Orin nvgpu
我们使用Linux R35.3.1版本的 的Orin 64G module,我们在测试相机时执行gst-launch-1.0 -v v4l2src device=“/dev/Video0” ! video/x-raw,framerate=30/1,width=1920,height=1080,format=UYVY ! xvimagesink ,偶尔会出现gpu问题,这个时候goome-shell cpu 100%
通过dmesg ,得到如下错误:
[ 108.109993] ga10b HDR cf1bf093 SHADOW0 81d31fca SHADOW1 19c3d90a
[ 108.118654] ga10b pbdma 3:
[ 108.125917] ga10b id: -1 - [channel] next_id: - -1 [channel] | status: invalid
[ 108.128983] ga10b PBDMA_PUT 00000015f47cd584 PBDMA_GET 000000ed9a9123dc
[ 108.136770] ga10b GP_PUT 00000000 GP_GET 03a21b7d FETCH 00000000 HEADER 219493fc
[ 108.143945] ga10b HDR 79b062df SHADOW0 b2b0a74b SHADOW1 90596fc1
[ 108.152605] ga10b pbdma 4:
[ 108.159866] ga10b id: -1 - [channel] next_id: - -1 [channel] | status: invalid
[ 108.162932] ga10b PBDMA_PUT 000000bfc35fe0f8 PBDMA_GET 00000075d707cab8
[ 108.170721] ga10b GP_PUT 00000000 GP_GET ca276c56 FETCH 00000000 HEADER 2102b4c0
[ 108.177894] ga10b HDR 2c632100 SHADOW0 207490ca SHADOW1 22576d27
[ 108.186554] ga10b pbdma 5:
[ 108.193814] ga10b id: -1 - [channel] next_id: - -1 [channel] | status: invalid
[ 108.196884] ga10b PBDMA_PUT 000000e1d1918fb4 PBDMA_GET 000000e1d1918fb4
[ 108.204671] ga10b GP_PUT 00000000 GP_GET 90f2a6ea FETCH 00000000 HEADER 4097ac24
[ 108.211844] ga10b HDR dadae679 SHADOW0 a8c7fff9 SHADOW1 44a44833
[ 108.220503] ga10b
[ 108.227769] ga10b ga10b eng 0:
[ 108.230305] ga10b id: 0 (tsg), next_id: -1 (channel), ctx status: valid
[ 108.233978] ga10b
[ 108.240980] ga10b ga10b eng 1:
[ 108.243597] ga10b id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[ 108.247104] ga10b
[ 108.254982] ga10b ga10b eng 2:
[ 108.257603] ga10b id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[ 108.261190] ga10b
[ 108.268981] ga10b ga10b eng 3:
[ 108.271511] ga10b id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[ 108.275190] ga10b
[ 108.282893] ga10b ga10b eng 4:
[ 108.285526] ga10b id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[ 108.289190] ga10b
[ 108.296805] ga10b ga10b eng 5:
[ 108.299423] ga10b id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[ 108.302929] ga10b
[ 108.310628] ga10b
[ 108.313080] nvgpu: 17000000.ga10b report_pbdma_error:330 [ERR] pbdma_intr_0(0)= 0x04000000
[ 108.325332] nvgpu: 17000000.ga10b nvgpu_cic_mon_report_err_safety_services:55 [ERR] Error reporting is not supported in this platform
[ 108.337146] nvgpu: 17000000.ga10b nvgpu_set_err_notifier_locked:149 [ERR] error notifier set to 24 for ch 509
[ 115.360479] nvgpu: 17000000.ga10b ga10b_pbdma_handle_intr_0_legacy:437 [ERR] semaphore acquire timeout!
[ 115.360855] ga10b Channel Status - chip ga10b
[ 115.360857] ga10b ---------------------------
[ 115.360993] ga10b 509-ga10b, TSG: 2, pid 2120, refs: 5, deterministic: no, domain name: (default)
[ 115.361134] ga10b channel status: in use on_pbdma, pbdma_busy busy
[ 115.361393] ga10b RAMFC: TOP: 8000001ff9be065c PUT: 001ff9be0670 GET: 001ff9be065c FETCH: 000000000000 HEADER: 2140006c COUNT: 11110000 SEMAPHORE: addr 002000180000 payload 000000000000006f execute 00081003
[ 115.361597] ga10b
[ 115.362110] ga10b 510-ga10b, TSG: 1, pid 1762, refs: 2, deterministic: no, domain name: (default)
[ 115.362187] ga10b channel status: in use idle not busy
[ 115.362439] ga10b RAMFC: TOP: 8000002004033f78 PUT: 002004033f78 GET: 002004033f78 FETCH: 000000000000 HEADER: 2140006c COUNT: 00000000 SEMAPHORE: addr 002004320000 payload 0000000000000000 execute 00000001
[ 115.362594] ga10b
[ 115.365236] ga10b 511-ga10b, TSG: 0, pid 1762, refs: 2, deterministic: no, domain name: (default)
[ 115.365606] ga10b channel status: in use on_eng not busy
[ 115.371024] ga10b RAMFC: TOP: 800000200404b090 PUT: 00200404b090 GET: 00200404b090 FETCH: 000000000000 HEADER: 2140006c COUNT: 00000000 SEMAPHORE: addr 002004020000 payload 0000000000000000 execute 00100001
[ 115.376802] ga10b
[ 115.395442] ga10b PBDMA Status - chip ga10b
[ 115.398065] ga10b -------------------------
全部信息通过附件上传
Orin_gpu.md (136.0 KB)
请问下这是NVGPU的什么bug
Could you try fakesink?
st-launch-1.0 -v v4l2src device=“/dev/Video0” ! video/x-raw,framerate=30/1,width=1920,height=1080,format=UYVY ! fpsdisplaysink video-sink=fakesink
我们使用v4l2编程打开多个相机的时候,测试了一两个月的过程中,同样偶尔会出现这个gpu报错的问题,这个时候通过top查看xorg 占用CPU100%,各相机的vi-ouput占用cpu100%
当我们停止的时候,close相机出现卡死,然后断电重启,重启进入系统后,报图片这个异常
Does your v4l2 APP have involve display for previewing?
我们v4l2读取相机数据,不同相机数据通过ros发布到不同的主题,使用rviz app进行显示,这个时候出现的问题
Maybe need to narrow down which module cause the problem first.
只有rviz 会订阅主题并显示,应该是显示的时候导致gpu出错了
Sorry don’t have experience for the RVIZ, you may want to post about RVIZ on the ROS forums.
但是就像最前面第一楼提到的,使用的gst-launch-1.0 一样会出现同样的问题,只是很偶现
Please check if any VI/CSI error before the GPU error shows.
行,我们尝试用gst-launch-1.0 -v v4l2src device=“/dev/Video0” ! video/x-raw,framerate=30/1,width=1920,height=1080,format=UYVY ! fpsdisplaysink video-sink=fakesink来复现这个问题,并抓下完整的log,但是不确定什么时候能复现
