jetson Orin Nano 4GB module is supported by JetPack 5.1.1, R35.31, and Ubuntu 20.04, as per the NVIDIA Jetson Linux Developer Guide.
  • The sudo nvbuildsamplefssh command is used to build and flash the file system on the Jetson module. The output of this command, including the debug.txt file, is likely related to the build and flash process.
  • The Root File System for the Jetson Orin Nano 4GB module is based on Ubuntu 20.04, which is a supported distribution for this module.
In comparison to other Jetson modules, the Orin Nano 4GB has similar requirements and compatibility as other modules in the Orin Nano series. However, the specific details may vary depending on the module and software versions used.
In summary, the Jetson Orin Nano 4GB module is compatible with JetPack 5.1.1, R35.31, and Ubuntu 20.04, and the sudo nvbuildsamplefssh command is used to build and flash the file system on this module. The Root File System is based on Ubuntu 20.04, which is a supported distribution for this module.
我需要如何解决这个问题?如何才能成功刷机?我需要使用Basic Flavor Root File System。
請問可以使用 JP 5.1.5 來確認 Basic Flavor Root File System 是否燒錄正常?
謝謝
感谢您的帮助。我这边没有JP5.1.5.我这边用的是5.1.1。但是jp5.1.1 我使用Desktop Flavor Root File System,打补丁Overlay_PCN210361_PCN210100_r35.3.1.tbz2 可以刷固件,但是Basic Flavor Root File System烧录失败。
了解
請問可以提供 serial console log 在 flash with Basic Flavor Root File System嗎?
謝謝
串口debug.txt (16.2 KB)
感谢您的回复!谢谢!
想請問是使用 dev kit 還是 custom board呢?
謝謝
使用的orin nano4GB套件。工具jetpack5.1.1。
請嘗試使用 JP5.1.5 的 basic flavor rfs 來確認是否問題再出現。
謝謝
