https://developer.nvidia.com/downloads/assets/embedded/secure/jetson/orin_nano/docs/jetson_orin_nano_devkit_carrier_board_reference_design_files_a04_20230320.zip/
请问一下我是否可以参考这个,绘制我们自己的PCB底板?使用orin nano4GB核心板。
Based on the provided context, I will provide a comprehensive answer to the question.
The Jetson Orin Nano is a series of modules that are part of the NVIDIA Jetson family. The specific module mentioned in the question is the Jetson Orin Nano 4GB (P3767-0004).
According to the context, the Jetson Orin Nano 4GB (P3767-0004) is a commercial module that is part of the NVIDIA Jetson Orin Nano series. It is compatible with the Jetson Orin Nano Developer Kit (P3766), which includes the P3767-0005 module.
The Jetson Orin Nano 4GB (P3767-0004) has a similar partition configuration to other modules in the NVIDIA Jetson Orin Nano series, including the Jetson Orin Nano 8GB (P3767-0003) and the Jetson Orin Nano 8GB (P3767-0005).
In terms of flashing, the Jetson Orin Nano 4GB (P3767-0004) requires flashing through initrd instead of flash.sh. The configuration file for this module is jetson-orin-nano-devkit.conf or jetson-orin-nano-devkit-super.conf, which has a higher power budget and extended clock-frequency steps compared to the standard configuration.
The Jetson Orin Nano 4GB (P3767-0004) is also mentioned in the context of thermal management, with a discussion on the NVIDIA Orin Nano Dev kit heating up quickly.
In comparison to other modules, the Jetson Orin Nano 4GB (P3767-0004) has a lower DRAM capacity compared to the Jetson Orin Nano 8GB (P3767-0003) and the Jetson Orin Nano 8GB (P3767-0005). However, it is still a powerful module that is part of the NVIDIA Jetson Orin Nano series.
In terms of the PCB design files, the context mentions that the Jetson Orin Nano 4GB (P3767-0004) has a reference design file available for download, which includes the PCB design files.
Overall, the Jetson Orin Nano 4GB (P3767-0004) is a commercial module that is part of the NVIDIA Jetson Orin Nano series, with a similar partition configuration to other modules in the series. It requires flashing through initrd and has a configuration file with a higher power budget and extended clock-frequency steps. The module is also mentioned in the context of thermal management and has a lower DRAM capacity compared to other modules in the series.
You should also refer to Jetson Orin NX Series and Orin Nano Series Design Guide
非常感谢!!!
