Hej,
I ran in a similar issue like: Unable to change OC limit on NX 8/16GB boards - Jetson & Embedded Systems / Jetson Orin NX - NVIDIA Developer Forums
We have designed our custom board which ensures that the Module VDD_IN is at 12V and there is a Pull-Up register on the MODULE_ID pin. Software wise we are running a YOCTO based image. Please also find the discussion I have started at the OE4T repo here
When I just run those commands:
nvpmodel -m 0
jetson_clocks
./gpu_burn -tc 0
stress-ng --cpu 8
The overall Power shown in jtop does not exceed 25W. When I perform this:
echo 4472 > /sys/bus/i2c/drivers/ina3221/1-0040/hwmon/hwmon1/curr1_max
echo 4472 > /sys/bus/i2c/drivers/ina3221/1-0040/hwmon/hwmon1/curr1_crit
I do manage to go above the limits, as @WayneWWW mentioned here this is not required. So I do assume I have missed some parts. Can someone guide me to the missing part. Is the limit adjusted in the Linux device-tree or somewhere else. Like @SPFish144 mentioned it is quite unclear weather we do use super mode in a correct way or not.
We also use the gpu_burn and stress-ng to check what are the thermal limits of our housing.
