Setup: Jetson Orin NX 16GB on a third-party carrier board, JetPack 6.2 target. Hardware on order — this is a pre-deployment design question, not a fault report.
We have two devices in the same cabinet on the same switch: a Jetson running a vision pipeline, and a separate x86 machine producing timestamped records. We need to match events from the two within a defined time window. Sites have unreliable internet, so an external NTP source is not dependable.
Three questions:
- Does the Orin NX support hardware timestamping on its Ethernet MAC for PTP (IEEE 1588), and is linuxptp supported on the JetPack 6.2 BSP? If hardware timestamping depends on the carrier board’s PHY, what should we ask our carrier board vendor to confirm?
- If PTP is not practical, is chrony against a local site master the recommended fallback, and what drift should we expect on Orin NX over a 24-hour period with no external reference?
- Is there guidance on avoiding clock steps on Jetson — we want the clock slewed rather than stepped, since a backward step would corrupt our event ordering. Does anything in the JetPack boot sequence step the clock after userspace starts?
