Can Orin nx 16G module be test on p3509 a01 devkit board ? (we don’t have a02 kit)
We test orin nx 16G with p3509 a01 board, and system can not enter suspend mode.
System will reboot soon after we set to suspend
$ sudo systemctl suspend
We would like to know :
1.Did system reboot won’t happen on a02 board?
2. If a02 won’t happen, what’s the difference between a01 and a02 ?
Hi, the carrier for Orin NX is P3768_A04. Please refer to the compatibility link for the info. As noted: Jetson Orin NX & Jetson Orin Nano series modules are not pin-compatible with Jetson Xavier NX series modules, but you can design a carrier board for the I/Os they have in common, such that both modules are supported.
