I am working with a Jetson Orin NX 16GB module on a custom carrier board, and I am encountering a timeout issue during the flashing process.
Background: Previously, I was able to flash a firmware image onto this exact module and carrier board combination successfully. However, when I try to re-flash the firmware now, the process hangs waiting for the device to boot and eventually times out.
Environment:
Module: Jetson Orin NX 16GB
Carrier Board: Custom carrier board
JetPack Version: JetPack6.2
Host PC: Ubuntu 22.04
Error Log:
Waiting for target to boot-up...
Timeout
Device failed to boot to the initrd flash kernel. Please retrive the serial log during flashing to debug further.
Cleaning up...
What I have tried: I attempted two different flashing methods, but both resulted in the exact same timeout error.
Method 1: Flashing from a generated massflash package
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --flash-only --massflash 1 --network usb0 --showlogs
Method 2: Flashing directly using the BSP
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_nvme.xml -S 80GiB -p "-c bootloader/generic/cfg/flash_t234_qspi.xml" --network usb0 recomputer-orin-robotics-j401-gmsl external
Any guidance or troubleshooting tips would be greatly appreciated. Thank you in advance!
