Orin not starting
Software Version
DRIVE OS 6.0.4 (rev. 1): NO CLUE
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux: PEHAPS . IF ONLY I CAN LOGIN TO ORIN. MAYBE ITS ABRACADABRA
QNX
other
Hardware Platform
other ITS 945-13730-0000-000
SDK Manager Version
1.9.10816
other
Host Machine Version
other
Loike everybody else. I cannot get ORIN working. It doesnt start. Bought another computer with Linux 20.04. Installed SDK Manager. It keeps failing on flash
Who knows what to specify when? where?
ARE there any serious instructions or is it just hit and try. 10 tries are not good enough
Error: SuMMARY BSP Pathc - target : Depends on failed components
Cuda toolkit for L4T: Dependency Error
cuDNN on Target Dependency Error
Drivers for Jetson: OS image ready
Filesystem and OS OS image ready
Flash Jetson AGX Orin: Install error
Multimedia API: Dependency error
Nvidia container Error : same as above
OPEN CV: same as above
TensorRT on Target same as above
VPI on Target same as above
20:13:53 SUMMARY: BSP Patch - target: Depends on failed component
20:13:53 SUMMARY: Multimedia API - target: Depends on failed component
20:13:53 SUMMARY: TensorRT on Target - target: Depends on failed component
20:13:53 SUMMARY: VPI on Target - target: Depends on failed component
20:13:53 SUMMARY: CUDA Toolkit for L4T - target: Depends on failed component
20:13:53 SUMMARY: cuDNN on Target - target: Depends on failed component
20:13:53 SUMMARY: OpenCV - target: Depends on failed component
20:13:53 SUMMARY: DateTime Target Setup - target: Depends on failed component
20:14:09 SUMMARY: CUDA on Host - host: Install completed successfully.
20:14:09 SUMMARY: CUDA Cross Compile Package on Host - host: Install completed successfully.
20:14:09 SUMMARY: NvSci - host: Install completed successfully.
20:14:09 SUMMARY: VPI on Host - host: Install completed successfully.
20:14:09 SUMMARY: Nsight Systems - host: Install completed successfully.
20:14:09 SUMMARY: Nsight Graphics - host: Install completed successfully.
20:14:09 SUMMARY: Nsight Compute - host: Install completed successfully.
20:14:09 SUMMARY: CUPTI - host: Install completed successfully.
20:14:09 SUMMARY: Compute Sanitizer - host: Install completed successfully.
20:15:09 SUMMARY: Drivers for Jetson - target_image: Install completed successfully.
20:19:23 SUMMARY: File System and OS - target_image: Install completed successfully.
20:20:17 SUMMARY: Flash Jetson AGX Orin - flash: First Error: Installation failed.
20:20:17 SUMMARY: NVIDIA Container Runtime with Docker integration (Beta) - target: Depends on failed component
20:20:17 SUMMARY: BSP Patch - target: Depends on failed component
20:20:17 SUMMARY: Multimedia API - target: Depends on failed component
20:20:17 SUMMARY: TensorRT on Target - target: Depends on failed component
20:20:17 SUMMARY: VPI on Target - target: Depends on failed component
20:20:17 SUMMARY: CUDA Toolkit for L4T - target: Depends on failed component
20:20:17 SUMMARY: cuDNN on Target - target: Depends on failed component
20:20:17 SUMMARY: OpenCV - target: Depends on failed component
20:20:17 SUMMARY: DateTime Target Setup - target: Depends on failed component
20:22:13 SUMMARY: CUDA on Host - host: Install completed successfully.
20:22:13 SUMMARY: CUDA Cross Compile Package on Host - host: Install completed successfully.
20:22:13 SUMMARY: NvSci - host: Install completed successfully.
20:22:13 SUMMARY: VPI on Host - host: Install completed successfully.
20:22:13 SUMMARY: Nsight Systems - host: Install completed successfully.
20:22:13 SUMMARY: Nsight Graphics - host: Install completed successfully.
20:22:13 SUMMARY: Nsight Compute - host: Install completed successfully.
20:22:13 SUMMARY: CUPTI - host: Install completed successfully.
20:22:13 SUMMARY: Compute Sanitizer - host: Install completed successfully.
20:23:18 SUMMARY: Drivers for Jetson - target_image: Install completed successfully.
20:27:33 SUMMARY: File System and OS - target_image: Install completed successfully.
20:32:55 SUMMARY: Flash Jetson AGX Orin - flash: First Error: Installation failed.
20:32:55 SUMMARY: NVIDIA Container Runtime with Docker integration (Beta) - target: Depends on failed component
20:32:55 SUMMARY: BSP Patch - target: Depends on failed component
20:32:55 SUMMARY: Multimedia API - target: Depends on failed component
20:32:55 SUMMARY: TensorRT on Target - target: Depends on failed component
20:32:55 SUMMARY: VPI on Target - target: Depends on failed component
20:32:55 SUMMARY: CUDA Toolkit for L4T - target: Depends on failed component
20:32:55 SUMMARY: cuDNN on Target - target: Depends on failed component
20:32:55 SUMMARY: OpenCV - target: Depends on failed component
20:32:55 SUMMARY: DateTime Target Setup - target: Depends on failed component
INSTALLATION FAILED
Please review the terminal tab for details. Resolve and RETRY.
EXPORT LOGS
RETRY
FAILED ITEMS
STOP TRYING
Copyright © 2022, NVIDIA CORPORATION. All rights reserved. | NVIDIA Developer
SDKM_logs_JetPack_5.0.2_(rev._1)_Linux_for_Jetson_AGX_Orin_modules_2022-11-26_20-22-07.zip (245.1 KB)
TAG SYS ITS P3730
That is never detected
P3730 is not even an option for a device that doesnt work .
How do I fill this form? What am I supposed to know?
Has it been flashed? Dont know. The terminal doesnt work
Is it Auto? Dont know because of the same
Is it 32 GB? Who knows. I think I bought 64 GB?
Should it be preconfig??
IP address ??? Cant git it up and running so doesnt exist
What should be the stodo the tyoperage device
should I select manual option? Which one ?? 32 GB or unknown!!
preconfig or runtime?
EMMC or NVME?
I press middle button first, then the power button and then keep both pressed for some unknown time and then release them together. Nothing happens. MAybe its just an exercies to keep me busy. Nothing happens
Selecting manual option asks to turn the device off. and then it fails saying the device is off!!!
Also, what is On? Is the LED indicator means its on? Or does it have to make noise to be considered on
Which side is the front of Orin? I am trying hard and looking at it from all angles. Maybe its obvious but am not able to figure out the front and behind
The led is ON!! but its not making noise
Are you asking the question for Jetson platform or DRIVE platform?
This forum is for developers in NVIDIA DRIVE™ AGX SDK Developer Program. We will need you to use your account with corporate or university email address.
Or you can also change your current account to use corporate or university email address by following the below links:
My Profile | NVIDIA Developer → “Edit Profile” → “Change email” → “CHANGE”
Sorry for any inconvenience.
Just filed a new ticket with corporate email address
https://forums.developer.nvidia.com/t/nvidia-orin-doesnt-work/235524
Referred to my original ticket.
Hope this works
