OK, here’s the result of doing that.
L4T BSP Information:
R35 , REVISION: 1.0
Target Board Information:
Name: jetson-agx-orin-devkit, Board Family: t186ref, SoC: Tegra 234,
OpMode: production, Boot Authentication: NS,
Disk encryption: disabled ,
copying emc_fuse_dev_params(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct-diag-boot.dts)… done.
copying device_config(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-device-p3701-0000.dts)… done.
copying misc_config(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-misc-p3701-0000.dts)… done.
./tegraflash.py --chip 0x23 --applet “/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/mb1_t234_prod.bin” --skipuid --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3701-0000.dts --misc_config tegra234-mb1-bct-misc-p3701-0000.dts --bins “mb2_applet applet_t234.bin” --cmd “dump eeprom cvm cvm.bin; dump custinfo custinfo_out.bin; reboot recovery”
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0238 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.0249 ] File rcm_state open failed
[ 0.0254 ] ERROR: failed to read rcm_state
[ 0.0254 ]
[ 0.0264 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.0266 ] Assuming zero filled SBK key
[ 0.0258 ] Pre-processing config: tegra234-mb1-bct-device-p3701-0000.dts
[ 0.0535 ] Pre-processing config: tegra234-mb1-bct-misc-p3701-0000.dts
[ 0.1614 ] Parsing partition layout
[ 0.1664 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.1688 ] Parsing partition layout
[ 0.1701 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.1718 ] Creating list of images to be signed
[ 0.2062 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[ 0.2076 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.2087 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.2092 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.2135 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.2141 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.2195 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.2198 ] adding BCH for mb2_t234_aligned.bin
[ 0.2227 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.2371 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.2375 ] adding BCH for mb2_t234_aligned.bin
[ 0.2545 ] Generating signatures
[ 0.2555 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.2559 ] Assuming zero filled SBK key
[ 0.2855 ] Warning: pub_key.key is not found
[ 0.2849 ] Parsing dev params for multi chains
[ 0.2949 ] Generating br-bct
[ 0.3102 ] Updating dev and MSS params in BR BCT
[ 0.3104 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.3120 ] Updating bl info
[ 0.3134 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.3148 ] WARNING: boot chain is not completed. set to 0
[ 0.3160 ] Get Signed section of bct
[ 0.3169 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[ 0.3186 ] Signing BCT
[ 0.3196 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.3200 ] Assuming zero filled SBK key
[ 0.3245 ] Sha saved in br_bct_BR.sha
[ 0.3248 ] Warning: pub_key.key is not found
[ 0.3239 ] Updating BCT with signature
[ 0.3254 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[ 0.3267 ] Offset :4608 Len :3584
[ 0.3275 ] Generating SHA2 Hash
[ 0.3284 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[ 0.3287 ] Assuming zero filled SBK key
[ 0.3323 ] Sha saved in br_bct_BR.sha
[ 0.3319 ] Updating BCT with SHA2 Hash
[ 0.3330 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[ 0.3340 ] Offset :4608 Len :3584
[ 0.3343 ] Offset :68 Len :8124
[ 0.3347 ] Generating coldboot mb1-bct
[ 0.3358 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.3367 ] MB1-BCT version: 0.9
[ 0.3386 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.3389 ] Added Platform Config 9 data with size :- 80
[ 0.3389 ]
[ 0.3390 ] Updating mb1-bct with firmware information
[ 0.3401 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.3435 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 0.3462 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[ 0.3476 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[ 0.3502 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.3504 ] Assuming zero filled SBK key
[ 0.3532 ] Warning: pub_key.key is not found
[ 0.3536 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.3558 ] Generating recovery mb1-bct
[ 0.3569 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.3581 ] MB1-BCT version: 0.9
[ 0.3607 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.3610 ] Added Platform Config 9 data with size :- 80
[ 0.3610 ]
[ 0.3611 ] Updating mb1-bct with firmware information
[ 0.3626 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.3665 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[ 0.3691 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[ 0.3704 ] adding BCH for mb1_bct_MB1_aligned.bct
[ 0.3727 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.3729 ] Assuming zero filled SBK key
[ 0.3753 ] Warning: pub_key.key is not found
[ 0.3757 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.3779 ] Error: Skip generating mem_bct because sdram_config is not defined
[ 0.3780 ] Error: Skip generating mem_bct because sdram_config is not defined
[ 0.3780 ] Copying signatures
[ 0.3790 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.3869 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 0.3872 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 0.3872 ] Boot Rom communication
[ 0.3885 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 0.3900 ] BR_CID: 0x80012344705DD10F2000000013FF0200
[ 0.4756 ] Sending bct_br
[ 0.5588 ] Sending mb1
[ 0.5595 ] Sending psc_bl1
[ 0.5682 ] Sending bct_mb1
[ 0.5737 ] Boot Rom communication completed
[ 0.5769 ] tegrahost_v2 --chip 0x23 0 --align applet_t234_aligned.bin
[ 0.5793 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --appendsigheader applet_t234_aligned.bin zerosbk
[ 0.5804 ] adding BCH for applet_t234_aligned.bin
[ 0.5929 ] tegrasign_v3.py --key None --list applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.5931 ] Assuming zero filled SBK key
[ 0.5966 ] Warning: pub_key.key is not found
[ 0.5970 ] tegrahost_v2 --chip 0x23 0 --updatesigheader applet_t234_aligned_sigheader.bin.encrypt applet_t234_aligned_sigheader.bin.hash zerosbk
[ 0.5996 ] Sending mb2_applet…
[ 0.6011 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download applet applet_t234_sigheader.bin.encrypt
[ 0.6028 ] BL: version 0.23.0.0-t234-54845784-92215740 last_boot_error: 0
[ 0.7591 ] Sending applet
[ 0.8789 ] completed
[ 0.8809 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.8824 ] MB2 Applet version 01.00.0000
[ 1.0758 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 1.0774 ] MB2 Applet version 01.00.0000
[ 1.1626 ] Retrieving board information
[ 1.1637 ] tegrarcm_v2 --chip 0x23 0 --oem platformdetails chip chip_info.bin
[ 1.1651 ] MB2 Applet version 01.00.0000
[ 1.2491 ] Saved platform info in chip_info.bin
[ 1.2545 ] Chip minor revision: 1
[ 1.2546 ] Bootrom revision: 0x7
[ 1.2547 ] Ram code: 0x0
[ 1.2548 ] Chip sku: 0xd0
[ 1.2549 ] Chip Sample: prod
[ 1.2558 ] Retrieving EEPROM data
[ 1.2558 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/cvm.bin --chip 0x23 0
[ 1.2575 ] MB2 Applet version 01.00.0000
[ 1.3408 ] Saved platform info in /home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/cvm.bin
[ 1.3755 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 1.3770 ] MB2 Applet version 01.00.0000
[ 1.4671 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 1.4684 ] MB2 Applet version 01.00.0000
[ 1.5532 ] Dumping customer Info
[ 1.5553 ] tegrarcm_v2 --chip 0x23 0 --oem dump bct tmp.bct
[ 1.5568 ] MB2 Applet version 01.00.0000
[ 1.6411 ] Saved bct in tmp.bct
[ 1.6506 ] tegrabct_v2 --brbct tmp.bct --chip 0x23 0 --custinfo /home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/custinfo_out.bin
[ 1.6526 ] C[ 1.6533 ] ustomer data saved in /home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/custinfo_out.bin successfully
[ 1.6534 ] Rebooting to recovery mode
[ 1.6555 ] tegrarcm_v2 --chip 0x23 0 --ismb2
[ 1.7432 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 1.7449 ] MB2 Applet version 01.00.0000
[ 1.8291 ] Booting to recovery mode
[ 1.8312 ] tegrarcm_v2 --chip 0x23 0 --reboot recovery
[ 1.8325 ] MB2 Applet version 01.00.0000
Board ID(3701) version(500) sku(0000) revision(H.0)
Copy /home/dr_b/YorLabs/Xavier/Linux_for_Tegra/kernel/dtb/tegra234-p3701-0000-p3737-0000.dtb to /home/dr_b/YorLabs/Xavier/Linux_for_Tegra/kernel/dtb/tegra234-p3701-0000-p3737-0000.dtb.rec
copying bctfile(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-p3701-0000-p3737-0000-TE990M-sdram.dts)… done.
copying pinmux_config(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-pinmux-p3701-0000.dtsi)… done.
copying gpioint_config(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-gpioint-p3701-0000.dts)… done.
copying pmic_config(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-pmic-p3701-0000.dts)… done.
copying pmc_config(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-padvoltage-p3701-0000.dtsi)… done.
copying deviceprod_config(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-cprod-p3701-0000.dts)… done.
copying prod_config(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-prod-p3701-0000.dts)… done.
copying scr_config(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb2-bct-scr-p3701-0000.dts)… done.
copying wb0sdram(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-p3701-0000-p3737-0000-TE990M-wb0sdram.dts)… done.
copying bootrom_config(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-reset-p3701-0000.dts)… done.
copying dev_params(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct-p3701-0000.dts)… done.
copying dev_params_b(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct_b-p3701-0000.dts)… done.
copying mb2bct_cfg(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb2-bct-misc-p3701-0000.dts)… done.
Existing pscfwfile(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/pscfw_t234_prod.bin) reused.
Existing pscbl1file(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/psc_bl1_t234_prod.bin) reused.
Existing mtsmcefile(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/mce_flash_o10_cr_prod.bin) reused.
Existing mb2applet(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/applet_t234.bin) reused.
Existing bootloader(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
copying initrd(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/l4t_initrd.img)… done.
Making Boot image… done.
bl is uefi
Not signing of boot.img
Making recovery ramdisk for recovery image…
Re-generating recovery ramdisk for recovery image…
/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/ramdisk_tmp /home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader /home/dr_b/YorLabs/Xavier/Linux_for_Tegra
36144 blocks
gzip: /home/dr_b/YorLabs/Xavier/Linux_for_Tegra/kernel/Image: not in gzip format
_BASE_KERNEL_VERSION=5.10.104-tegra
53066 blocks
Making Recovery image…
copying recdtbfile(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/kernel/dtb/tegra234-p3701-0000-p3737-0000.dtb.rec)… done.
20+0 records in
20+0 records out
20 bytes copied, 0.000382933 s, 52.2 kB/s
Existing sosfile(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
Existing tegraboot(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing cpu_bootloader(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing mb2blfile(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing xusbfile(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/xusb_t234_prod.bin) reused.
Existing dcefile(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/display-t234-dce.bin) reused.
Existing nvdecfile(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/nvdec_t234_prod.fw) reused.
Existing psc_rf(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/psc_rf_t234_prod.bin) reused.
Existing mb2_rf(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/mb2rf_t234.bin) reused.
Existing mb1file(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
Existing bpffile(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/bpmp_t234-TE990M-A1_prod.bin) reused.
Existing scefile(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
Existing camerafw(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/camera-rtcpu-t234-rce.img) reused.
Existing apefile(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/adsp-fw.bin) reused.
Existing spefile(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/spe_t234.bin) reused.
Existing wb0boot(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/sc7_t234_prod.bin) reused.
Existing tosfile(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/tos-optee_t234.img) reused.
Existing eksfile(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/kernel/dtb/tegra234-p3701-0000-p3737-0000.dtb)… done.
Copying nv_boot_control.conf to rootfs
Not signing of kernel-dtb
populating kernel to rootfs… done.
populating initrd to rootfs… done.
populating kernel_tegra234-p3701-0000-p3737-0000.dtb to rootfs… done.
No signing of initrd and extlinux.conf
Making system.img…
Setting “FDT /boot/dtb/kernel_tegra234-p3701-0000-p3737-0000.dtb” successfully in the extlinux.conf…done.
populating rootfs from /home/dr_b/YorLabs/Xavier/Linux_for_Tegra/rootfs … populating /boot/extlinux/extlinux.conf … done.
Sync’ing system.img … done.
Converting RAW image to Sparse image… done.
system.img built successfully.
Existing tbcfile(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/uefi_jetson.bin) reused.
131072+0 records in
131072+0 records out
67108864 bytes (67 MB, 64 MiB) copied, 0.6956 s, 96.5 MB/s
Sync’ing esp.img … done.
copying tbcdtbfile(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/kernel/dtb/tegra234-p3701-0000-p3737-0000.dtb)… done.
copying cfgfile(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/t186ref/cfg/flash_t234_qspi_sdmmc.xml) to flash.xml… done.
Existing flashapp(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/tegraflash.py) reused.
Existing overlay_dtb(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/L4TConfiguration.dtbo) reused.
Existing overlay_dtb(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/tegra234-p3737-overlay-pcie.dtbo) reused.
Existing overlay_dtb(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/tegra234-p3737-audio-codec-rt5658-40pin.dtbo) reused.
Existing overlay_dtb(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/tegra234-p3737-a03-overlay.dtbo) reused.
Existing overlay_dtb(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/tegra234-p3737-a04-overlay.dtbo) reused.
Existing overlay_dtb(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/L4TRootfsInfo.dtbo) reused.
Existing overlay_dtb(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/tegra234-p3737-camera-dual-imx274-overlay.dtbo) reused.
Existing overlay_dtb(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/tegra234-p3737-camera-e3331-overlay.dtbo) reused.
Existing overlay_dtb(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/tegra234-p3737-camera-e3333-overlay.dtbo) reused.
Existing overlay_dtb(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/tegra234-p3737-camera-imx185-overlay.dtbo) reused.
Existing overlay_dtb(/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/tegra234-p3737-camera-imx390-overlay.dtbo) reused.
./tegraflash.py --bl uefi_jetson_with_dtb.bin --odmdata gbe-uphy-config-22,hsstp-lane-map-3,nvhs-uphy-config-0,hsio-uphy-config-0,gbe0-enable-10g --overlay_dtb L4TConfiguration.dtbo,tegra234-p3737-overlay-pcie.dtbo,tegra234-p3737-audio-codec-rt5658-40pin.dtbo,tegra234-p3737-a03-overlay.dtbo,tegra234-p3737-a04-overlay.dtbo,L4TRootfsInfo.dtbo,tegra234-p3737-camera-dual-imx274-overlay.dtbo,tegra234-p3737-camera-e3331-overlay.dtbo,tegra234-p3737-camera-e3333-overlay.dtbo,tegra234-p3737-camera-imx185-overlay.dtbo,tegra234-p3737-camera-imx390-overlay.dtbo --bldtb tegra234-p3701-0000-p3737-0000.dtb --applet mb1_t234_prod.bin --cmd “flash; reboot” --cfg flash.xml --chip 0x23 --concat_cpubl_bldtb --cpubl uefi_jetson.bin --device_config tegra234-mb1-bct-device-p3701-0000.dts --misc_config tegra234-mb1-bct-misc-p3701-0000.dts --pinmux_config tegra234-mb1-bct-pinmux-p3701-0000.dtsi --gpioint_config tegra234-mb1-bct-gpioint-p3701-0000.dts --pmic_config tegra234-mb1-bct-pmic-p3701-0000.dts --pmc_config tegra234-mb1-bct-padvoltage-p3701-0000.dtsi --deviceprod_config tegra234-mb1-bct-cprod-p3701-0000.dts --prod_config tegra234-mb1-bct-prod-p3701-0000.dts --scr_config tegra234-mb2-bct-scr-p3701-0000.dts --wb0sdram_config tegra234-p3701-0000-p3737-0000-TE990M-wb0sdram.dts --br_cmd_config tegra234-mb1-bct-reset-p3701-0000.dts --dev_params tegra234-br-bct-p3701-0000.dts,tegra234-br-bct_b-p3701-0000.dts --mb2bct_cfg tegra234-mb2-bct-misc-p3701-0000.dts --bins “psc_fw pscfw_t234_prod.bin; mts_mce mce_flash_o10_cr_prod.bin; mb2_applet applet_t234.bin; mb2_bootloader mb2_t234.bin; xusb_fw xusb_t234_prod.bin; dce_fw display-t234-dce.bin; nvdec nvdec_t234_prod.fw; bpmp_fw bpmp_t234-TE990M-A1_prod.bin; sce_fw camera-rtcpu-sce.img; rce_fw camera-rtcpu-t234-rce.img; ape_fw adsp-fw.bin; spe_fw spe_t234.bin; tos tos-optee_t234.img; eks eks.img” --sdram_config tegra234-p3701-0000-p3737-0000-TE990M-sdram.dts --cust_info custinfo_out.bin --secondary_gpt_backup --bct_backup --boot_chain A
saving flash command in /home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/flash_win.bat
*** Flashing target device started. ***
version 1.0.0
[ 0.0295 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.0297 ] Assuming zero filled SBK key
[ 0.0169 ] Parsing partition layout
[ 0.0583 ] tegraparser_v2 --pt flash.xml.tmp
File “/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/tegraflash_impl_t234.py”, line 1370, in tegraflash_update_bpmp_dtb
if bpmp_dtb == None and bpmp_dtb_in_layout == None:
UnboundLocalError: local variable ‘bpmp_dtb’ referenced before assignment
During handling of the above exception, another exception occurred:
File “./tegraflash.py”, line 1369, in
tegraflash_run_commands()
File “./tegraflash.py”, line 1210, in tegraflash_run_commands
interpreter.onecmd(command)
File “/usr/lib/python3.8/cmd.py”, line 217, in onecmd
return func(arg)
File “./tegraflash.py”, line 271, in do_flash
self.chip_inst.tegraflash_flash(exports)
File “/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/tegraflash_impl_t234.py”, line 878, in tegraflash_flash
self.tegraflash_parse_partitionlayout()
File “/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/tegraflash_impl_t234.py”, line 458, in tegraflash_parse_partitionlayout
self.tegraflash_update_bpmp_dtb()
File “/home/dr_b/YorLabs/Xavier/Linux_for_Tegra/bootloader/tegraflash_impl_t234.py”, line 1436, in tegraflash_update_bpmp_dtb
raise tegraflash_exception('Unexpected error in updating: ’ + bpmp_dtb + ’ ’ + str(e))
Failed flashing t186ref.
+(/home/dr_b/YorLabs/Xavier/yor_xavier_scripts/flash_jetson_EVERYTHING.bash:219): popd
~/YorLabs/Xavier/yor_xavier_scripts
+(/home/dr_b/YorLabs/Xavier/yor_xavier_scripts/flash_jetson_EVERYTHING.bash:221): set +x
+(./setup_and_build_kernel_5.10.26_for_ORIN.bash:202): ‘[’ ‘!’ -z /home/dr_b/YorLabs/Xavier/yor_xavier_scripts/…/Orin-setup-build-2022_09_30_15_14_43.errors ‘]’
+(./setup_and_build_kernel_5.10.26_for_ORIN.bash:203): grep -i -e warning -e error /home/dr_b/YorLabs/Xavier/yor_xavier_scripts/…/Orin-setup-build-2022_09_30_15_14_43.log
+(./setup_and_build_kernel_5.10.26_for_ORIN.bash:204): cat /home/dr_b/YorLabs/Xavier/yor_xavier_scripts/…/Orin-setup-build-2022_09_30_15_14_43.errors
+(./setup_and_build_kernel_5.10.26_for_ORIN.bash:205): echo ’ ’
+(./setup_and_build_kernel_5.10.26_for_ORIN.bash:208): set +x
