Orin NX 16GB on Waveshare IO-BASE-B: no display under Linux, UEFI works — clean flashes of L4T 36.3.0 and 36.4.7 both fail
Hardware
  • Jetson Orin NX 16GB module (p3767-0000)
  • Waveshare JETSON-ORIN-IO-BASE-B carrier (DisplayPort only, no HDMI)
  • Monitor connected via native DisplayPort cable (also tested DP->HDMI adapter)
  • Root filesystem on NVMe
Symptom
The bootloader/UEFI drives the monitor correctly — the NVIDIA logo and boot
messages are displayed over the same cable and monitor. The moment Linux takes
over, the screen goes black and the monitor reports “no signal” and enters
standby. This never recovers. The system is otherwise fully functional and
reachable over SSH.
What I have tested
  1. L4T 36.4.3 (JetPack 6.2), as originally flashed
    /sys/class/drm/card1-DP-1 : disconnected : edid = 0 byte
    dmesg:
    dce: dce_ipc_channel_init:311 Invalid Channel State [0x0] for ch_type [2]
    dce: dce_admin_setup_clients_ipc:585 Channel Reset Complete for Type [1]
    dce: dce_admin_setup_clients_ipc:561 Get queue info failed for [2]
    dce: dce_admin_setup_clients_ipc:585 Channel Reset Complete for Type [3]
    dce: dce_start_boot_flow:166 DCE_BOOT_DONE
    nv_platform 13800000.display: [drm] Cannot find any crtc or sizes
    NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff
    (the NVRM line repeats hundreds of times, and a new burst appears every
    time the DP cable is unplugged/replugged — so hotplug IS detected)
    Xorg.0.log (with the stock configuration):
    (–) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
    (–) NVIDIA(GPU-0): DFP-1: Internal TMDS → disconnected
  2. Forcing the display in xorg.conf
    With Option “ConnectedMonitor” “DFP-0”, Option “UseEDID” “false” and an
    explicit 1920x1080 modeline, X does set the mode:
    (II) NVIDIA(0): Setting mode “DFP-0:1920x1080_60.00”
    but the monitor never wakes up, so no link is established.
  3. Removing video=efifb:off from the kernel command line
    No change — the bootloader framebuffer is torn down when nvidia-drm loads.
  4. apt upgrade to L4T 36.4.7
    I discovered the firmware was out of sync: kernel/drivers were at 36.4.7
    while nvbootctrl still reported 36.4.3 and “Capsule update status: 0”.
    I applied the capsule manually (TEGRA_BL_3767_super.Cap to
    /boot/efi/EFI/UpdateCapsule/TEGRA_BL.Cap + OsIndications), after which:
    Current version: 36.4.7
    Capsule update status: 1
    DMI: … BIOS 36.4.7-gcid-42132812 09/18/2025
    Display behaviour unchanged.
  5. Full clean flash to L4T 36.3.0 (JetPack 6.0) using
    l4t_initrd_flash.sh --external-device nvme0n1p1
    -c tools/kernel_flash/flash_l4t_t234_nvme.xml
    -p “-c bootloader/generic/cfg/flash_t234_qspi.xml”
    –showlogs --network usb0 jetson-orin-nano-devkit internal
    “Flash is successful”.
    On 36.3.0 the situation is different but still broken:
    /sys/class/drm/ contains only: card0 renderD128 version
    → there are NO connector directories at all
    dmesg:
    drm drm: [drm] Cannot find any crtc or sizes
    lsmod shows nvidia, nvidia_modeset, tegra_drm, drm_kms_helper, host1x all
    loaded.
Device tree / board identification (on 36.4.x)
/proc/device-tree/model:
NVIDIA Jetson Orin NX Engineering Reference Developer Kit Super
/proc/device-tree/compatible:
nvidia,p3768-0000+p3767-0000-super
nvidia,p3767-0000
nvidia,tegra234
Questions
  1. Is “dce_admin_setup_clients_ipc:561 Get queue info failed for [2]” together
    with “Invalid Channel State [0x0] for ch_type [2]” expected on a healthy
    system, or does it indicate that the display IPC channel genuinely failed
    to come up? It is present on both 36.3.0 and 36.4.7 here.
  2. On 36.3.0 no DRM connectors are created at all, while on 36.4.x a DP-1
    connector exists but is permanently “disconnected” with a 0-byte EDID.
    What would explain the difference, and does it point to the DCB/pinmux
    being wrong for this carrier?
  3. The module is on a third-party carrier (Waveshare IO-BASE-B) flashed with
    the jetson-orin-nano-devkit configuration, which is what the vendor’s
    documentation instructs. Is there a way to verify from the running system
    which DCB was actually applied, and whether DP is enabled for SOR on this
    configuration?
  4. Given that UEFI successfully drives the same monitor over the same cable,
    can this still be a hardware issue (for example AUX AC-coupling on the
    carrier), or does the bootloader use a path that would work regardless?
I can provide full dmesg, Xorg.0.log or the flash log on request.
I am happy to test JetPack 6.2.3 / Jetson Linux 36.5.2 if you think that
could change anything — I have not tried it yet.
Try to check rel-36.5 and also just share us the xorg log right after flash. No need to configure anything for now.
Thanks. I flashed rel-36.5 (Jetson Linux 36.5.0) with l4t_initrd_flash.sh
using jetson-orin-nano-devkit, and made no configuration changes afterwards.
The monitor was connected via a native DP cable and powered on during boot.
Same result: the UEFI logo is shown, then the screen goes black / no signal
once the kernel display driver takes over.
Xorg.0.log and dmesg from the first boot are attached.
Key lines:
Xorg.0.log
(–) NVIDIA(GPU-0): DFP-0: disconnected (Internal DisplayPort)
(–) NVIDIA(GPU-0): DFP-1: disconnected (Internal TMDS)
(–) NVIDIA(0): No enabled display devices found
dmesg
NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x730282 result 0x1f
When you hotplug the monitor, will you see xorg gives you any new log?
When hotplugging the monitor (DP cable unplugged at ~168 s and plugged back
in at ~177 s):
Xorg.0.log: nothing new was printed.
dmesg — each hotplug is detected, but the same two RM calls fail every time:
[ 168.275659] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
[ 168.276702] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x730282 result 0x1f:
[ 177.743674] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
[ 177.744687] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x730282 result 0x1f:
The same two failures also occur at boot (16.0 s), right before
“nv_platform 13800000.display: [drm] Cannot find any crtc or sizes”.
Do you have other monitor or carrier board that could test?
I tested with a second monitor ([märke och modell]) over a native
DP-to-DP cable. Same result: the NVIDIA logo / UEFI boot screen is shown,
then the screen goes black once Linux takes over.
So the behaviour is identical on two different monitors. I don’t have
another carrier board. Does this point to the Waveshare carrier board?
Additional test: I also flashed 36.5.0 with the p3509-a02-p3767-0000
configuration. The output then appears as HDMI-A-1 instead of DP-1, and
hotplug is no longer detected at all (no RM calls on plug/unplug), with
either a direct DP cable or a DP->HDMI adapter.
With jetson-orin-nano-devkit, hotplug IS detected every time, but the
RM calls 0x731341 (result 0xffff) and 0x730282 (result 0x1f) fail.
So HPD seems correctly wired for the p3768 configuration on this carrier,
but reading the sink fails. Could this be an AUX channel problem on the
carrier (for example missing AC-coupling capacitors on AUX_P/AUX_N), even
though UEFI can drive the same monitor?
Additional test with UEFI display hand-off:
  • Set “SOC Display Hand-Off Mode” to Always in UEFI
    (efivar SocDisplayHandoffMode = 0x01, confirmed).
  • Blacklisted nvidia, nvidia_modeset, nvidia_drm and removed video=efifb:off.
Result: the UEFI logo is shown, then the monitor still loses signal.
/chosen/framebuffer is present but stays:
compatible = simple-framebuffer
status = disabled
width = 0, height = 0, stride = 0
No efifb/simplefb is registered (/proc/fb is empty).
So UEFI drives this monitor, but even with hand-off set to Always it does
not hand the display over, and the kernel display driver cannot read the
sink. Why would UEFI hand-off leave the framebuffer node disabled with
zero size on this board?
No need to try those tests you just did there. They do not really help.
I feel it is carrier board hardware issue. However, as it is not NV devkit, there is no next steps I could suggest but find another carrier board.
